Pacman-mirrors gives up too early
Below, I ask for 99, but only get 1, as the 2nd fails:
% sudo pacman-mirrors -f 99
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
  ..... Australia      : http://manjaro.melbourneitmirror.net/
::ERROR Not Found 'http://manjaro.melbourneitmirror.net/'
  1.108 Australia      : http://manjaro.mirror.serversaustralia.com.au/
::INFO Writing mirror list
::Australia       : http://manjaro.mirror.serversaustralia.com.au/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
How to workaround this?
You have a custom mirror file. Probably because you chose your country.
Try:
sudo pacman-mirrors -c all && sudo pacman-mirrors -f
I think they should be update. That what I’m thinking.
Customizing the mirror pool
If you, for various reasons, have a preference for specific mirrors, it is possible to create a personal mirror pool. This is done by supplying –interactive [–default] , –continent-- or --country argument.
A word of caution
Don’t limit yourself too much. Pacman-mirrors will only use up-to-date mirrors in the final mirrorlist. Also observe this: Your custom mirror pool will not be changed - even if a mirror leaves service or becomes unmaintained. It is your reponsibility to maintain your custom mirror pool in the event the official mirrorpool is changed.
– Pacman-mirrors - Manjaro Linux
