Module #1
Argument: {
nice.level = -11
rt.prio = 88
#rt.time.soft = -1
#rt.time.hard = -1
#uclamp.min = 0
#uclamp.max = 1024
Usage counter: n/a
Properties:
module.name = "libpipewire-module-rt"
object.id = "1"
object.serial = "1"
module.author = "Wim Taymans <wim.taymans@gmail.com>"
module.description = "Use realtime thread scheduling, falling back to RTKit"
module.usage = "( nice.level=<priority: default 20(don't change)> ) ( rt.prio=<priority: default 83> ) ( rt.time.soft=<in usec: default -1> ) ( rt.time.hard=<in usec: default -1> ) ( rlimits.enabled=<default true> ) ( rtportal.enabled=<default true> ) ( rtkit.enabled=<default true> ) ( uclamp.min=<default 0> ) ( uclamp.max=<default 1024> )"
module.version = "1.4.10"
nice.level = "-11"
rt.prio = "88"
Module #2
Argument: {
# List of server Unix sockets, and optionally permissions
#sockets = [ { name = "pipewire-0" }, { name = "pipewire-0-manager" } ]
Usage counter: n/a
Properties:
module.name = "libpipewire-module-protocol-native"
object.id = "2"
object.serial = "2"
module.description = "Native protocol using unix sockets"
Module #4
Argument: {
#profile.interval.ms = 0
Usage counter: n/a
Properties:
module.name = "libpipewire-module-profiler"
object.id = "4"
object.serial = "4"
module.description = "Generate Profiling data"
module.usage = "( profile.interval.ms=<minimum interval for sampling data (in ms) ) "
Module #6
Argument:
Usage counter: n/a
Properties:
module.name = "libpipewire-module-metadata"
object.id = "6"
object.serial = "6"
module.description = "Allow clients to create metadata store"
Module #8
Argument:
Usage counter: n/a
Properties:
module.name = "libpipewire-module-spa-device-factory"
object.id = "8"
object.serial = "8"
module.description = "Provide a factory to make SPA devices"
Module #10
Argument:
Usage counter: n/a
Properties:
module.name = "libpipewire-module-spa-node-factory"
object.id = "10"
object.serial = "10"
module.description = "Provide a factory to make SPA nodes"
Module #12
Argument:
Usage counter: n/a
Properties:
module.name = "libpipewire-module-client-node"
object.id = "12"
object.serial = "12"
module.description = "Allow clients to create and control remote nodes"
Module #14
Argument:
Usage counter: n/a
Properties:
module.name = "libpipewire-module-client-device"
object.id = "14"
object.serial = "14"
module.description = "Allow clients to create and control remote devices"
Module #16
Argument:
Usage counter: n/a
Properties:
module.name = "libpipewire-module-portal"
object.id = "16"
object.serial = "16"
Module #17
Argument: {
# Socket-specific access permissions
#access.socket = { pipewire-0 = "default", pipewire-0-manager = "unrestricted" }
# Deprecated legacy mode (not socket-based),
# for now enabled by default if access.socket is not specified
#access.legacy = true
Usage counter: n/a
Properties:
module.name = "libpipewire-module-access"
object.id = "17"
object.serial = "17"
module.description = "Perform access check"
module.usage = "( access.socket={ <socket>=<access>, ... } ) ( access.legacy=true ) "
Module #18
Argument:
Usage counter: n/a
Properties:
module.name = "libpipewire-module-adapter"
object.id = "18"
object.serial = "18"
module.description = "Manage adapter nodes"
Module #20
Argument: {
#allow.link.passive = false
Usage counter: n/a
Properties:
module.name = "libpipewire-module-link-factory"
object.id = "20"
object.serial = "20"
module.description = "Allow clients to create links"
module.usage = "( allow.link.passive=<bool, default false> ) "
Module #22
Argument:
Usage counter: n/a
Properties:
module.name = "libpipewire-module-session-manager"
object.id = "22"
object.serial = "22"
