Package Manager - Missing tabs
My Package Manager does not have the ‘Advanced’ tab, nor does it exposed AUR under the “Third Party” tab?? Any ideas?
PackManager_GUI
KDE Plasma Version: 5.26.3
KDE Frameworks Version: 5.99.0
Qt Version: 5.15.7
Kernel Version: 5.18.19-3-MANJARO
OS Type: 64-bit
Processors: 4 × Intel® Core™ i5-2500 CPU @ 3.30GHz
Memory: 15.5 GiB of RAM
how does it look like if you open other gtk-Apps like Thunderbird, Firefox or LibreOffice?
( explanation: trying to find out if it is a gtk lib issue or just need to reinstall pamac )
[ also welcome :slight_smile: ]
Try turning off Software Mode
@Takage Aaah! Yes … how unobservant of me!! Thanks.
@anon58039152 Thanks :slight_smile:
