Package cache - files not detected by pacman/paccache (more then orphaned)
I regularly clean my package cache of orphaned packages and limit the keep number to 2 versions.
However in my /var/cache/pacman/pkg directory are some files, pacman/pamac/paccache can’t detect any more. For example: mhwd-nvidia-1:430.26-1-any.pkg.tar.xz (from 2019).
About the reason I just can speculate, but my obvious question:
How can I get rid of them? Is there only the manuel way left?
Have you tried
sudo rm /var/cache/pacman/pkg/*
See
man paccache
To see what consequence this run may have
sudo paccache --dryrun --uninstalled --keep 0
To remove all - including uninstalled packages - leaving only the installed package in the cache
sudo paccache --remove --uninstalled --keep 0
Seems you cannot have so many options at once so you will have to run the command 3 times with the different options.
Really ? it should be equivalent of
sudo paccache -ruk0
Which I know works
[teo@teo-lenovo-v15 ~]$ sudo paccache --dryrun --remove --uninstalled --keep 0
[sudo] password for teo:
==> ERROR: only one operation may be used at a time
So does the paccache say :slight_smile: I guess it goes ok with one dash one letter syntax but does not like it in the 2 dashes whole words format. Which seems like a bug actually.
It seems that --dryrun is the culprit - I never used it - thought I include an option to see what was happening.
Thank you for proving me wrong - I edited my comment accordingly
I just tried it for the first time, i usually just pacman -Scc
The following works fine:
  • sudo is not needed for a dryrun
  • You can only specify one operation from the set of remove, dryrun, or move. Additional options (uninstalled, keep, verbose, etc.) are fine.
I don’t want to delete the whole cache.
Thanks for your answers, but I know how to use paccache and even the command
paccache -duk0 or -ruk0 can’t find those “ghost” packages.
Maybe because in the past the name scheme changed?
Understandable
The package is a part of mhwd - Manjaro Hardware Detection - after your system is setup - technically there is no longer any need for mhwd as mhwd focus is to install the drivers for GPU but Manjaro Settings Manager GUI depends on mhwd to switch GPU drivers so it is best to keep it around.
That could be because there is an epoch attached 1:430.26.1-1 and/or it is caused by the extension - the extension is now zstd as packags are compressed using zstd.
Option 1
sudo pacman -Rdd mhwd-nvidia
check if the package has been removed - if not remove it manully
sudo rm mhwd-nvidia-1:430.26-1-any.pkg.tar.xz
Reinstall mhwd-nvidia
sudo pacman -Syu mhwd-nvidia
Option 2
The first step is to remove all mhwd related packages
sudo pacman -R $(pacman -Qsq mhwd)
Then recheck the cache folder - if the package is still there remove manually
Then reinstall mhwd
If you choose to handle kernel change manually or don’t need the functionality provided you can decide if you want reinstall or not.
Yes, maybe because there was this change from xz to zstd left those packages behind.
So…
Option 1 would only remove the latest mhwd-nvidia package (550*) and
Option 2 would remove all but not mhwd-nvidia-1:430.26-1-any-pkg-tar-xz.
This package is not the only one, so I think there is only the manual way, but looking for the xz extension is a good start (there are 54 files within the cache directory).
Unfortunately I am not experienced enough with making a script :sweat_smile:
The cache folder is what it is - it is not required for operating the system.
pacman places files there when download - usually it is not a big deal to remove them all.
But you are system admin - your decision.
To remove all package with the old extension including .sig files
sudo rm /var/cache/pacman/pkg/*.pkg.tar.xz*
While the extension is now zstd - there is still packages in the repo which has never been rebuild with the new extension - not a big deal.
If want to go into details - you could move the all to a temp folder in your home
mkdir ~/temp
cp /var/cache/pacman/pkg/* ~/home/temp
sudo rm /var/cacha/pacman/pkg/*
I listed what exist on my mirror server - packages that has not been rebuilt with hew extension - 113 packages - pacman handles both correct - they are mostly static packeges with wallpapers etc.
