Pacman-mirrors minor updates explained
pacman-mirrors
#1
The 4.2.1 update was a small update fixing an inconvenient exitcode when using --api --get-branch and it was a change in output and some minor cosmetics.
The 4.2.2 update was a small update fixing a regression bug as reported in this post
A text constant had gone missing. I can’t remember removing it but it was gone.
This missing constant only affected situations where a country having no mirrors was specified either on commandline, in pacman-mirrors.conf or in a custom-mirrors.json.
The effect would be pacman-mirrors stalling with an error stating the constant did not exist. Adding the constant in the file removed the error.
Cinnamon, Deepin and i3 17.0.3 release candidates
#2
Might be time to introduce some automated testing. pacman-mirrors is now an integral part of Manjaro installations so we need to spot these things before deployment to ‘stable’.
#3
There is a lot of tests being done with make test - I am very positive to new tests which can improve the finial result.
#4
I have added ten more testcases each of which tests for the presence of specific string constants which - for now is in use.
With these it is not possible to accidentally remove a string constant without the entire testsuite failing.
So now we have 118 tests which being run when master repo is updated
