Hello, I may not be new linux user but I am not that good with it.
I reinstalled my Manjaro so I can have clean slate. Noting new here, I done must have configs and rebooted couple of times. Everything looked fine including Nvidia drivers.
As I have dual boot, on next day I started my computer and chose Manjaro. It got stuck before login.
On TTY I tried to update
sudo pacman-mirrors -f3
sudo pacman -Syyu
Also xorg don’t start, tail of log after inxi
Inxi
Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=4e47a25c-b855-4219-807e-f85aa5237861 rw quiet splash
resume=UUID=b55c5dcf-1e53-4132-974d-c1e920c9432e udev.log_priority=3
Console: tty 2 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: STRIX Z270F GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1009
date: 07/23/2017
Info: model: Intel Core i5-7600K bits: 64 type: MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF2
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 3087 high: 3800 min/max: 800/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 3800 2: 951 3: 3800
4: 3800 bogomips: 30409
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: disabled, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: Gigabyte driver: N/A
alternate: nouveau non-free: 535.xx+ status: current (as of 2023-07)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-22 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1e89 class-ID: 0300
Device-2: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 046d:0826
Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2 driver: X:
loaded: N/A failed: nvidia gpu: N/A tty: 240x67
API: OpenGL Message: GL data unavailable in console. Try -G --display
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-3: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.1.41-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.75 status: off with: wireplumber status: off
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: off with: pulseaudio-alsa type: plugin
tools: pacat,pactl
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.66 TiB used: 409.44 GiB (8.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QEXE7 temp: 36.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU800 size: 119.24 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 8BS scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 409.44 GiB (45.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 129 Uptime: 3m wakeups: 0 Memory: total: 32 GiB
available: 31.28 GiB used: 557 MiB (1.7%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1244 libs: 403 tools: pamac pm: flatpak pkgs: 0
Shell: Bash (login) v: 5.1.16 running-in: tty 2 inxi: 3.3.28
/var/x.org
[ 293.723]
X.Org X Server 1.21.1.8
[ 293.723] Current Operating System: Linux peff-manjaro 6.1.41-1-MANJARO #1 SMP PREEMPT_DYNAMIC Tue Jul 25 09:17:30 UTC 2023 x86_64
[ 293.723] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=4e47a25c-b855-4219-807e-f85aa5237861 rw quiet splash resume=UUID=b55c5dcf-1e53-4132-974d-c1e920c9432e udev.log_priority=3
[ 293.723]
[ 293.723] Current version of pixman: 0.42.2
[ 293.723] Before reporting problems, check http://wiki.x.org
[ 293.723] Markers: (--) probed, (**) from config file, (==) default setting,
[ 293.723] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Aug 7 14:27:14 2023
[ 293.725] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 293.725] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 293.726] (==) ServerLayout "layout"
[ 293.726] (**) |-->Screen "Screen0" (0)
[ 293.726] (**) | |-->Monitor "Monitor0"
[ 293.726] (**) | |-->Device "Device0"
[ 293.726] (==) Automatically adding devices
[ 293.726] (==) Automatically enabling devices
[ 293.726] (==) Automatically adding GPU devices
[ 293.726] (==) Automatically binding GPU devices
[ 293.726] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 293.727] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 293.727] Entry deleted from font path.
[ 293.727] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 293.727] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 293.727] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 293.727] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 293.727] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 293.727] (**) Extension "COMPOSITE" is enabled
[ 293.727] (II) The server relies on udev to provide the list of input devices.
[ 293.727] (II) Module ABI versions:
[ 293.727] X.Org ANSI C Emulation: 0.4
[ 293.727] X.Org Video Driver: 25.2
[ 293.727] X.Org XInput driver : 24.4
[ 293.727] X.Org Server Extension : 10.0
[ 293.728] (++) using VT number 2
[ 293.729] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 293.732] (--) PCI:*(1@0:0:0) 10de:1e89:1458:3fc1 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 293.732] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 293.732] (II) LoadModule: "glx"
[ 293.732] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 293.737] (II) Module glx: vendor="X.Org Foundation"
[ 293.737] compiled for 1.21.1.8, module version = 1.0.0
[ 293.737] ABI class: X.Org Server Extension, version 10.0
[ 293.737] (II) LoadModule: "nvidia"
[ 293.737] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 293.740] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 293.740] compiled for 1.6.99.901, module version = 1.0.0
[ 293.740] Module class: X.Org Video Driver
[ 293.740] (II) NVIDIA dlloader X Driver 535.86.05 Fri Jul 14 20:26:08 UTC 2023
[ 293.740] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 293.741] (II) Loading sub module "fb"
[ 293.741] (II) LoadModule: "fb"
[ 293.741] (II) Module "fb" already built-in
[ 293.741] (II) Loading sub module "wfb"
[ 293.741] (II) LoadModule: "wfb"
[ 293.741] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 293.742] (II) Module wfb: vendor="X.Org Foundation"
[ 293.742] compiled for 1.21.1.8, module version = 1.0.0
[ 293.742] ABI class: X.Org ANSI C Emulation, version 0.4
[ 293.746] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 293.747] (EE) NVIDIA: system's kernel log for additional error messages and
[ 293.747] (EE) NVIDIA: consult the NVIDIA README for details.
[ 293.747] (EE) No devices detected.
[ 293.747] (EE)
Fatal server error:
[ 293.747] (EE) no screens found(EE)
[ 293.747] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
How to process from here?
