Package Manager Does Not Launch After Recent Updates
I have a peculiar issue where the package manager (pamac-manager) does not load/properly launch after recent (1~2 months ago) system updates. When I try to open the package manager, the terminal displays the following error:
(pamac-manager:7335): Gtk-WARNING **: 22:38:24.310: No IM module matching GTK_IM_MODULE=fcitx found
I use fcitx as part of a setup to allow me to type in Japanese in an otherwise English-based environment. After the issue surfaced, I reinstalled fcitx but to no avail.
Any suggestions about how to fix this issue?
Please note that while I’ve been using Manjaro for years, I am not very familiar with its nuts and bolts and so would appreciate suggestions that would be easy to implement for a novice. Thank you.
You might try installing pamac-gtk3 instead, to see if that makes a difference.
sudo pacman -S pamac-gtk3
This should give the option to replace the existing pamac-gtk.
Additionally, are you using Wayland or X11?
If using Wayland, you might try either;
  • export GTK_IM_MODULE=wayland
  • export GTK_IM_MODULE=fcitx
or, if using X11;
…environment variables in your ~/.profile.
(followed by a reboot)
Cheers.
Welcome to the Forum!
I’d suggest removing that package, doing the upgrades and then reinstalling it afterwards, if you haven’t already tried that.
Just to add: a bit more system info might help e.g. inxi -zv8 … cheers! :slight_smile:
Dear @soundofthunder , thank you for your suggestion! Switching from pamac-gtk to pamac-gtk3 resolved the issue. No additional action (additions of environment variables) were necessary. Many thanks for your help.