module.author = "George Kiagiadakis <george.kiagiadakis@collabora.com>"
module.description = "Implements objects for session management"
Module #536870912
Argument:
Usage counter: n/a
Properties:
module.author = "Pauli Virtanen <pav@iki.fi>"
module.description = "Always keeps at least one sink loaded even if it's a null one"
module.usage = "sink_name=<name of sink>"
Module #536870913
Argument:
Usage counter: n/a
Properties:
module.description = "Keep track of devices (and their descriptions) both past and present and prioritise by role"
module.usage = "do_routing=<Automatically route streams based on a priority list (unique per-role)?> on_hotplug=<When new device becomes available, recheck streams?> on_rescue=<When device becomes unavailable, recheck streams?>"
Module #536870914
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the volume/mute state of devices"
module.usage = "restore_port=<Save/restore port?> restore_volume=<Save/restore volumes?> restore_muted=<Save/restore muted states?> restore_formats=<Save/restore saved formats?>"
Module #536870915
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the volume/mute/device state of streams"
module.usage = "restore_device=<Save/restore sinks/sources?> restore_volume=<Save/restore volumes?> restore_muted=<Save/restore muted states?> on_hotplug=<This argument is obsolete, please remove it from configuration> on_rescue=<This argument is obsolete, please remove it from configuration> fallback_table=<filename>"
Sink #57
State: SUSPENDED
Description: Navi 31 HDMI/DP Audio Digital Stereo (HDMI)
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_03_00.1.hdmi-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
object.path = "alsa:acp:HDMI:4:playback"
api.alsa.path = "hdmi:1"
api.alsa.pcm.card = "1"
api.alsa.pcm.stream = "playback"
port.group = "playback"
device.icon_name = "audio-card-analog"
device.bus = "pci"
audio.channels = "2"
audio.position = "FL,FR"
iec958.codecs = "[\"PCM\"]"
device.routes = "1"
alsa.resolution_bits = "16"
alsa.card = "1"
alsa.card_name = "HDA ATI HDMI"
alsa.long_card_name = "HDA ATI HDMI at 0xa0220000 irq 135"
alsa.mixer_name = "ATI R6xx HDMI"
alsa.components = "HDA:1002aa01,00aa0100,00100800"
alsa.id = "HDMI"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "F24G3xTF"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "3"
alsa.sync.id = "00000000:00000000:00000000:00000000"
device.profile.name = "hdmi-stereo"
device.profile.description = "Digital Stereo (HDMI)"
card.profile.device = "4"
device.id = "48"
factory.name = "api.alsa.pcm.sink"
node.pause-on-idle = "false"
priority.driver = "696"
priority.session = "696"
media.class = "Audio/Sink"
node.name = "alsa_output.pci-0000_03_00.1.hdmi-stereo"
node.nick = "F24G3xTF"
device.description = "Navi 31 HDMI/DP Audio"
api.alsa.card.name = "HDA ATI HDMI"
api.alsa.card.longname = "HDA ATI HDMI at 0xa0220000 irq 135"
factory.id = "19"
clock.quantum-limit = "8192"
client.id = "47"
node.driver = "true"
node.loop.name = "data-loop.0"
library.name = "audioconvert/libspa-audioconvert"
object.id = "57"
object.serial = "57"
device.enum.api = "udev"
api.alsa.card = "1"
device.plugged.usec = "8603412"
device.bus_path = "pci-0000:03:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card1"
device.subsystem = "sound"
device.vendor.id = "0x1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "0xab30"
device.product.name = "Navi 31 HDMI/DP Audio"
device.name = "alsa_card.pci-0000_03_00.1"
device.nick = "HDA ATI HDMI"
api.alsa.use-acp = "true"
api.acp.auto-port = "false"
api.dbus.ReserveDevice1.Priority = "-20"
api.alsa.split-enable = "true"
api.dbus.ReserveDevice1 = "Audio1"
spa.object.id = "4"
