PacUI: Bash script providing advanced Pacman and Yay/Pikaur/Aurman/Pakku/Trizen/Pacaur functionality in a simple UI
cli
pacui
pacman
yay
aur
#361
Based on its git page (and mentions by @c00ter) it seems that trizen might be a viable successor to pacaur. I’ll do some testing and research and see if we should add it to repos…
#362
I’ve installed trizen and integrated into my normal workflow - updating system, added to @Chrysostomus 's update-check.
It has an issue when doing trizen -Su in that it keeps asking to update pacui-git , which I do not get with pacaur or yaourt:
 there is nothing to do
:: Package qemu-launcher is unmaintained!
 1. pacui-git: 1.8.r30.g9e90d53-1 ==> r628.gf15de67-3
=>> Select packages for upgrade (default: all)
Other than that it looks promising.
#363
up to now, i like yay, because its syntax is simple. on the other hand, installing 200mb of “go” (only as a makedepend) is kind of strange.
trizen installs many perl packages (but not very large in size).
aurutils is supposed to create a local repository instead of using pacman’s cache directory. i have not tested it yet, but has the least amount of dependencies.
maybe, my PKGBUILD file of pacui-git contains an error, which prevents the AUR helper tool to resolve the latest version number of git packages?
i am not an experienced packager at all. it would be great, if somebody has some suggestions to solve this problem.
#364
i have just integrated a check for AUR helpers before the UI is loaded. if no AUR helper is found, a warning message is printed.
i have also changed the code to easily support multiple AUR helpers. in order to test this, i have included “yay” support (i needed about 15min for it), because this is the AUR helper i have recently tested.
when i am done testing trizen and aurutils, i will include support for them (if i like them).
#365
hi all,
i use the old and good Pacli and it is 100% :wink:
vlw fwi, Holmes :slight_smile:
#366
does pacli still work properly?
the “clean system” option should be broken, because the syntax of pacman-mirrors has changed. but i am not sure, whether “pacman-mirrors -g” still works (with a displayed warning), or whether it is deprecated completely.
if pacli works for you and does everything you want to do, i recommend you stick with it. it is open source, so you can even fix bugs yourself when they occur.
have you ever done a survey, what the kibojoe users prefer? pacli or pacui?
pacui contains currently about 2000 lines of code (it has started with about 400 lines of code). i have reduced its options to 15 (but it can do much more than pacli). currently, i am working on support for many AUR helpers…
#367
i have just added trizen support to pacui.
i had to disable the info preview on the right side for yay, because strangely it requires root privileges for it (and this messes up fzf). i will enable it again as soon as this bug is fixed.
#368
Just tried yay - fails…
:: 1 Packages to upgrade.
0  aur/firefox-always-nightly   		59.0a1.20171230100110-1 -> 99.0a1-20
Enter packages you don't want to upgrade.
Numbers:
==> Installing firefox-always-nightly
==> Directory exists. Clean Build? [y/N] y
==> Edit PKGBUILD? [y/N] n
Error installing firefox-always-nightly : invalid variable:
pkgname
#369
When you have chosen the desired aur helper to depend on, notify me so I know to add it to the repos.
#370
Tested now with trizen. Trizen seems to be a legit contender for the title.
#371
Hey. Interesting!
I was just checking/mentioning that the other day. Do I get kudos for it? I want the kudos.
…So then that brings a larger set of depends [perl*] - no reservations about it ?
#372
trizen brings many (but relatively small) perl dependencies with it, yes.
yay brings one large go (make) dependency with it.
i do not plan to make trizen a hard dependency of pacui, though. instead, i have implemented a check for AUR helpers being installed on the users system. (the UI of) pacui does not start without an AUR helper. this should prevent users facing a “broken” pacui and advanced users can still choose their preferred AUR helper.
#373
i have just fixed the problem of pacui-git being shown as outdated when doing an update using trizen. you simply need to install the latest pacui-git version.
the version number no longer corresponds to the release version (e.g. 1.8.1), but only on the number of github commits (e.g. r721).
#374
Just updated and now no longer have the problem :sunny: :smile:
#375
i have just worked on the “config” and “fix” options without changing anything the user should notice. i basically improved security and handling of some edge cases. please report, if one of those options is not working as previously anymore.
i have also added the preview window to the list view of “t”, “rt”, and “ls” options. please test this feature and report any bugs you may find.
#376
Hoping we can make a new release soon.
#377
is there something, which makes a release advantageous or necessary?
everybody, who wants the latest version can install pacui-git from the AUR.
about an hour ago, i have thought about a release, but when doing big features, i think at least a week of testing before a release is a good thing.
one more thing: you have mentioned above that you like trizen and want to put a maintained AUR helper (besides yaourt) in the manjaro repositories. have you decided which AUR helper to package?
#378
I want support for different aur helpers on iso :slightly_smiling_face:. Also, the git version does not provide pacui, which many packages depend on, so using the git version makes bothersome extra work.
Currently trizen has been the best I tried. Any others you would recommend trying? Aurutils seemed a bit cumbersome because of its nonmonolithic approach.
#379
i just fixed that with the relase of pacui-git a couple of minutes ago.
also, i have just seen your request on the AUR for the same thing :grin:
i have not tested aurutils yet, because you need to manually setup a local repository. this is the reason i have implemented support for it in pacui.
but if there is somebody here, who is familiar with it (and can answer a couple of my questions), i can still implement support for it rather quickly.
i hope you have seen my comment above:
this means there will not be a hard dependency for an AUR helper in pacui (except, you can give me a good reason for it). at least, i have integrated a couple of warnings when AUR helpers are missing.
#380
Would it be possible to implement pacui so that it just uses pacman if no aur helper is present?
