Tried pacnew-chaser (from the AUR) using Gnome 40 DE.
Doesnot find any .pacnew.
List of *.pacnew at this time:
/etc/systemd/resolved.conf.pacnew
/etc/pacman.d/chaotic-mirrorlist.pacnew
If exists @papajoke then what is wrong…
This is the script I use. Replace meld
with another program if you prefer.
#!/bin/bash
# Merge new *.pacnew configuration files with their originals
echo; echo; echo ".pacnew files found: $(/usr/bin/pacdiff --output | wc -l)"
echo; /usr/bin/pacdiff --output; echo
set -euo pipefail
export PATH=/usr/bin:/usr/sbin
for i in $(/usr/bin/pacdiff --output); do
echo "Merging $i ..."
/usr/bin/meld "admin://$i" "admin://${i/.pacnew/}"
echo; echo
read -p "Delete the .pacnew file $i? " -n 1 -r
if [[ $REPLY =~ ^[YyOo]$ ]]
then
echo; sudo rm -v $i
fi
done
If @papajoke cannot repair or do something else, I have to put your script into which location?
Think /usr/bin/ will a nice place or better in .zshrc?
I use Meld because of Firefox - CustomCSSforFx.
Script casts ERROR in Meld:
There was a problem opening the file
Der angegebene Ort wird nicht unterstützt
means probably:
unable to handle “admin:” locations ----> sudo?? ← No
What now? I can load the file with the Filerequester of Meld
User scripts go in user folders like ~/bin
or ~/.local/bin
Yep, it’s broken right now. You can use this instead for now. You’ll want to install zensu
gksu /usr/bin/meld "$i" "${i/.pacnew/}"
# /usr/bin/meld "admin://$i" "admin://${i/.pacnew/}"
That works, thank You so much
(~.local/bin/test-pacnew) and use kdesu (I use Krusader for damaging system)
