Pacman-Mirrors issue
#1
I’ve encountered an interesting problem while trying to update my software/install.
When running: sudo pacman-mirrors -g, the next errors shows up:
Traceback (most recent call last): File "/usr/bin/pacman-mirrors", line 23, in <module> from pacman_mirrors import pacman_mirrors ModuleNotFoundError: No module named 'pacman_mirrors'
What can be done about this error?
#2
This option doesn’t exist any more. Are you up-to-date?
#3
That’s the thing. Not sure if I am or not.
Haven’t been able to update my system for awhile now…
Wonder if my install got botched and some packages/dependencies weren’t installed at all.
#4
I think it is reasonable to assume you are not up-to-date.
What is the output of sudo pacman -Syyu
#5
This:
 core        210.0 KiB   382K/s 00:01 [####################################################################] 100%
 extra        2.3 MiB   303K/s 00:08 [####################################################################] 100%
 community        4.8 MiB   686K/s 00:07 [####################################################################] 100%
warning: lsb-release: local (1.4-15) is newer than core (1.4-12)
warning: manjaro-icons: local (20180304-1) is newer than extra (20170701-1)
warning: tzdata: local (2018e-2) is newer than core (2018e-1)
 there is nothing to do
#6
What is the contents of /etc/pacman.d/mirrorlist
#7
## Manjaro Linux repository mirrorlist
## Generated on 06 August 2018 17:32
## Use pacman-mirrors to modify
## Location  : United_States
## Time      :  0.238
## Last Sync :
Server = http://ftp-osl.osuosl.org/pub/manjaro-arm/repo/stable/$arch/$repo
## Location  : Denmark
## Time      :  1.465
## Last Sync :
Server = http://mirror.strits.dk/manjaro-arm/stable/$arch/$repo
## Location  : Switzerland
## Time      :  1.554
## Last Sync :
Server = https://mirror.scachemaille.ch/manjaro-arm/stable/$arch/$repo
#8
You have tagged the issue with Manjaro ARM but as far as I know pacman-mirrors does not work on Manjaro ARM.
#9
Manjaro ARM is using the old pacman-mirrors, where it has a static mirror list and uses -g to rank them.
#10
Try getting the newest pacman-mirrorlist package from here. You can install it with:
sudo pacman -U http://mirror.strits.dk/manjaro-arm/stable/any/core/pacman-mirrorlist-20181215-1-any.pkg.tar.xz
