pacman-mirrors -f ERROR not found for every link
Hello everyone, i'm trying to install a packet on my machine and it seems like my mirrors are all broken. I've been jumping from post to post trying solutions but nothing worked.
inxi -Fx (as guidelined)
System:    Host: insig-pc Kernel: 4.14.166-1-MANJARO i686 bits: 32 compiler: gcc v: 9.2.0
           Desktop: Xfce 4.14.1 Distro: Manjaro Linux
Machine:   Type: Kvm System: clevo product: M7X0SUN v: Rev. A1 serial: <root required>
           Mobo: clevo model: M7X0SUN v: Bottom serial: <root required> BIOS: Phoenix v: 6.00
           date: 09/16/2009
CPU:       Topology: Dual Core model: Intel Core2 Duo T8300 bits: 64 type: MCP arch: Penryn rev: 6
           L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 9601
           Speed: 1200 MHz min/max: 1200/2401 MHz Core speeds (MHz): 1: 1200 2: 1200
Graphics:  Device-1: NVIDIA G98M [GeForce G 105M] vendor: CLEVO/KAPOK driver: nvidia v: 340.107
           bus ID: 01:00.0
           Display: x11 server: X.org 1.20.6 driver: nvidia resolution: <xdpyinfo missing>
           OpenGL: renderer: GeForce G 105M/PCIe/SSE2 v: 3.3.0 NVIDIA 340.107 direct render: Yes
Audio:     Device-1: Silicon Integrated Systems [SiS] Azalia Audio vendor: CLEVO/KAPOK
           driver: snd_hda_intel v: kernel bus ID: 00:0f.0
           Sound Server: ALSA v: k4.14.166-1-MANJARO
Network:   Device-1: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter
           vendor: CLEVO/KAPOK driver: sis190 v: 1.4 port: 1000 bus ID: 00:04.0
           IF: enp0s4 state: down mac: 00:90:f5:96:9c:e7
           Device-2: Realtek RTL8187B Wireless 802.11g 54Mbps Network Adapter type: USB
           driver: rtl8187 bus ID: 1-2:2
           IF: wlp0s3f3u2 state: up mac: 00:25:d3:96:0d:33
Drives:    Local Storage: total: 149.05 GiB used: 64.54 GiB (43.3%)
           ID-1: /dev/sda vendor: Western Digital model: WD1600BEVS-00VAT0 size: 149.05 GiB
Partition: ID-1: / size: 139.30 GiB used: 64.54 GiB (46.3%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 6.51 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 62.8 C mobo: N/A gpu: nvidia temp: 70 C
Info:      Processes: 143 Uptime: 44m Memory: 2.96 GiB used: 1.33 GiB (44.8%) Init: systemd
           Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11 inxi: 3.0.37
The ERROR:
sudo pacman-mirrors -f5 && sudo pacman -Syyu
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  ..... Germany        : https://mirror.23media.com/manjaro/
::ERROR Not Found 'https://mirror.23media.com/manjaro/'
  ..... Germany        : http://mirror.23media.com/manjaro/
::ERROR Not Found 'http://mirror.23media.com/manjaro/'
  ..... Denmark        : https://www.uex.dk/public/manjaro/
::ERROR Not Found 'https://www.uex.dk/public/manjaro/'
  ..... Brazil         : https://manjaro.c3sl.ufpr.br/
::ERROR Not Found 'https://manjaro.c3sl.ufpr.br/'
  ..... Germany        : https://mirror.alpix.eu/manjaro/
::ERROR Not Found 'https://mirror.alpix.eu/manjaro/'
  ..... Sweden         : https://mirror.zetup.net/manjaro/
::ERROR Not Found 'https://mirror.zetup.net/manjaro/'
::INFO Writing mirror list
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
error: failed to update core (no servers configured for repository)
error: failed to update extra (no servers configured for repository)
error: failed to update community (no servers configured for repository)
error: failed to update multilib (no servers configured for repository)
error: failed to synchronize all databases
The files:
*sudo cat /etc/pacman **
/etc/pacman.conf  /etc/pacman.conf.pacnew  /etc/pacman-mirrors.conf
/etc/pacman.d:
gnupg  mirrorlist
cat /etc/pacman.conf
## /etc/pacman.conf
## See the pacman.conf(5) manpage for option and repository directives
## GENERAL OPTIONS
[options]