device.string = "1"
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, availability group: Legacy 1, available)
Active Port: hdmi-output-0
Formats:
pcm
Source #57
State: SUSPENDED
Description: Monitor of Navi 31 HDMI/DP Audio Digital Stereo (HDMI)
Driver: PipeWire
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_03_00.1.hdmi-stereo
Properties:
device.bus = "pci"
device.routes = "1"
alsa.card = "1"
alsa.id = "HDMI"
device.api = "alsa"
device.class = "monitor"
alsa.device = "3"
device.id = "48"
factory.id = "19"
client.id = "47"
object.id = "57"
api.alsa.card = "1"
spa.object.id = "4"
device.string = "1"
Ports:
Formats:
pcm
Client #32
Driver: PipeWire
Owner Module: 2
Properties:
pipewire.protocol = "protocol-native"
core.name = "pipewire-stathis-1566"
pipewire.sec.socket = "pipewire-0-manager"
pipewire.sec.pid = "1566"
pipewire.sec.uid = "1000"
pipewire.sec.gid = "1000"
pipewire.sec.label = "unconfined"
module.id = "2"
object.id = "32"
object.serial = "32"
application.version = "0.5.13"
wireplumber.daemon = "true"
wireplumber.profile = "main"
application.name = "WirePlumber"
remote.name = "[pipewire-0-manager,pipewire-0]"
config.name = "null"
context.modules.allow-empty = "true"
application.process.binary = "wireplumber"
application.language = "en_US.UTF-8"
application.process.id = "1566"
application.process.user = "stathis"
application.process.host = "stathis-H410M-HVS"
application.process.session_id = "2"
window.x11.display = ":0"
cpu.max-align = "32"
default.clock.rate = "48000"
default.clock.quantum = "1024"
default.clock.min-quantum = "32"
default.clock.max-quantum = "2048"
default.clock.quantum-limit = "8192"
default.clock.quantum-floor = "4"
default.video.width = "640"
default.video.height = "480"
default.video.rate.num = "25"
default.video.rate.denom = "1"
log.level = "2"
clock.power-of-two-quantum = "true"
link.max-buffers = "64"
mem.warn-mlock = "false"
mem.allow-mlock = "true"
settings.check-quantum = "false"
settings.check-rate = "false"
core.version = "1.4.10"
pipewire.access = "unrestricted"
session.services = "[audio, policy.device.profile, policy.device.routes, api.bluez, video-capture, bluetooth.midi, policy.default-nodes, api.alsa, policy.linking.standard, api.v4l2, bluetooth.audio, api.alsa-seq, midi, policy.linking.role-based, api.libcamera]"
Client #33
Driver: PipeWire
Owner Module: 2
Properties:
core.name = "pipewire-stathis-1567"
pipewire.sec.socket = "pipewire-0"
pipewire.sec.pid = "1567"
module.id = "2"
object.id = "33"
object.serial = "33"
config.name = "pipewire-pulse.conf"
application.name = "pipewire"
application.process.binary = "pipewire"
application.process.id = "1567"
log.level = "2"
Client #34
Driver: PipeWire
Owner Module: 2
Properties:
module.id = "2"
object.id = "34"
object.serial = "34"
client.api = "pipewire-pulse"
pulse.server.type = "unix"
window.x11.screen = "0"
application.name = "xfwm4"
application.process.id = "1528"
application.process.binary = "xfwm4"
application.language = "en_US.utf8"
application.process.machine_id = "239731aabcd44baf90abf538f190e585"
log.level = "2"
Client #47
Driver: PipeWire
Owner Module: 2
Properties:
module.id = "2"
object.id = "47"
object.serial = "47"
application.name = "WirePlumber [export]"
wireplumber.export-core = "true"
log.level = "2"
Client #53
Driver: PipeWire
Owner Module: 2
Properties:
module.id = "2"
object.id = "53"
object.serial = "53"
application.name = "xfce4-pulseaudio-plugin"
application.version = "0.5.1"
application.id = "org.xfce.pulseaudio-plugin"
application.icon_name = "multimedia-volume-control"
application.process.id = "1646"
application.process.binary = "wrapper-2.0"
log.level = "2"
Client #62
Driver: PipeWire