-rwxr-xr-x 1 root root    761084 Jul  4  2019 /a/repos/manjaro/pool/overlay/adapta-maia-theme-3.94.0.149-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root      7592 May 18  2018 /a/repos/manjaro/pool/overlay/amdgpu-experimental-20180518-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root    381452 Jul  7  2023 /a/repos/manjaro/pool/overlay/archuseriso-0.7.9-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root  31895600 Jul 29  2019 /a/repos/manjaro/pool/overlay/artwork-cinnamon-minimal-20190729-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root   2306016 Jan 12  2016 /a/repos/manjaro/pool/overlay/artwork-fluxbox-20160112-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root   4300268 Sep 12  2019 /a/repos/manjaro/pool/overlay/artwork-i3-20190912-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root  48019760 May 14  2016 /a/repos/manjaro/pool/overlay/awoken-icon-theme-2.5.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root  24248992 May 14  2016 /a/repos/manjaro/pool/overlay/awoken-icon-theme-light-2.5.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     14364 Jul 27  2022 /a/repos/manjaro/pool/overlay/base-3-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root     14520 Oct 27  2018 /a/repos/manjaro/pool/overlay/bootsplash-systemd-0.1.2-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     29620 Oct 27  2018 /a/repos/manjaro/pool/overlay/bootsplash-theme-amd-0.1-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root     31836 Oct 27  2018 /a/repos/manjaro/pool/overlay/bootsplash-theme-arch-0.1-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root     32944 Oct 27  2018 /a/repos/manjaro/pool/overlay/bootsplash-theme-gnome-0.1-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root     27560 Oct 27  2018 /a/repos/manjaro/pool/overlay/bootsplash-theme-illyria-0.1-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root     28080 Oct 27  2018 /a/repos/manjaro/pool/overlay/bootsplash-theme-kde-0.1-3-any.pkg.tar.xz
-rwxr-xr-x 1 root root     26420 Oct 27  2018 /a/repos/manjaro/pool/overlay/bootsplash-theme-manjaro-0.1-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root     26244 Oct 27  2018 /a/repos/manjaro/pool/overlay/bootsplash-theme-vendor-0.1-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root     43736 Oct 27  2018 /a/repos/manjaro/pool/overlay/bootsplash-theme-xfce-0.1-3-any.pkg.tar.xz
-rwxr-xr-x 1 root root  10170048 Oct 21  2019 /a/repos/manjaro/pool/overlay/breeze-maia-icon-themes-5.63.0-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     23376 Oct 13  2022 /a/repos/manjaro/pool/overlay/calamares-oem-postinstall-configs-20221013-3-any.pkg.tar.xz
-rwxr-xr-x 1 root root      6564 Feb  7  2018 /a/repos/manjaro/pool/overlay/cinnamon-live-1.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     23380 Sep 15  2019 /a/repos/manjaro/pool/overlay/cinnamon-panel-chooser-1.5-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root  11190132 Jul 29  2019 /a/repos/manjaro/pool/overlay/cinnamon-wallpapers-20190729-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root      4536 Sep 27  2016 /a/repos/manjaro/pool/overlay/fluxbox-theme-manjaro-20160927-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root   2303600 Oct 12  2015 /a/repos/manjaro/pool/overlay/fluxbox-wallpapers-20151012-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     69768 Sep 12  2019 /a/repos/manjaro/pool/overlay/i3-default-artwork-20190912-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     54656 Jan 10  2018 /a/repos/manjaro/pool/overlay/i3-help-20180110-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root   4007456 Nov  3  2015 /a/repos/manjaro/pool/overlay/i3-wallpapers-20151103-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root   1018896 Jul 15  2018 /a/repos/manjaro/pool/overlay/illyria-wallpaper-1.4-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     28896 Nov  5  2023 /a/repos/manjaro/pool/overlay/juno-tablet-0.2.0-3-any.pkg.tar.xz
-rwxr-xr-x 1 root root     54584 Oct 10  2023 /a/repos/manjaro/pool/overlay/kvantum-theme-matcha-20190810-3-any.pkg.tar.xz
-rwxr-xr-x 1 root root   9592540 Sep  8  2017 /a/repos/manjaro/pool/overlay/lxde-wallpapers-20170907-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root      4052 Jul  8  2017 /a/repos/manjaro/pool/overlay/maia-console-1.2-6-any.pkg.tar.xz
-rwxr-xr-x 1 root root    995176 Feb 20  2017 /a/repos/manjaro/pool/overlay/manjaro-artwork-1.0.8-4-any.pkg.tar.xz
-rwxr-xr-x 1 root root  55516876 Mar 25  2013 /a/repos/manjaro/pool/overlay/manjaro-artwork-extra-1.0.7-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root   2327316 Mar 25  2013 /a/repos/manjaro/pool/overlay/manjaro-artwork-openbox-1.0.7-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root  18668364 Dec  8  2016 /a/repos/manjaro/pool/overlay/manjaro-backgrounds-20161208-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root      8656 Oct 30  2017 /a/repos/manjaro/pool/overlay/manjaro-base-skel-20171029-3-any.pkg.tar.xz