## The following paths are commented out with their default values listed.
## If you wish to use different paths, uncomment and update the paths.
##RootDir     = /
##DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
##LogFile     = /var/log/pacman.log
##GPGDir      = /etc/pacman.d/gnupg/
##HookDir     = /etc/pacman.d/hooks/
HoldPkg      = pacman glibc manjaro-system
## If upgrades are available for these packages they will be asked for first
SyncFirst    = manjaro-system archlinux-keyring manjaro-keyring
##XferCommand = /usr/bin/curl -C - -f %u > %o
##XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
##CleanMethod = KeepInstalled
##UseDelta    = 0.7
Architecture = auto
## Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
##IgnorePkg   =
##IgnoreGroup =
##NoUpgrade   =
##NoExtract   =
## Misc options
##UseSyslog
##Color
##TotalDownload
## We cannot check disk space from within a chroot environment
CheckSpace
##VerbosePkgLists
## By default, pacman accepts packages signed by keys that its local keyring
## trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
##RemoteFileSigLevel = Required
## NOTE: You must run `pacman-key --init` before first using pacman; the local
## keyring can then be populated with the keys of all official Manjaro Linux
## packagers with `pacman-key --populate archlinux manjaro`.
## REPOSITORIES
##   - can be defined here or included from another file
##   - pacman will search repositories in the order defined here
##   - local/custom mirrors can be added here or in separate files
##   - repositories listed first will take precedence when packages
##     have identical names, regardless of version number
##   - URLs will have $repo replaced by the name of the current repo
##   - URLs will have $arch replaced by the name of the architecture
## Repository entries are of the format:
##       [repo-name]
##       Server = ServerName
##       Include = IncludePath
## The header [repo-name] is crucial - it must be present and
## uncommented to enable the repo.
## The testing repositories are disabled by default. To enable, uncomment the
## repo name header and Include lines. You can add preferred servers immediately
## after the header, and they will be used before the default mirrors.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
## If you want to run 32 bit applications on your x86_64 system,
## enable the multilib repositories as required here.
[multilib]
## An example of a custom package repository.  See the pacman manpage for
## tips on creating your own repositories.
##[custom]
##SigLevel = Optional TrustAll
##Server = file:///home/custompkgs
cat /etc/pacman-mirrors.conf
## /etc/pacman-mirrors.conf
## Branch Pacman should use (stable, testing, unstable)
Branch = x32-stable
## Generation method
## 1) rank   - rank mirrors depending on their access time
## 2) random - randomly generate the output mirrorlist
# Method = rank
## Define protocols and priority
##   separated by comma 'https,http' or 'http,https'
## ATM available protocols are: http, https, ftp
## Not specifying a protocol will ban the protocol from being used
## If a mirror has more than one protocol defined only the first is written to the mirrorlist
## Empty means all in reversed alphabetic order
# Protocols =
## When set to False - all certificates are accepted.
## Use only if you fully trust all ssl-enabled mirrors.
# SSLVerify = True
cat /etc/pacman.d/mirrorlist
## Arch Linux repository mirrorlist
## Generated on 2020-05-11
## Worldwide
#Server = http://mirrors.evowise.com/archlinux/$repo/os/$arch
#Server = http://mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = https://mirror.rackspace.com/archlinux/$repo/os/$arch
## Australia
#Server = https://mirror.aarnet.edu.au/pub/archlinux/$repo/os/$arch
#Server = http://archlinux.mirror.digitalpacific.com.au/$repo/os/$arch
#Server = https://archlinux.mirror.digitalpacific.com.au/$repo/os/$arch
#Server = http://ftp.iinet.net.au/pub/archlinux/$repo/os/$arch
#Server = http://mirror.internode.on.net/pub/archlinux/$repo/os/$arch
#Server = http://archlinux.melbourneitmirror.net/$repo/os/$arch
#Server = http://syd.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = https://syd.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = http://ftp.swin.edu.au/archlinux/$repo/os/$arch
## Austria
#Server = http://mirror.digitalnova.at/archlinux/$repo/os/$arch
#Server = http://mirror.easyname.at/archlinux/$repo/os/$arch
#Server = http://mirror.reisenbauer.ee/archlinux/$repo/os/$arch
#Server = https://mirror.reisenbauer.ee/archlinux/$repo/os/$arch
## Bangladesh
#Server = http://mirror.xeonbd.com/archlinux/$repo/os/$arch
## Belarus
#Server = http://ftp.byfly.by/pub/archlinux/$repo/os/$arch
#Server = http://mirror.datacenter.by/pub/archlinux/$repo/os/$arch
## Belgium
#Server = http://archlinux.cu.be/$repo/os/$arch
#Server = http://archlinux.mirror.kangaroot.net/$repo/os/$arch
#Server = http://mirror.tiguinet.net/arch/$repo/os/$arch
## Bosnia and Herzegovina
#Server = http://archlinux.mirror.ba/$repo/os/$arch
