Packagekit Issue (Service Crashes)
I have an issue that I noticed while trying to install yt-dlp. The step where it re-runs packagekit always timed out, and after trying a re-install of packagekit, it still is broken. Trying to restart the service before the re-install resulted in it failing to start, and restarts of the system also failed.
Not sure what to do from here.
From journalctl -xe:
Subject: Process 4945 (packagekitd) dumped core
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Process 4945 (packagekitd) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Jul 20 23:11:35 IntrepidExplorator systemd[1]: systemd-coredump@2-4952-0.service: Deactivated>
░░ Subject: Unit succeeded
░░ The unit systemd-coredump@2-4952-0.service has successfully entered the 'dead' state.
Jul 20 23:11:35 IntrepidExplorator systemd[1]: packagekit.service: Main process exited, code=>
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit packagekit.service has exited.
░░ The process' exit code is 'dumped' and its exit status is 5.
Jul 20 23:11:35 IntrepidExplorator systemd[1]: packagekit.service: Failed with result 'core-d
  Kernel: 6.5.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.5-x86_64
    root=UUID=2a31104f-8406-433f-9350-2f8b71afd5fd rw rootflags=subvol=@ quiet
    cryptdevice=UUID=0e39c179-f5a7-402b-b9eb-ef28102abd87:luks-0e39c179-f5a7-402b-b9eb-ef28102abd87
    root=/dev/mapper/luks-0e39c179-f5a7-402b-b9eb-ef28102abd87 splash
    resume=/dev/mapper/luks-34f78b3b-b82b-48e4-8133-a5115be1fb21
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_wayland dm: SDDM
  Type: Laptop System: LG product: 17Z90N-R.AAC8U1 v: 0.1 serial: <filter>
    Chassis: type: 10 v: 0.1 serial: <filter>
  Mobo: LG model: 17Z90N v: FAB1 serial: <filter> UEFI: Phoenix
    v: C2ZE0200 X64 date: 08/12/2020
  ID-1: CMB0 charge: 73.4 Wh (100.0%) condition: 73.4/80.0 Wh (91.8%)
    power: 0.0 W volts: 8.7 min: 7.7 model: LG LGC-LGC type: Li-ion
    serial: <filter> status: full cycles: 19
  System RAM: total: 16 GiB available: 15.25 GiB used: 4.78 GiB (31.3%)
    igpu: 60 MiB
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 3200 MT/s volts: curr: 1.2 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471A1K43DB1-CWE serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    manufacturer: Samsung part-no: M471A1G44AB0-CWE serial: N/A
  Info: model: Intel Core i7-1065G7 socket: U3E1 bits: 64 type: MT MCP
    arch: Ice Lake gen: core 10 level: v4 note: check built: 2019-21
    process: Intel 10nm family: 6 model-id: 0x7E (126) stepping: 5
    microcode: 0xBA
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 1337 high: 1500 min/max: 400/3900 base/boost: 1500/1500
    scaling: driver: intel_pstate governor: powersave volts: 0.7 V
    ext-clock: 100 MHz cores: 1: 1300 2: 1500 3: 1251 4: 1300 5: 1300 6: 1250
    7: 1500 8: 1300 bogomips: 23968
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
    avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
    est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep sgx sgx_lc sha_ni smap smep split_lock_detect ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Iris Plus Graphics G7 vendor: LG driver: i915 v: kernel
    arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a52
    class-ID: 0300
  Device-2: Realtek LG Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 0bda:5641
  Display: server: X.Org v: 23.1.2 with: Xwayland v: 23.1.2
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: LG Display 0x05f8 built: 2018 res: 2560x1600
    dpi: 178 gamma: 1.2 size: 366x229mm (14.41x9.02") diag: 432mm (17")
    ratio: 16:10 modes: 2560x1600
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Iris Plus Graphics
    (ICL GT2) direct-render: Yes
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: LG
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
    bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
  API: ALSA v: k6.5.0-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.74 status: off with: wireplumber status: off
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0026
    class-ID: e001
  Device-1: luks-0e39c179-f5a7-402b-b9eb-ef28102abd87 maj-min: 254:0
    type: LUKS dm: dm-0 size: 467.84 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 467.84 GiB
  Device-2: luks-34f78b3b-b82b-48e4-8133-a5115be1fb21 maj-min: 254:1
    type: LUKS dm: dm-1 size: 8.8 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 8.8 GiB
  Local Storage: total: 476.94 GiB used: 138.03 GiB (28.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: HFS512GD9TNG-L2A0A size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 80001C10 temp: 41.9 C scheme: GPT
  SMART: yes health: PASSED on: 20d 3h cycles: 70
    read-units: 2,271,872 [1.16 TB] written-units: 4,320,660 [2.21 TB]
  ID-1: / raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
    used: 138.02 GiB (29.5%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks-0e39c179-f5a7-402b-b9eb-ef28102abd87 label: N/A
    uuid: 2a31104f-8406-433f-9350-2f8b71afd5fd
    used: 720 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 68B3-352B
  ID-3: /home raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
  ID-4: /var/cache raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
  ID-5: /var/log raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
  ID-1: swap-1 type: partition size: 8.8 GiB used: 5 MiB (0.1%) priority: -2
    dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-34f78b3b-b82b-48e4-8133-a5115be1fb21 label: swap
    uuid: b7237a9a-b34c-407c-b410-a8b043dc12b2
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-1:2 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
    serial: <filter>
  Device-2: 3-2:3 info: Realtek LG Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 0bda:5641 class-ID: 0e02 serial: <filter>
  Device-3: 3-7:4 info: Microsoft Xbox Elite Series 2 Controller (model 1797)
    type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0
    chip-ID: 045e:0b00 class-ID: ff00 serial: <filter>
  Device-4: 3-10:5 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-4: 4-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 56.0 C mobo: N/A
  Processes: 309 Uptime: 15m wakeups: 4271 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: 1339 pm: pacman pkgs: 1330 libs: 387 tools: pamac,yay pm: flatpak
  pkgs: 9 Shell: Bash (su) v: 5.1.16 running-in: yakuake inxi: 3.3.28
What does the core dump say?
Or the service? ex:
systemctl status packagekit
Also … may I ask what you are using packagekit for?
Ok, got it, it didn’t like a custom system argument to /etc/pacman.
Glad its worked it.
But I asked because packagekit is not only not required … but warned against if you are trying to use it for system package management. ( in lieu of, ex, pacman )
Its your system of course. But ‘there be dragons’ and whatnot.
pacman/Tips and tricks - ArchWiki
