Alright so Sublime strikes again. They post bad information for pgp keys on their site and it breaks pacman. I know this has been discussed before but the solution I have found didn’t work. I removed all references to Sublime in pacman.conf and ran # pacman -Scc && pacman-mirrors -f && pacman -Syyu only to still be getting:
:: Import PGP key 7A4E76095D8A52E4, “Antonio Rojas arojas@archlinux.org”? [Y/n] y error: key “7A4E76095D8A52E4” could not be imported error: required key missing from keyring error: failed to commit transaction (unexpected error) Errors occurred, no packages were upgraded.
Or perhaps I had already been though all that. But you are still right that it isn’t the third part repo. And it had been a entire day between updates so…
Regardless that isn’t the solution as this is new errors:
[mathew@Tuesday ~]$ sudo pacman -Syu
[sudo] password for mathew:
core is up to date
extra is up to date
community is up to date
multilib is up to date
there is nothing to do
[mathew@Tuesday ~]$ sudo pacman -S kdenlive
resolving dependencies...
Packages (6) frei0r-plugins-2.2.0-1 gavl-1.4.0-6 libebur128-1.2.6-1 mlt-7.12.0-2 qt5-networkauth-5.15.8-1 kdenlive-22.12.1-2
Total Installed Size: 89.92 MiB
:: Proceed with installation? [Y/n] y
(6/6) checking keys in keyring [##############################################################################################] 100%
downloading required keys...
:: Import PGP key 7A4E76095D8A52E4, "Antonio Rojas <arojas@archlinux.org>"? [Y/n] y
error: key "7A4E76095D8A52E4" could not be imported
[mathew@Tuesday ~]$ rm -rf /etc/pacman.d/gnupg
rm: cannot remove '/etc/pacman.d/gnupg/secring.gpg': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/trustdb.gpg': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/gpg.conf': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/gpg-agent.conf': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/private-keys-v1.d': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/.gpg-v21-migrated': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/openpgp-revocs.d': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/tofu.db': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/crls.d': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/pubring.gpg~': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/pubring.gpg': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/S.dirmngr': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/S.gpg-agent': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/S.gpg-agent.extra': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/S.gpg-agent.browser': Permission denied
rm: cannot remove '/etc/pacman.d/gnupg/S.gpg-agent.ssh': Permission denied
[mathew@Tuesday ~]$ sudo rm -rf /etc/pacman.d/gnupg
[mathew@Tuesday ~]$ sudo pacman -U https://mirror.easyname.at/manjaro/pool/sync/archlinux-keyring-20230130-1-any.pkg.tar.zst
:: Retrieving packages...
archlinux-keyring-20230130-1-any.pkg.tar.zst failed to download
error: failed retrieving file 'archlinux-keyring-20230130-1-any.pkg.tar.zst' from mirror.easyname.at : SSL connection timeout
warning: failed to retrieve some files
[mathew@Tuesday ~]$ sudo pacman -U https://mirror.easyname.at/manjaro/pool/overlay/manjaro-keyring-20221028-4-any.pkg.tar.xz
manjaro-keyring-20221028-4-any.pkg.tar.xz failed to download
error: failed retrieving file 'manjaro-keyring-20221028-4-any.pkg.tar.xz' from mirror.easyname.at : SSL connection timeout
[mathew@Tuesday ~]$ sudo rm -f /var/lib/pacman/sync/*
[mathew@Tuesday ~]$ sudo pacman -Syyu
core 163.5 KiB 244 KiB/s 00:01 [##############################################################################################] 100%
extra 1857.9 KiB 2004 KiB/s 00:01 [##############################################################################################] 100%
community 7.5 MiB 6.44 MiB/s 00:01 [##############################################################################################] 100%
multilib 169.4 KiB 255 KiB/s 00:01 [##############################################################################################] 100%
warning: Public keyring not found; have you run 'pacman-key --init'?
error: keyring is not writable
[mathew@Tuesday ~]$ sudo pacman-key --init
gpg: /etc/pacman.d/gnupg/trustdb.gpg: trustdb created
gpg: no ultimately trusted keys found
gpg: starting migration from earlier GnuPG versions
gpg: porting secret keys from '/etc/pacman.d/gnupg/secring.gpg' to gpg-agent
gpg: migration succeeded
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: directory '/etc/pacman.d/gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/D808E198C1F4E3D02F4634229A6FC8DB22E33AAD.rev'
gpg: Done
==> Updating trust database...
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 0 trust: 0-, 0q, 0n, 0m, 0f, 1u
:: Import PGP key F99FFE0FEAE999BD, "Allan McRae <allan@archlinux.org>"? [Y/n] y
(6/6) checking package integrity [##############################################################################################] 100%
error: qt5-networkauth: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/qt5-networkauth-5.15.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: libebur128: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/libebur128-1.2.6-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mlt: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/mlt-7.12.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: gavl: signature from "Allan McRae (Developer) <allan@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gavl-1.4.0-6-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: frei0r-plugins: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/frei0r-plugins-2.2.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: kdenlive: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/kdenlive-22.12.1-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package (PGP signature))
[mathew@Tuesday ~]$