## Brazil
#Server = http://br.mirror.archlinux-br.org/$repo/os/$arch
#Server = http://archlinux.c3sl.ufpr.br/$repo/os/$arch
#Server = http://www.caco.ic.unicamp.br/archlinux/$repo/os/$arch
#Server = https://www.caco.ic.unicamp.br/archlinux/$repo/os/$arch
#Server = http://linorg.usp.br/archlinux/$repo/os/$arch
#Server = http://archlinux.pop-es.rnp.br/$repo/os/$arch
#Server = http://mirror.ufam.edu.br/archlinux/$repo/os/$arch
#Server = http://mirror.ufscar.br/archlinux/$repo/os/$arch
## Bulgaria
#Server = http://mirror.host.ag/archlinux/$repo/os/$arch
#Server = http://mirrors.netix.net/archlinux/$repo/os/$arch
#Server = http://mirrors.uni-plovdiv.net/archlinux/$repo/os/$arch
#Server = https://mirrors.uni-plovdiv.net/archlinux/$repo/os/$arch
## Canada
#Server = http://mirror.cedille.club/archlinux/$repo/os/$arch
#Server = http://archlinux.mirror.colo-serv.net/$repo/os/$arch
#Server = http://mirror.csclub.uwaterloo.ca/archlinux/$repo/os/$arch
#Server = https://mirror.csclub.uwaterloo.ca/archlinux/$repo/os/$arch
#Server = http://mirror2.evolution-host.com/archlinux/$repo/os/$arch
#Server = https://mirror2.evolution-host.com/archlinux/$repo/os/$arch
#Server = http://mirror.its.dal.ca/archlinux/$repo/os/$arch
#Server = http://muug.ca/mirror/archlinux/$repo/os/$arch
#Server = https://muug.ca/mirror/archlinux/$repo/os/$arch
#Server = http://archlinux.mirror.rafal.ca/$repo/os/$arch
#Server = http://mirror.scd31.com/arch/$repo/os/$arch
#Server = https://mirror.scd31.com/arch/$repo/os/$arch
#Server = http://mirror.sergal.org/archlinux/$repo/os/$arch
#Server = https://mirror.sergal.org/archlinux/$repo/os/$arch
## Chile
#Server = http://mirror.archlinux.cl/$repo/os/$arch
#Server = http://mirror.ufro.cl/archlinux/$repo/os/$arch
#Server = https://mirror.ufro.cl/archlinux/$repo/os/$arch
## China
#Server = http://mirrors.163.com/archlinux/$repo/os/$arch
#Server = http://mirrors.cqu.edu.cn/archlinux/$repo/os/$arch
#Server = https://mirrors.cqu.edu.cn/archlinux/$repo/os/$arch
#Server = http://mirrors.dgut.edu.cn/archlinux/$repo/os/$arch
#Server = https://mirrors.dgut.edu.cn/archlinux/$repo/os/$arch
#Server = http://mirror.lzu.edu.cn/archlinux/$repo/os/$arch
#Server = http://mirrors.neusoft.edu.cn/archlinux/$repo/os/$arch
#Server = https://mirrors.neusoft.edu.cn/archlinux/$repo/os/$arch
#Server = http://mirror.redrock.team/archlinux/$repo/os/$arch
#Server = https://mirror.redrock.team/archlinux/$repo/os/$arch
#Server = https://mirrors.sjtug.sjtu.edu.cn/archlinux/$repo/os/$arch
#Server = http://mirrors.tuna.tsinghua.edu.cn/archlinux/$repo/os/$arch
#Server = https://mirrors.tuna.tsinghua.edu.cn/archlinux/$repo/os/$arch
#Server = http://mirrors.ustc.edu.cn/archlinux/$repo/os/$arch
#Server = https://mirrors.ustc.edu.cn/archlinux/$repo/os/$arch
#Server = https://mirrors.xjtu.edu.cn/archlinux/$repo/os/$arch
#Server = http://mirrors.zju.edu.cn/archlinux/$repo/os/$arch
## Colombia
#Server = http://mirrors.udenar.edu.co/archlinux/$repo/os/$arch
## Croatia
#Server = http://archlinux.iskon.hr/$repo/os/$arch
## Czechia
#Server = http://mirror.dkm.cz/archlinux/$repo/os/$arch
#Server = https://mirror.dkm.cz/archlinux/$repo/os/$arch
#Server = http://ftp.fi.muni.cz/pub/linux/arch/$repo/os/$arch
#Server = http://ftp.linux.cz/pub/linux/arch/$repo/os/$arch
#Server = http://gluttony.sin.cvut.cz/arch/$repo/os/$arch
#Server = https://gluttony.sin.cvut.cz/arch/$repo/os/$arch
#Server = http://mirrors.nic.cz/archlinux/$repo/os/$arch
#Server = http://ftp.sh.cvut.cz/arch/$repo/os/$arch
#Server = https://ftp.sh.cvut.cz/arch/$repo/os/$arch
#Server = http://mirror.vpsfree.cz/archlinux/$repo/os/$arch
## Denmark
#Server = http://mirrors.dotsrc.org/archlinux/$repo/os/$arch
#Server = https://mirrors.dotsrc.org/archlinux/$repo/os/$arch
#Server = http://mirror.one.com/archlinux/$repo/os/$arch
#Server = https://mirror.one.com/archlinux/$repo/os/$arch
## Ecuador
#Server = http://mirror.cedia.org.ec/archlinux/$repo/os/$arch
#Server = http://mirror.espoch.edu.ec/archlinux/$repo/os/$arch
#Server = http://mirror.uta.edu.ec/archlinux/$repo/os/$arch
## Finland
#Server = http://arch.mirror.far.fi/$repo/os/$arch
#Server = http://mirror.pseudoform.org/$repo/os/$arch
#Server = https://mirror.pseudoform.org/$repo/os/$arch
#Server = https://mirror.srv.fail/archlinux/$repo/os/$arch
#Server = http://mirror.wuki.li/archlinux/$repo/os/$arch
#Server = https://mirror.wuki.li/archlinux/$repo/os/$arch
## France
#Server = http://archlinux.de-labrusse.fr/$repo/os/$arch
#Server = http://mirror.archlinux.ikoula.com/archlinux/$repo/os/$arch
#Server = http://archlinux.vi-di.fr/$repo/os/$arch
#Server = http://mirrors.arnoldthebat.co.uk/archlinux/$repo/os/$arch
#Server = https://mirrors.arnoldthebat.co.uk/archlinux/$repo/os/$arch
#Server = http://archlinux.mirrors.benatherton.com/$repo/os/$arch
#Server = http://mirror.cyberbits.eu/archlinux/$repo/os/$arch
#Server = https://mirror.cyberbits.eu/archlinux/$repo/os/$arch
#Server = https://mirrors.eric.ovh/arch/$repo/os/$arch
#Server = http://mirror.ibcp.fr/pub/archlinux/$repo/os/$arch
#Server = http://mirror.lastmikoi.net/archlinux/$repo/os/$arch