-rwxr-xr-x 1 root root   1358384 Oct  5  2018 /a/repos/manjaro/pool/overlay/manjaro-grub-theme-adapta-1.4-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root   2787252 Oct  5  2018 /a/repos/manjaro/pool/overlay/manjaro-grub-theme-blue-1.4-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root    755960 Oct  5  2018 /a/repos/manjaro/pool/overlay/manjaro-grub-theme-blurred-1.4-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root   1705776 Oct  5  2018 /a/repos/manjaro/pool/overlay/manjaro-grub-theme-brown-1.4-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root   1015464 Oct  5  2018 /a/repos/manjaro/pool/overlay/manjaro-grub-theme-doggie-1.4-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root   1848240 Oct  5  2018 /a/repos/manjaro/pool/overlay/manjaro-grub-theme-glassfield-1.4-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root   1187164 Oct  5  2018 /a/repos/manjaro/pool/overlay/manjaro-grub-theme-light-1.4-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root   7730828 Sep 13  2019 /a/repos/manjaro/pool/overlay/manjaro-grub-theme-sunset-1.4-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     24744 Sep 24  2018 /a/repos/manjaro/pool/overlay/manjaro-iso-profiles-base-17.1.12-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     86688 Jul 19  2023 /a/repos/manjaro/pool/overlay/manjaro-keyring-20230719-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root     22256 Aug  8  2023 /a/repos/manjaro/pool/overlay/manjaro-live-base-20230808-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root     16812 Dec 19  2022 /a/repos/manjaro/pool/overlay/manjaro-live-skel-20221219-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     34008 Apr  4  2017 /a/repos/manjaro/pool/overlay/manjaro-lxde-logout-banner-0.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root      5196 Apr 27  2017 /a/repos/manjaro/pool/overlay/manjaro-lxde-xfce4-notifyd-0.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root      3696 May 28  2017 /a/repos/manjaro/pool/overlay/manjaro-lxde-xfce4-volumed-pulse-0.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root      6064 Jun  1  2018 /a/repos/manjaro/pool/overlay/manjaro-openbox-adapta-maia-1.0-4-any.pkg.tar.xz
-rwxr-xr-x 1 root root      7180 Nov  3  2018 /a/repos/manjaro/pool/overlay/manjaro-openbox-maia-1.0-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root      4396 Aug 28  2019 /a/repos/manjaro/pool/overlay/manjaro-openbox-matcha-1.0-3-any.pkg.tar.xz
-rwxr-xr-x 1 root root      2024 May 22  2018 /a/repos/manjaro/pool/overlay/manjaro-openbox-theme-18.0-1.18-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root    597320 Dec 30  2018 /a/repos/manjaro/pool/overlay/manjaro-openbox-wallpapers-1.0.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root    516156 Jul 29  2019 /a/repos/manjaro/pool/overlay/manjaro-openbox-wallpapers-matrix-0.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root   9219300 Jun  3  2013 /a/repos/manjaro/pool/overlay/manjaro-users-artwork-wallpapers-2013.05-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root   3261744 Jan 28  2018 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-17.0-1.3-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root   9469472 Oct 28  2018 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-18.0-1.4-3-any.pkg.tar.xz
-rwxr-xr-x 1 root root     14136 Aug  4  2019 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-by-lunix-budgie-1.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root   6472904 Aug  4  2019 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-by-lunix-cinnamon-1.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root    382404 Aug  4  2019 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-by-lunix-cool-logo-1.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     16944 Aug  4  2019 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-by-lunix-deepin-1.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root   3310700 Aug  4  2019 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-by-lunix-gnome-1.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root    180128 Aug  4  2019 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-by-lunix-i3-1.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root   6626816 Aug  4  2019 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-by-lunix-kde-plasma-1.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root 104207100 Aug  4  2019 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-by-lunix-manjaro-1.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root    157368 Aug  4  2019 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-by-lunix-openbox-1.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root   2950196 Aug  4  2019 /a/repos/manjaro/pool/overlay/manjaro-wallpapers-by-lunix-xfce-1.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root  11590932 Jan  3  2018 /a/repos/manjaro/pool/overlay/masalla-icon-theme-1.2-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     17748 Dec 26  2019 /a/repos/manjaro/pool/overlay/mkinitcpio-openswap-0.1.0-3-any.pkg.tar.xz
