Hey guys! I have a problem receiving updates on Manjaro. When the installation of Manjaro finishes and we start the system, we update the system before doing anything. However, when I go to the package manager and look for updates, the package manager says that the system is already up to date. But we know that after installing the system, several new updates arrive. How can I solve this problem? Note: It’s not an internet problem.
we have an update in stable all 7…10 days , if iso is “very” young no reason to have update
I don’t understand what you mean, brother
Try that in a terminal.
sudo pacman-mirrors --geoip && sudo pacman -Syyu
I’ve tried using this command, but the problem remains the same. I also forgot to mention that it is not possible to fetch Flatpak/Snap apps. Searches return empty.
What is the output?
It just returns that it didn’t find any results.
What is the output, exactly?
I’ll have to leave here, can we continue later? Thanks for the help!
?? no, we have new update ONLY if iso is old (15 days… 1 month):
what is iso name ? we have in last gnome name “210904
” so 4 days
Hi, the exact message is: No packages found. But I’m sure there’s the app I’m looking for on Flatpak. And yes, third-party apps skill in settings.
So you mean I shouldn’t be getting updates?
That is not the output of pacman
command. At some point copy/paste the output of the command from the terminal I gave above, here, this is gonna be old soon to ask you the same thing that much time. Copy the command above, paste it in your terminal, and copy the full output, and paste it here in a reply, between three backticks so it is properly formatted, example:
the whole output here
: Sincronizando a base de dados de pacotes...
core 169,6 KiB 432 KiB/s 00:00 [######################] 100%
extra 1892,8 KiB 1318 KiB/s 00:01 [######################] 100%
community 6,6 MiB 586 KiB/s 00:12 [######################] 100%
multilib 174,6 KiB 394 KiB/s 00:00 [######################] 100%
:: Iniciando atualização completa do sistema...
atenção: gnome-shell-extension-nightthemeswitcher: local (52-1) é mais novo que community (51-2)
nada para fazer
The answer is in Portuguese, I will change it to English
This output means there is no update (and the package gnome-shell-extension-nightthemeswitcher
got downgraded but this is not an issue).
But how not? Since I just installed the system
read dates
- last update https://forum.manjaro.org/c/announcements/stable-updates/12 not exists update since last announcement
- your iso name is
210904
for snap :
is ON in pamac preferences ?
with last version , is at us to install libpamac plugin package ? for verif:
LANG=C pacman -Qs pamac
Yes they are, I had typed the wrong app name