#Server = https://arch-mirror.cloud.louifox.house/$repo/os/$arch
#Server = http://archlinux.mailtunnel.eu/$repo/os/$arch
#Server = https://archlinux.mailtunnel.eu/$repo/os/$arch
#Server = http://mir.archlinux.fr/$repo/os/$arch
#Server = http://mirrors.celianvdb.fr/archlinux/$repo/os/$arch
#Server = https://mirrors.celianvdb.fr/archlinux/$repo/os/$arch
#Server = http://arch.nimukaito.net/$repo/os/$arch
#Server = https://arch.nimukaito.net/$repo/os/$arch
#Server = http://mirror.oldsql.cc/archlinux/$repo/os/$arch
#Server = https://mirror.oldsql.cc/archlinux/$repo/os/$arch
#Server = http://archlinux.mirrors.ovh.net/archlinux/$repo/os/$arch
#Server = http://archlinux.polymorf.fr/$repo/os/$arch
#Server = http://archlinux.rezopole.net/$repo/os/$arch
#Server = http://mirrors.standaloneinstaller.com/archlinux/$repo/os/$arch
#Server = https://mirror.sysa.tech/archlinux/$repo/os/$arch
#Server = https://mirror.thekinrar.fr/archlinux/$repo/os/$arch
#Server = http://ftp.u-strasbg.fr/linux/distributions/archlinux/$repo/os/$arch
#Server = https://mirror.wormhole.eu/archlinux/$repo/os/$arch
#Server = http://arch.yourlabs.org/$repo/os/$arch
#Server = https://arch.yourlabs.org/$repo/os/$arch
## Georgia
#Server = http://archlinux.grena.ge/$repo/os/$arch
#Server = https://archlinux.grena.ge/$repo/os/$arch
## Germany
#Server = http://mirror.23media.com/archlinux/$repo/os/$arch
#Server = https://mirror.23media.com/archlinux/$repo/os/$arch
#Server = https://appuals.com/archlinux/$repo/os/$arch
#Server = http://artfiles.org/archlinux.org/$repo/os/$arch
#Server = https://mirror.bethselamin.de/$repo/os/$arch
#Server = http://mirror.chaoticum.net/arch/$repo/os/$arch
#Server = https://mirror.chaoticum.net/arch/$repo/os/$arch
#Server = http://mirror.checkdomain.de/archlinux/$repo/os/$arch
#Server = https://mirror.checkdomain.de/archlinux/$repo/os/$arch
#Server = http://arch.eckner.net/archlinux/$repo/os/$arch
#Server = https://arch.eckner.net/archlinux/$repo/os/$arch
#Server = http://mirror.f4st.host/archlinux/$repo/os/$arch
#Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
#Server = http://ftp.fau.de/archlinux/$repo/os/$arch
#Server = https://ftp.fau.de/archlinux/$repo/os/$arch
#Server = https://dist-mirror.fem.tu-ilmenau.de/archlinux/$repo/os/$arch
#Server = https://mirror.gnomus.de/$repo/os/$arch
#Server = http://www.gutscheindrache.com/mirror/archlinux/$repo/os/$arch
#Server = http://ftp.gwdg.de/pub/linux/archlinux/$repo/os/$arch
#Server = http://archlinux.honkgong.info/$repo/os/$arch
#Server = http://ftp.hosteurope.de/mirror/ftp.archlinux.org/$repo/os/$arch
#Server = http://ftp-stud.hs-esslingen.de/pub/Mirrors/archlinux/$repo/os/$arch
#Server = http://archlinux.mirror.iphh.net/$repo/os/$arch
#Server = http://arch.jensgutermuth.de/$repo/os/$arch
#Server = https://arch.jensgutermuth.de/$repo/os/$arch
#Server = http://mirror.fra10.de.leaseweb.net/archlinux/$repo/os/$arch
#Server = https://mirror.fra10.de.leaseweb.net/archlinux/$repo/os/$arch
#Server = http://mirror.metalgamer.eu/archlinux/$repo/os/$arch
#Server = https://mirror.metalgamer.eu/archlinux/$repo/os/$arch
#Server = http://mirror.mikrogravitation.org/archlinux/$repo/os/$arch
#Server = https://mirror.mikrogravitation.org/archlinux/$repo/os/$arch
#Server = https://ger.mirror.pkgbuild.com/$repo/os/$arch
#Server = https://mirror.pkgbuild.com/$repo/os/$arch
#Server = http://mirrors.n-ix.net/archlinux/$repo/os/$arch
#Server = https://mirrors.n-ix.net/archlinux/$repo/os/$arch
#Server = http://mirror.netcologne.de/archlinux/$repo/os/$arch
#Server = https://mirror.netcologne.de/archlinux/$repo/os/$arch
#Server = http://mirrors.niyawe.de/archlinux/$repo/os/$arch
#Server = https://mirrors.niyawe.de/archlinux/$repo/os/$arch
#Server = http://mirror.orbit-os.com/archlinux/$repo/os/$arch
#Server = https://mirror.orbit-os.com/archlinux/$repo/os/$arch
#Server = http://packages.oth-regensburg.de/archlinux/$repo/os/$arch
#Server = https://packages.oth-regensburg.de/archlinux/$repo/os/$arch
#Server = https://www.ratenzahlung.de/mirror/archlinux/$repo/os/$arch
#Server = http://ftp.halifax.rwth-aachen.de/archlinux/$repo/os/$arch
#Server = https://ftp.halifax.rwth-aachen.de/archlinux/$repo/os/$arch
#Server = http://linux.rz.rub.de/archlinux/$repo/os/$arch
#Server = http://mirror.selfnet.de/archlinux/$repo/os/$arch
#Server = https://mirror.selfnet.de/archlinux/$repo/os/$arch
#Server = http://ftp.spline.inf.fu-berlin.de/mirrors/archlinux/$repo/os/$arch
#Server = https://ftp.spline.inf.fu-berlin.de/mirrors/archlinux/$repo/os/$arch
#Server = http://archlinux.thaller.ws/$repo/os/$arch
#Server = https://archlinux.thaller.ws/$repo/os/$arch
#Server = http://ftp.tu-chemnitz.de/pub/linux/archlinux/$repo/os/$arch
#Server = http://mirror.ubrco.de/archlinux/$repo/os/$arch
#Server = https://mirror.ubrco.de/archlinux/$repo/os/$arch
#Server = http://mirror.undisclose.de/archlinux/$repo/os/$arch
#Server = https://mirror.undisclose.de/archlinux/$repo/os/$arch
#Server = http://ftp.uni-bayreuth.de/linux/archlinux/$repo/os/$arch
#Server = http://ftp.uni-hannover.de/archlinux/$repo/os/$arch
