Pamac build capt-src don’t work
Hello Linux friend, nerds I do have a strange problem
In my KDE Manjaro 21.0.7 I get error that that does not work
In terminal run: pamac build capt-src
And I got error not working that capt-src does not work or not exist in aur repository
Any one have the same problem
Best regards
Peter Linux Nuub!
capt-src exists.
Please post the exact output of that command.
You also will want to read the pinned comment.
This is the answer I gotten
The HTTP 429 Too Many Requests response status code indicates the user has sent too many requests in a given amount of time (“rate limiting”). Sounds like you’re querying the AUR too often.
Oookej did it one time
You can be rate limited if you’re using a VPN or proxy. If not, try again later.
Please paste terminal output, not screenshots or photos.
okej then i know
