Package conflict with unreadable text
similar problem here, none of the provided solutions work …
Error: Failed to prepare transaction:
conflicting dependencies:
- ���oi�A�&;p and ltq�XQ�����&;p are in conflict
and i have no clue which packages to remove ... i am truly stuck here folk
~ []$ pamac update --no-aur
Preparing...
Authenticating as: bogi
Password:
Resolving dependencies...
Checking inter-conflicts...
Error: unresolvable package conflicts detected
- ���oi�A and ltq�XQ���R�r�r are in conflict
Please use sudo pacman -Syu to see what the conflict is.
[sudo] password for bogi:
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
:: Replace lib32-libva-mesa-driver with multilib/lib32-mesa? [Y/n]
starts off here , then
:: Replace lib32-libva-mesa-driver with multilib/lib32-mesa? [Y/n] y
:: Replace lib32-mesa-vdpau with multilib/lib32-mesa? [Y/n] y
:: Replace libva-mesa-driver with extra/mesa? [Y/n] y
:: Replace linux610 with core/linux-meta? [Y/n] y
:: Replace linux610-virtualbox-host-modules with extra/linux-virtualbox-host-modules-meta? [Y/n] y
:: Replace mesa-vdpau with extra/mesa? [Y/n] y
:: Replace qcoro-qt6 with extra/qcoro? [Y/n] y
:: Replace tracker3 with extra/tinysparql? [Y/n] y
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: nodejs-lts-hydrogen-18.20.5-1 and nodejs-lts-iron-20.18.0-1 are in conflict
Please format the output as pre-formatted text either by selecting it and pressing the </> button or by enclosing it in 3 back ticks like so:
text
which then appears like this:
text
EDIT:
Thanks, much better.
As for the conflict, you need to remove one or the other. I’m not familiar with either so :man_shrugging:
A post was merged into an existing topic: None of the node packages are removable
19 posts were split to a new topic: None of the node packages are removable
The issue is fixed with libpamac 11.7.0-2.