#Server = http://ftp.uni-kl.de/pub/linux/archlinux/$repo/os/$arch
#Server = http://mirror.united-gameserver.de/archlinux/$repo/os/$arch
#Server = https://arch.unixpeople.org/$repo/os/$arch
#Server = http://ftp.wrz.de/pub/archlinux/$repo/os/$arch
#Server = https://ftp.wrz.de/pub/archlinux/$repo/os/$arch
#Server = http://mirror.wtnet.de/arch/$repo/os/$arch
#Server = https://mirror.wtnet.de/arch/$repo/os/$arch
## Greece
#Server = http://ftp.cc.uoc.gr/mirrors/linux/archlinux/$repo/os/$arch
#Server = http://mirrors.myaegean.gr/linux/archlinux/$repo/os/$arch
#Server = http://ftp.ntua.gr/pub/linux/archlinux/$repo/os/$arch
#Server = http://ftp.otenet.gr/linux/archlinux/$repo/os/$arch
## Hong Kong
#Server = http://mirror-hk.koddos.net/archlinux/$repo/os/$arch
#Server = https://mirror-hk.koddos.net/archlinux/$repo/os/$arch
#Server = http://hkg.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = https://hkg.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = https://arch-mirror.wtako.net/$repo/os/$arch
#Server = http://mirror.xtom.com.hk/archlinux/$repo/os/$arch
#Server = https://mirror.xtom.com.hk/archlinux/$repo/os/$arch
## Hungary
#Server = http://ftp.energia.mta.hu/pub/mirrors/ftp.archlinux.org/$repo/os/$arch
#Server = http://archmirror.hbit.sztaki.hu/archlinux/$repo/os/$arch
#Server = http://nova.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
#Server = http://quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
#Server = http://super.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
#Server = https://nova.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
#Server = https://quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
#Server = https://super.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
## Iceland
#Server = http://mirror.system.is/arch/$repo/os/$arch
#Server = https://mirror.system.is/arch/$repo/os/$arch
## India
#Server = http://mirror.cse.iitk.ac.in/archlinux/$repo/os/$arch
#Server = https://ind.mirror.pkgbuild.com/$repo/os/$arch
#Server = http://mirrors.piconets.webwerks.in/archlinux-mirror/$repo/os/$arch
#Server = https://mirrors.piconets.webwerks.in/archlinux-mirror/$repo/os/$arch
## Indonesia
#Server = http://mirror.labkom.id/archlinux/$repo/os/$arch
#Server = http://mirror.poliwangi.ac.id/archlinux/$repo/os/$arch
#Server = http://suro.ubaya.ac.id/archlinux/$repo/os/$arch
#Server = http://mirror.telkomuniversity.ac.id/archlinux/$repo/os/$arch
#Server = https://mirror.telkomuniversity.ac.id/archlinux/$repo/os/$arch
## Iran
#Server = http://repo.iut.ac.ir/repo/archlinux/$repo/os/$arch
#Server = http://mirrors.mirjamali.ir/archlinux/$repo/os/$arch
#Server = https://mirrors.mirjamali.ir/archlinux/$repo/os/$arch
#Server = http://mirror.nak-mci.ir/arch/$repo/os/$arch
#Server = http://mirror.rasanegar.com/archlinux/$repo/os/$arch
#Server = https://mirror.rasanegar.com/archlinux/$repo/os/$arch
## Ireland
#Server = http://ftp.heanet.ie/mirrors/ftp.archlinux.org/$repo/os/$arch
#Server = https://ftp.heanet.ie/mirrors/ftp.archlinux.org/$repo/os/$arch
## Israel
#Server = http://mirror.isoc.org.il/pub/archlinux/$repo/os/$arch
#Server = https://archlinux.mivzakim.net/$repo/os/$arch
## Italy
#Server = https://archlinux.beccacervello.it/archlinux/$repo/os/$arch
#Server = http://archlinux.mirror.garr.it/archlinux/$repo/os/$arch
#Server = http://mirrors.prometeus.net/archlinux/$repo/os/$arch
## Japan
#Server = http://mirrors.cat.net/archlinux/$repo/os/$arch
#Server = https://mirrors.cat.net/archlinux/$repo/os/$arch
#Server = http://ftp.tsukuba.wide.ad.jp/Linux/archlinux/$repo/os/$arch
#Server = http://ftp.jaist.ac.jp/pub/Linux/ArchLinux/$repo/os/$arch
#Server = https://ftp.jaist.ac.jp/pub/Linux/ArchLinux/$repo/os/$arch
#Server = https://jpn.mirror.pkgbuild.com/$repo/os/$arch
## Kazakhstan
#Server = http://mirror.ps.kz/archlinux/$repo/os/$arch
#Server = https://mirror.ps.kz/archlinux/$repo/os/$arch
## Kenya
#Server = http://archlinux.mirror.liquidtelecom.com/$repo/os/$arch
#Server = https://archlinux.mirror.liquidtelecom.com/$repo/os/$arch
## Latvia
#Server = http://archlinux.koyanet.lv/archlinux/$repo/os/$arch
## Lithuania
#Server = http://mirrors.atviras.lt/archlinux/$repo/os/$arch
#Server = https://mirrors.atviras.lt/archlinux/$repo/os/$arch
#Server = http://mirrors.ims.nksc.lt/archlinux/$repo/os/$arch
#Server = https://mirrors.ims.nksc.lt/archlinux/$repo/os/$arch
## Luxembourg
#Server = http://archlinux.mirror.root.lu/$repo/os/$arch
## Netherlands
#Server = http://mirror.i3d.net/pub/archlinux/$repo/os/$arch
#Server = https://mirror.i3d.net/pub/archlinux/$repo/os/$arch
#Server = http://mirror.koddos.net/archlinux/$repo/os/$arch
#Server = https://mirror.koddos.net/archlinux/$repo/os/$arch
#Server = http://arch.mirrors.lavatech.top/$repo/os/$arch
#Server = https://arch.mirrors.lavatech.top/$repo/os/$arch
#Server = http://mirror.ams1.nl.leaseweb.net/archlinux/$repo/os/$arch
#Server = https://mirror.ams1.nl.leaseweb.net/archlinux/$repo/os/$arch
#Server = http://archlinux.mirror.liteserver.nl/$repo/os/$arch
#Server = https://archlinux.mirror.liteserver.nl/$repo/os/$arch