-rwxr-xr-x 1 root root     25688 Jan  4  2018 /a/repos/manjaro/pool/overlay/morc_menu-1.0-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root  26890280 Oct  8  2017 /a/repos/manjaro/pool/overlay/muser-wallpapers-20171008-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root    295784 May 15  2019 /a/repos/manjaro/pool/overlay/openbox-themes-1.0.2-4-any.pkg.tar.xz
-rwxr-xr-x 1 root root     37284 May  7  2018 /a/repos/manjaro/pool/overlay/openbox-themes-extra-1.0-4-any.pkg.tar.xz
-rwxr-xr-x 1 root root   7741184 Jun 13 16:39 /a/repos/manjaro/pool/overlay/pacman-static-6.1.0-4-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root     12688 Jan 31  2017 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-cinnamon-2.0-4-any.pkg.tar.xz
-rwxr-xr-x 1 root root     14132 Jan 31  2017 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-circle-1.4-4-any.pkg.tar.xz
-rwxr-xr-x 1 root root     16268 Jan 31  2017 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-deepin-1.6-5-any.pkg.tar.xz
-rwxr-xr-x 1 root root     14780 Jan 31  2017 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-deepin-circle-1.0-4-any.pkg.tar.xz
-rwxr-xr-x 1 root root     16336 Feb  2  2017 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-elegant-2.0-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root     23560 Feb  2  2017 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-elegant-hidpi-2.0-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root     16504 Jan 31  2017 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-extra-elegant-1.1-4-any.pkg.tar.xz
-rwxr-xr-x 1 root root    136540 Mar 26  2017 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-fancy-budgie-1.1.r2.gca022e7-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     13120 Jan 31  2017 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-gnome-1.2-4-any.pkg.tar.xz
-rwxr-xr-x 1 root root    386476 Feb 15  2017 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-gnome-17.0-1.0-4-any.pkg.tar.xz
-rwxr-xr-x 1 root root   1450072 Jan 31  2017 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-redefined-bsplash-1.0-5-any.pkg.tar.xz
-rwxr-xr-x 1 root root     10612 May 10  2014 /a/repos/manjaro/pool/overlay/plymouth-theme-manjaro-very-elegant-1.0-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root    238952 Sep  7  2023 /a/repos/manjaro/pool/overlay/rog-ally-acpi-override-20230907-1-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root      7532 Jun  2  2018 /a/repos/manjaro/pool/overlay/rootmenu-0.15-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root  25218744 Apr 25  2018 /a/repos/manjaro/pool/overlay/vibrancy-icons-teal-2.7-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root  18331616 Dec 17  2019 /a/repos/manjaro/pool/overlay/wallpapers-2018-1.2-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root  31551960 Nov  4  2019 /a/repos/manjaro/pool/overlay/wallpapers-infinity-book-20191104-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root  19900228 Sep 12  2019 /a/repos/manjaro/pool/overlay/wallpapers-juhraya-1.1-2-any.pkg.tar.xz
-rwxr-xr-x 1 root root  13782144 Aug 13  2019 /a/repos/manjaro/pool/overlay/wallpapers-tuxedo-20190813-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     17556 Oct  6  2019 /a/repos/manjaro/pool/overlay/xiccd-0.3.0-1-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root     21680 Nov 19  2019 /a/repos/manjaro/pool/sync/castget-2.0.1-1-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root     18904 Nov  8  2019 /a/repos/manjaro/pool/sync/fcitx-cloudpinyin-0.3.7-1-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root     49448 Dec 11  2019 /a/repos/manjaro/pool/sync/gtkspell3-3.0.10-2-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root     10372 Nov 18  2019 /a/repos/manjaro/pool/sync/hsetroot-1.0.5-1-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root     64220 Nov  9  2019 /a/repos/manjaro/pool/sync/irssi-xmpp-0.54-3-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root     96984 Dec 18  2019 /a/repos/manjaro/pool/sync/libelfin-0.3-2-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root    356584 Dec 11  2019 /a/repos/manjaro/pool/sync/libwnck-2.31.0-3-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root     42436 Nov 15  2019 /a/repos/manjaro/pool/sync/pastebinit-1.5.1-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     66520 Nov 19  2019 /a/repos/manjaro/pool/sync/permlib-0.2.9-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root     97816 Dec 22  2019 /a/repos/manjaro/pool/sync/pony-stable-0.2.2-2-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root     47144 Nov 18  2019 /a/repos/manjaro/pool/sync/procinfo-ng-2.0.304-8-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root      8968 Dec  3  2019 /a/repos/manjaro/pool/sync/sigrok-firmware-fx2lafw-0.1.7-1-any.pkg.tar.xz
-rwxr-xr-x 1 root root    297736 Nov 29  2019 /a/repos/manjaro/pool/sync/spatialindex-1.9.3-1-x86_64.pkg.tar.xz
-rwxr-xr-x 1 root root    130768 Nov 18  2019 /a/repos/manjaro/pool/sync/wireless_tools-30.pre9-3-x86_64.pkg.tar.xz
