My ISP supplies “dual-stack” instead of “IPv6 nativ” - therefore no IPv6 adresses. Fact.
As repo.manjaro.org has only IPv4,
the command “pacman-mirrors” needs some minutes until it connects.
If I block IPv6 in Network-Preference - then its as fast as heaven/hell.
curl --ipv6 https://manjaro.moson.eu/pool/overlay/autogit-1.0-1-any.pkg.tar.zst --output testfile
limits connections to IPv6 Adresses for example. On my machine this fails (timeout).
Ahh Ich verstehe - but I think you are mixing concepts here.
If manjaro.moson.eu is in fact providing IPv6 address - an AAAA-record - and your curl command cannot translate the hostname into an IPv6 address then it is a configuration issue - but it is impossible to know if this is on your side or your ISP.
If you run pacman -Syy - what happens then? - that implies your primary mirror is manjaro.moson.eu.
Are you running a local DNS - bind or pihole - anything but the default ISP config for your router/modem?
EDIT.
I did a search for python and IPvX connection but I still think it is a configuration issue on your side.
yeah. repo.manjaro.org probably does not have an ipv6 address. This is not something pacman-mirrors can do anything about though…
And Manjaro does not control the mirrors, so there is no way to ensure that they have an ipv6 address either.
This doesnot work else with activated/deactivated “DHCPv6 Rapid Commit verwenden”.
And “Native IPv4-Anbindung verwenden” , with activated/deactivated “DHCPv6 Rapid Commit verwenden”.
kein Unterschied…
Die verbindung zu repo.manjaro.org dauert mit den vorgeschlagenen Einstellungen bis zu 5 Minuten,
wenn ich in Einstellungen/Netzwerk die IPv6 deaktiviere oder auf “Automatisch, nur DHCP” stelle,
kommt die Antwort “sofort”.
Wie ist das eigentlich: repo.manjaro.org hat nur eine IPv4 Adresse.
Sagt der Server mir Bescheid, das IPv6 nicht zu haben ist, oder macht er ein timeout von 2 Minuten
auf solch eine unverschämte Anfrage (hast du IPv6) und meldet dan Fehler, worauf mein PC
sich dazu herablässt, eine IPv4 Adresse zu verlangen?
How is that actually: repo.manjaro.org has only one IPv4 address.
Does the server tell me that IPv6 is not available or does it timeout for 2 minutes
on such an outrageous request (do you have IPv6) and then reports an error, what my PC
condescends to ask for an IPv4 address?
ip -6 route show default
default via fe80::464e:6dff:fe69:a22 dev enp6s0 proto ra metric 20100 pref medium