#Server = http://mirror.mijn.host/archlinux/$repo/os/$arch
#Server = https://mirror.mijn.host/archlinux/$repo/os/$arch
#Server = http://mirror.neostrada.nl/archlinux/$repo/os/$arch
#Server = https://mirror.neostrada.nl/archlinux/$repo/os/$arch
#Server = http://ftp.nluug.nl/os/Linux/distr/archlinux/$repo/os/$arch
#Server = http://archlinux.mirror.pcextreme.nl/$repo/os/$arch
#Server = https://archlinux.mirror.pcextreme.nl/$repo/os/$arch
#Server = http://mirror.serverion.com/archlinux/$repo/os/$arch
#Server = https://mirror.serverion.com/archlinux/$repo/os/$arch
#Server = http://ftp.snt.utwente.nl/pub/os/linux/archlinux/$repo/os/$arch
#Server = http://mirror.tarellia.net/distr/archlinux/$repo/os/$arch
#Server = https://mirror.tarellia.net/distr/archlinux/$repo/os/$arch
#Server = http://archlinux.mirror.wearetriple.com/$repo/os/$arch
#Server = https://archlinux.mirror.wearetriple.com/$repo/os/$arch
#Server = http://mirror-archlinux.webruimtehosting.nl/$repo/os/$arch
#Server = https://mirror-archlinux.webruimtehosting.nl/$repo/os/$arch
#Server = http://mirrors.xtom.nl/archlinux/$repo/os/$arch
#Server = https://mirrors.xtom.nl/archlinux/$repo/os/$arch
## New Caledonia
#Server = http://mirror.lagoon.nc/pub/archlinux/$repo/os/$arch
#Server = http://archlinux.nautile.nc/archlinux/$repo/os/$arch
#Server = https://archlinux.nautile.nc/archlinux/$repo/os/$arch
## New Zealand
#Server = http://mirror.fsmg.org.nz/archlinux/$repo/os/$arch
#Server = https://mirror.fsmg.org.nz/archlinux/$repo/os/$arch
#Server = http://mirror.smith.geek.nz/archlinux/$repo/os/$arch
#Server = https://mirror.smith.geek.nz/archlinux/$repo/os/$arch
## North Macedonia
#Server = http://arch.softver.org.mk/archlinux/$repo/os/$arch
#Server = http://mirror.onevip.mk/archlinux/$repo/os/$arch
#Server = http://mirror.t-home.mk/archlinux/$repo/os/$arch
#Server = https://mirror.t-home.mk/archlinux/$repo/os/$arch
## Norway
#Server = http://mirror.archlinux.no/$repo/os/$arch
#Server = http://archlinux.uib.no/$repo/os/$arch
#Server = http://mirror.neuf.no/archlinux/$repo/os/$arch
#Server = https://mirror.neuf.no/archlinux/$repo/os/$arch
#Server = http://mirror.terrahost.no/linux/archlinux/$repo/os/$arch
## Paraguay
#Server = http://archlinux.mirror.py/archlinux/$repo/os/$arch
## Philippines
#Server = http://mirror.rise.ph/archlinux/$repo/os/$arch
## Poland
#Server = http://ftp.icm.edu.pl/pub/Linux/dist/archlinux/$repo/os/$arch
#Server = https://ftp.icm.edu.pl/pub/Linux/dist/archlinux/$repo/os/$arch
#Server = http://arch.midov.pl/arch/$repo/os/$arch
#Server = http://arch.nixlab.pl/$repo/os/$arch
#Server = https://arch.nixlab.pl/$repo/os/$arch
#Server = http://mirror.onet.pl/pub/mirrors/archlinux/$repo/os/$arch
#Server = http://piotrkosoft.net/pub/mirrors/ftp.archlinux.org/$repo/os/$arch
#Server = http://ftp.vectranet.pl/archlinux/$repo/os/$arch
## Portugal
#Server = http://glua.ua.pt/pub/archlinux/$repo/os/$arch
#Server = https://glua.ua.pt/pub/archlinux/$repo/os/$arch
#Server = http://ftp.rnl.tecnico.ulisboa.pt/pub/archlinux/$repo/os/$arch
#Server = https://ftp.rnl.tecnico.ulisboa.pt/pub/archlinux/$repo/os/$arch
## Romania
#Server = http://mirrors.chroot.ro/archlinux/$repo/os/$arch
#Server = https://mirrors.chroot.ro/archlinux/$repo/os/$arch
#Server = http://mirror.efect.ro/archlinux/$repo/os/$arch
#Server = https://mirror.efect.ro/archlinux/$repo/os/$arch
#Server = http://archlinux.mirrors.linux.ro/$repo/os/$arch
#Server = http://mirrors.m247.ro/archlinux/$repo/os/$arch
#Server = http://mirrors.nav.ro/archlinux/$repo/os/$arch
#Server = http://mirrors.nxthost.com/archlinux/$repo/os/$arch
#Server = https://mirrors.nxthost.com/archlinux/$repo/os/$arch
#Server = http://mirrors.pidginhost.com/arch/$repo/os/$arch
#Server = https://mirrors.pidginhost.com/arch/$repo/os/$arch
## Russia
#Server = http://mirror.rol.ru/archlinux/$repo/os/$arch
#Server = https://mirror.rol.ru/archlinux/$repo/os/$arch
#Server = http://mirror.truenetwork.ru/archlinux/$repo/os/$arch
#Server = http://mirror.yandex.ru/archlinux/$repo/os/$arch
#Server = https://mirror.yandex.ru/archlinux/$repo/os/$arch
#Server = http://archlinux.zepto.cloud/$repo/os/$arch
## Serbia
#Server = http://arch.petarmaric.com/$repo/os/$arch
#Server = http://mirror.pmf.kg.ac.rs/archlinux/$repo/os/$arch
## Singapore
#Server = http://mirror.0x.sg/archlinux/$repo/os/$arch
#Server = https://mirror.0x.sg/archlinux/$repo/os/$arch
#Server = http://mirror.aktkn.sg/archlinux/$repo/os/$arch
#Server = https://mirror.aktkn.sg/archlinux/$repo/os/$arch
#Server = https://download.nus.edu.sg/mirror/archlinux/$repo/os/$arch
#Server = https://sgp.mirror.pkgbuild.com/$repo/os/$arch
#Server = http://mirror.nus.edu.sg/archlinux/$repo/os/$arch
## Slovakia
#Server = http://mirror.lnx.sk/pub/linux/archlinux/$repo/os/$arch
#Server = https://mirror.lnx.sk/pub/linux/archlinux/$repo/os/$arch
#Server = http://tux.rainside.sk/archlinux/$repo/os/$arch
## Slovenia
#Server = http://archimonde.ts.si/archlinux/$repo/os/$arch
#Server = https://archimonde.ts.si/archlinux/$repo/os/$arch
