Thank you for your reply, @linux-aarhus. Your explanation does make sense. However, I have seen this consistently for several days now. For what it is worth, I have not made any other changes to my mirrors, nor any other configuration changes.
When I run sudo pacman-mirrors -c United_States,Germany,Austria -i -fc
, for example, I get the following output:
::WARNING https://repo.manjaro.org 'Connection: HTTPSConnectionPool(host='repo.manjaro.org', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))'
::WARNING https://wikipedia.org 'Connection: HTTPSConnectionPool(host='wikipedia.org', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))'
::ERROR Connection: HTTPSConnectionPool(host='repo.manjaro.org', port=443): Max retries exceeded with url: /mirrors.json (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
::INFO => Mirror status: https://repo.manjaro.org/status.json
::ERROR Connection: HTTPSConnectionPool(host='repo.manjaro.org', port=443): Max retries exceeded with url: /status.json (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
..... Austria : https://mirror.easyname.at/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='mirror.easyname.at', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
..... Germany : https://mirror.alpix.eu/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='mirror.alpix.eu', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
0.886 United_States : http://mirror.fcix.net/manjaro/
..... United_States : https://nnenix.mm.fcix.net/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='nnenix.mm.fcix.net', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
..... United_States : https://irltoolkit.mm.fcix.net/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='irltoolkit.mm.fcix.net', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
..... United_States : https://uvermont.mm.fcix.net/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='uvermont.mm.fcix.net', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
..... United_States : https://ziply.mm.fcix.net/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='ziply.mm.fcix.net', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
..... United_States : https://mnvoip.mm.fcix.net/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='mnvoip.mm.fcix.net', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
..... United_States : https://forksystems.mm.fcix.net/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='forksystems.mm.fcix.net', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
..... United_States : https://codingflyboy.mm.fcix.net/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='codingflyboy.mm.fcix.net', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
..... United_States : https://coresite.mm.fcix.net/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='coresite.mm.fcix.net', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
..... United_States : https://opencolo.mm.fcix.net/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='opencolo.mm.fcix.net', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
..... United_States : https://southfront.mm.fcix.net/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='southfront.mm.fcix.net', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
..... United_States : https://volico.mm.fcix.net/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='volico.mm.fcix.net', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get issuer certificate (_ssl.c:1002)')))
But ultimately, I can select several from United States, Germany and Austria.
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Writing mirror list
::Austria : https://mirror.easyname.at/manjaro/stable/$repo/$arch
::Germany : https://mirror.alpix.eu/manjaro/stable/$repo/$arch
::United_States : http://mirror.fcix.net/manjaro/stable/$repo/$arch
::United_States : https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States : https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States : https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States : https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States : https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States : https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States : https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States : https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States : https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States : https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
::United_States : https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
sudo pacman -Syyu
is successful.
Maybe a different issue, I don’t want to pollute this thread with a different issue. I would like to know know if this is related.