Owner Module: 2
Properties:
core.name = "pipewire-stathis-2150"
pipewire.sec.pid = "2150"
module.id = "2"
object.id = "43"
object.serial = "62"
pipewire.access.portal.is_portal = "true"
portal.monitor = "Camera"
application.name = "xdg-desktop-portal"
application.process.binary = "xdg-desktop-portal"
application.process.id = "2150"
log.level = "0"
Client #63
Driver: PipeWire
Owner Module: 2
Properties:
module.id = "2"
object.id = "58"
object.serial = "63"
application.name = "Blueman"
application.process.id = "1917"
application.process.binary = "python3.14"
window.x11.display = ":0.0"
log.level = "2"
Client #64
Driver: PipeWire
Owner Module: 2
Properties:
module.id = "2"
object.id = "59"
object.serial = "64"
application.name = "Firefox"
application.process.id = "3256"
application.process.binary = "firefox"
log.level = "2"
Client #66
Driver: PipeWire
Owner Module: 2
Properties:
module.id = "2"
object.id = "60"
object.serial = "66"
application.process.id = "6420"
application.process.binary = "pactl"
application.name = "pactl"
log.level = "2"
Card #48
Driver: alsa
Owner Module: n/a
Properties:
device.api = "alsa"
media.class = "Audio/Device"
api.alsa.path = "hw:1"
api.alsa.card = "1"
device.bus = "pci"
device.icon_name = "audio-card-analog-pci"
spa.object.id = "4"
factory.id = "15"
client.id = "47"
object.id = "48"
object.serial = "48"
object.path = "alsa:acp:HDMI"
alsa.card = "1"
alsa.id = "HDMI"
device.string = "1"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
Active Profile: output:hdmi-stereo
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 1"
card.profile.port = "0"
device.product.name = "F24G3xTF"
iec958.codecs.detected = "[\"PCM\"]"
Part of profile(s): output:hdmi-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 2"
card.profile.port = "1"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 3"
card.profile.port = "2"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 4"
card.profile.port = "3"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Card #49
Driver: alsa
Owner Module: n/a
Properties:
device.api = "alsa"
api.alsa.path = "hw:0"
api.alsa.card = "0"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.card.longname = "HDA Intel PCH at 0xa0520000 irq 136"
device.plugged.usec = "8626773"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "0x8086"
device.product.id = "0xa3f0"
device.product.name = "Comet Lake PCH-V cAVS"
device.name = "alsa_card.pci-0000_00_1f.3"
device.description = "Built-in Audio"
device.nick = "HDA Intel PCH"
spa.object.id = "2"
factory.id = "15"
client.id = "47"
object.id = "49"
object.serial = "49"
object.path = "alsa:acp:PCH"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xa0520000 irq 136"
alsa.mixer_name = "Realtek ALC887-VD"
alsa.components = "HDA:10ec0887,1849288a,00100302"
alsa.id = "PCH"
device.string = "0"
Profiles:
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: no)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
pro-audio: Pro Audio (sinks: 1, sources: 2, priority: 1, available: yes)
Active Profile: off
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "mic"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "mic"
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "line"
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "line"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 5, not available)
Properties:
port.type = "headphones"
port.availability-group = "Legacy 5"
card.profile.port = "4"
Aragorn:
Never take any advice from Reddit, YouTube, Facebook, or even worse, ChatGPT.
Too late for that. Reddit and youtube have solved almost all my problems!
I didnt have any sound even before i install the sound card
