pacman remove is pacman -Rs !
howto install/uninstall clonezilla.
use pacman?
installing:
pacman -S clonezilla
UnInstalling is not working so:
pacman remove --auto-remove clonezilla
works by using Add/Uninstalling Menue
You need to learn the options form pacman .
https://wiki.archlinux.org/index.php/Pacman#Removing_packages
also useful
https://wiki.archlinux.org/index.php/Pacman/Rosetta
# pacman -Rs clonezilla
thanks :slight_smile: works