## South Africa
#Server = http://archlinux.za.mirror.allworldit.com/archlinux/$repo/os/$arch
#Server = https://archlinux.za.mirror.allworldit.com/archlinux/$repo/os/$arch
#Server = http://za.mirror.archlinux-br.org/$repo/os/$arch
#Server = http://mirror.is.co.za/mirror/archlinux.org/$repo/os/$arch
#Server = http://mirrors.urbanwave.co.za/archlinux/$repo/os/$arch
#Server = https://mirrors.urbanwave.co.za/archlinux/$repo/os/$arch
## South Korea
#Server = http://ftp.harukasan.org/archlinux/$repo/os/$arch
#Server = https://ftp.harukasan.org/archlinux/$repo/os/$arch
#Server = http://ftp.lanet.kr/pub/archlinux/$repo/os/$arch
#Server = https://ftp.lanet.kr/pub/archlinux/$repo/os/$arch
#Server = http://mirror.premi.st/archlinux/$repo/os/$arch
## Spain
#Server = https://mirror.cloroformo.org/archlinux/$repo/os/$arch
#Server = http://mirror.librelabucm.org/archlinux/$repo/os/$arch
#Server = https://mirror.librelabucm.org/archlinux/$repo/os/$arch
#Server = https://osl.ugr.es/archlinux/$repo/os/$arch
#Server = http://ftp.rediris.es/mirror/archlinux/$repo/os/$arch
#Server = http://sharing.thelinuxsect.com/archlinux/$repo/os/$arch
## Sweden
#Server = http://ftp.acc.umu.se/mirror/archlinux/$repo/os/$arch
#Server = https://ftp.acc.umu.se/mirror/archlinux/$repo/os/$arch
#Server = http://archlinux.dynamict.se/$repo/os/$arch
#Server = https://archlinux.dynamict.se/$repo/os/$arch
#Server = http://ftpmirror.infania.net/mirror/archlinux/$repo/os/$arch
#Server = http://ftp.lysator.liu.se/pub/archlinux/$repo/os/$arch
#Server = https://ftp.lysator.liu.se/pub/archlinux/$repo/os/$arch
#Server = http://ftp.myrveln.se/pub/linux/archlinux/$repo/os/$arch
#Server = https://ftp.myrveln.se/pub/linux/archlinux/$repo/os/$arch
#Server = https://mirror.osbeck.com/archlinux/$repo/os/$arch
## Switzerland
#Server = http://pkg.adfinis-sygroup.ch/archlinux/$repo/os/$arch
#Server = https://pkg.adfinis-sygroup.ch/archlinux/$repo/os/$arch
#Server = http://mirror.init7.net/archlinux/$repo/os/$arch
#Server = https://mirror.init7.net/archlinux/$repo/os/$arch
#Server = http://mirror.puzzle.ch/archlinux/$repo/os/$arch
#Server = https://mirror.puzzle.ch/archlinux/$repo/os/$arch
#Server = https://mirror.ungleich.ch/mirror/packages/archlinux/$repo/os/$arch
## Taiwan
#Server = http://archlinux.cs.nctu.edu.tw/$repo/os/$arch
#Server = http://shadow.ind.ntou.edu.tw/archlinux/$repo/os/$arch
#Server = https://shadow.ind.ntou.edu.tw/archlinux/$repo/os/$arch
#Server = http://ftp.tku.edu.tw/Linux/ArchLinux/$repo/os/$arch
#Server = http://ftp.yzu.edu.tw/Linux/archlinux/$repo/os/$arch
#Server = https://ftp.yzu.edu.tw/Linux/archlinux/$repo/os/$arch
## Thailand
#Server = http://mirror.kku.ac.th/archlinux/$repo/os/$arch
#Server = https://mirror.kku.ac.th/archlinux/$repo/os/$arch
#Server = http://mirror2.totbb.net/archlinux/$repo/os/$arch
## Turkey
#Server = http://ftp.linux.org.tr/archlinux/$repo/os/$arch
#Server = http://mirror.veriteknik.net.tr/archlinux/$repo/os/$arch
## Ukraine
#Server = http://archlinux.ip-connect.vn.ua/$repo/os/$arch
#Server = https://archlinux.ip-connect.vn.ua/$repo/os/$arch
#Server = http://mirror.mirohost.net/archlinux/$repo/os/$arch
#Server = https://mirror.mirohost.net/archlinux/$repo/os/$arch
#Server = http://mirrors.nix.org.ua/linux/archlinux/$repo/os/$arch
#Server = https://mirrors.nix.org.ua/linux/archlinux/$repo/os/$arch
## United Kingdom
#Server = http://archlinux.uk.mirror.allworldit.com/archlinux/$repo/os/$arch
#Server = https://archlinux.uk.mirror.allworldit.com/archlinux/$repo/os/$arch
#Server = http://mirror.bytemark.co.uk/archlinux/$repo/os/$arch
#Server = https://mirror.bytemark.co.uk/archlinux/$repo/os/$arch
#Server = http://mirrors.manchester.m247.com/arch-linux/$repo/os/$arch
#Server = http://mirrors.melbourne.co.uk/archlinux/$repo/os/$arch
#Server = https://mirrors.melbourne.co.uk/archlinux/$repo/os/$arch
#Server = http://www.mirrorservice.org/sites/ftp.archlinux.org/$repo/os/$arch
#Server = https://www.mirrorservice.org/sites/ftp.archlinux.org/$repo/os/$arch
#Server = http://mirror.netweaver.uk/archlinux/$repo/os/$arch
#Server = https://mirror.netweaver.uk/archlinux/$repo/os/$arch
#Server = http://lon.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = https://lon.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = http://arch.serverspace.co.uk/arch/$repo/os/$arch
#Server = http://archlinux.mirrors.uk2.net/$repo/os/$arch
#Server = http://mirrors.ukfast.co.uk/sites/archlinux.org/$repo/os/$arch
#Server = https://mirrors.ukfast.co.uk/sites/archlinux.org/$repo/os/$arch
## United States
#Server = http://mirrors.acm.wpi.edu/archlinux/$repo/os/$arch
#Server = http://mirrors.advancedhosters.com/archlinux/$repo/os/$arch
#Server = http://mirrors.aggregate.org/archlinux/$repo/os/$arch
#Server = http://ca.us.mirror.archlinux-br.org/$repo/os/$arch
#Server = http://il.us.mirror.archlinux-br.org/$repo/os/$arch
#Server = http://archlinux.surlyjake.com/archlinux/$repo/os/$arch
#Server = https://archlinux.surlyjake.com/archlinux/$repo/os/$arch
#Server = http://mirror.arizona.edu/archlinux/$repo/os/$arch
