Pactree - show dependencies required only for queried package
pactree shows dependencies of a package. An option I’d find useful, but can not find in the manual or else was to filter dependencies that only solely exist for the queried package .
EXAMPLE:
$ pactree bash
bash
├─readline
│ ├─glibc
│ │ ├─linux-api-headers>=4.10
│ │ ├─tzdata
│ │ └─filesystem
│ │   └─iana-etc
│ ├─ncurses
│ │ ├─glibc
│ │ └─gcc-libs
│ │   └─glibc>=2.27
│ └─ncurses provides libncursesw.so=6-64
├─readline provides libreadline.so=8-64
├─glibc
├─ncurses
└─bashrc-manjaro provides bashrc
  └─bash
shows all dependencies for bash. One of those is glibc in example. glibc has close to 2000 packages depending on it on my system.
What I would like to see are only packages that are only there because bash (and no other package) depends on them.
is there a way?
Hi @vrms,
Try:
pactree --reverse <package>
Where <package> is the name of the package you want to check the dependencies of.
From the help:
$ pactree --help
-r, --reverse           list packages that depend on the named package
Hope this helps!
I am aware of pactree --reverse <pkg_name> (which shows packages depending on <pkg_name>). But that is not what I meant. Sorry if I was not clear enough.
I’ll add an example to my Topic.
pactree pacman -d1
LANG=C pacman -Qi pacman | grep '^Depend'
this ?
EDIT
OK
see dependencies only that become orphaned if you delete the package
that would (in the bash example from above), also show glibc. So no, not what I thought of.
exaclty
packages required only by one package :
 LANG=C pacman -Qi | gawk '/^Name/ {x=$3}; /^Required By     : vlc$/ {print x}'
aribb24
ffmpeg4.4
libdvbpsi
libmatroska
libtar
libupnp
note: exists also sub-dependencies :
LANG=C pacman -Qi | gawk '/^Name/ {x=$3}; /^Required By     : ffmpeg4.4$/ {print x}'
libmfx
so, libmfx is also removed or orphan with vlc
out of curiosity … what is the leading LANG=C doing exactly?
If your language isn’t English, prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
  • C standing for the programming language C?
  • because C only has output in English, this forces the output to be in English (even if my bash was using something else) ?
Indeed.
I honestly don’t know what, if anything, it stands for…I just know what it does.
If you don’t prepend with English, “name” and “required by” in the oneliner will not work as search strings and will have to be translated too.
for me, no english man, pacman -Qi return :
Nom                      : bash
Fournit                  : sh
Dépend de                : readline  libreadline.so=8-64  glibc  ncurses
Requis par               :
I search “Required By” or "Dépend de ", Nom/Name ? if i force english, it’s easy, i can search only “Name” and code is OK for all users
why you want this dependencies information ?
pacman -Rs package_name
remove package and unnecessary dependencies
Yes, it refers to the programming language C, and concretely, with LC_ALL=C, you also get all of the output — e.g. the date/time format, collation, et al — in the standard C formatting.