#Server = https://mirror.arizona.edu/archlinux/$repo/os/$arch
#Server = http://arlm.tyzoid.com/$repo/os/$arch
#Server = https://arlm.tyzoid.com/$repo/os/$arch
#Server = http://mirror.cc.columbia.edu/pub/linux/archlinux/$repo/os/$arch
#Server = http://arch.mirror.constant.com/$repo/os/$arch
#Server = https://arch.mirror.constant.com/$repo/os/$arch
#Server = http://mirror.cs.pitt.edu/archlinux/$repo/os/$arch
#Server = http://mirror.cs.vt.edu/pub/ArchLinux/$repo/os/$arch
#Server = http://distro.ibiblio.org/archlinux/$repo/os/$arch
#Server = http://mirror.es.its.nyu.edu/archlinux/$repo/os/$arch
#Server = http://mirrors.gigenet.com/archlinux/$repo/os/$arch
#Server = http://www.gtlib.gatech.edu/pub/archlinux/$repo/os/$arch
#Server = http://mirror.dc02.hackingand.coffee/arch/$repo/os/$arch
#Server = https://mirror.dc02.hackingand.coffee/arch/$repo/os/$arch
#Server = http://arch.hu.fo/archlinux/$repo/os/$arch
#Server = https://arch.hu.fo/archlinux/$repo/os/$arch
#Server = http://repo.ialab.dsu.edu/archlinux/$repo/os/$arch
#Server = https://repo.ialab.dsu.edu/archlinux/$repo/os/$arch
#Server = http://mirrors.kernel.org/archlinux/$repo/os/$arch
#Server = https://mirrors.kernel.org/archlinux/$repo/os/$arch
#Server = http://mirror.dal10.us.leaseweb.net/archlinux/$repo/os/$arch
#Server = http://mirror.mia11.us.leaseweb.net/archlinux/$repo/os/$arch
#Server = http://mirror.sfo12.us.leaseweb.net/archlinux/$repo/os/$arch
#Server = http://mirror.wdc1.us.leaseweb.net/archlinux/$repo/os/$arch
#Server = https://mirror.dal10.us.leaseweb.net/archlinux/$repo/os/$arch
#Server = https://mirror.mia11.us.leaseweb.net/archlinux/$repo/os/$arch
#Server = https://mirror.sfo12.us.leaseweb.net/archlinux/$repo/os/$arch
#Server = https://mirror.wdc1.us.leaseweb.net/archlinux/$repo/os/$arch
#Server = http://mirrors.liquidweb.com/archlinux/$repo/os/$arch
#Server = http://mirror.lty.me/archlinux/$repo/os/$arch
#Server = https://mirror.lty.me/archlinux/$repo/os/$arch
#Server = http://reflector.luehm.com/arch/$repo/os/$arch
#Server = https://reflector.luehm.com/arch/$repo/os/$arch
#Server = http://mirrors.lug.mtu.edu/archlinux/$repo/os/$arch
#Server = https://mirrors.lug.mtu.edu/archlinux/$repo/os/$arch
#Server = http://mirror.math.princeton.edu/pub/archlinux/$repo/os/$arch
#Server = http://mirror.metrocast.net/archlinux/$repo/os/$arch
#Server = http://mirror.kaminski.io/archlinux/$repo/os/$arch
#Server = https://mirror.kaminski.io/archlinux/$repo/os/$arch
#Server = http://iad.mirrors.misaka.one/archlinux/$repo/os/$arch
#Server = https://iad.mirrors.misaka.one/archlinux/$repo/os/$arch
#Server = http://repo.miserver.it.umich.edu/archlinux/$repo/os/$arch
#Server = http://mirrors.mit.edu/archlinux/$repo/os/$arch
#Server = https://mirrors.mit.edu/archlinux/$repo/os/$arch
#Server = http://mirrors.ocf.berkeley.edu/archlinux/$repo/os/$arch
#Server = https://mirrors.ocf.berkeley.edu/archlinux/$repo/os/$arch
#Server = http://archmirror1.octyl.net/$repo/os/$arch
#Server = https://archmirror1.octyl.net/$repo/os/$arch
#Server = http://ftp.osuosl.org/pub/archlinux/$repo/os/$arch
#Server = http://arch.mirrors.pair.com/$repo/os/$arch
#Server = http://dfw.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = http://iad.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = http://ord.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = https://dfw.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = https://iad.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = https://ord.mirror.rackspace.com/archlinux/$repo/os/$arch
#Server = http://plug-mirror.rcac.purdue.edu/archlinux/$repo/os/$arch
#Server = https://plug-mirror.rcac.purdue.edu/archlinux/$repo/os/$arch
#Server = http://mirrors.rit.edu/archlinux/$repo/os/$arch
#Server = https://mirrors.rit.edu/archlinux/$repo/os/$arch
#Server = https://arch.rrig.gs/$repo/os/$arch
#Server = http://mirrors.rutgers.edu/archlinux/$repo/os/$arch
#Server = https://mirrors.rutgers.edu/archlinux/$repo/os/$arch
#Server = http://mirror.siena.edu/archlinux/$repo/os/$arch
#Server = http://mirrors.sonic.net/archlinux/$repo/os/$arch
#Server = https://mirrors.sonic.net/archlinux/$repo/os/$arch
#Server = http://arch.mirror.square-r00t.net/$repo/os/$arch
#Server = https://arch.mirror.square-r00t.net/$repo/os/$arch
#Server = http://mirror.stephen304.com/archlinux/$repo/os/$arch
#Server = https://mirror.stephen304.com/archlinux/$repo/os/$arch
#Server = http://mirror.pit.teraswitch.com/archlinux/$repo/os/$arch
#Server = https://mirror.pit.teraswitch.com/archlinux/$repo/os/$arch
#Server = http://mirror.umd.edu/archlinux/$repo/os/$arch
#Server = http://mirror.vtti.vt.edu/archlinux/$repo/os/$arch
#Server = http://mirrors.xmission.com/archlinux/$repo/os/$arch
#Server = http://mirrors.xtom.com/archlinux/$repo/os/$arch
#Server = https://mirrors.xtom.com/archlinux/$repo/os/$arch
## Vietnam
#Server = http://f.archlinuxvn.org/archlinux/$repo/os/$arch
Is this an x32 install?
yes it is, if i understand correctly. i should switch OS?
Yes, see here --> List of distributions for 32 bit x86 hardware [Wiki]
Thanks for the clarification!
