Oversized calendar and quick settings menu
After the upgrade from last week the calendar and quick settings menu appear oversized (window, icons …)
I tried checking for newer packages, changing themes (to default), changing layouts (with the switcher) and disabled all extensions in case any could interfere but none of those seems to work.
Can anyone help me find a solution for this?
I looked in the forum but could not find anything similar that could work.
In case it’s helpful here’s some info on my system:
  Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=27ba6cde-fa39-41b1-a203-b0147cd3b42c rw quiet apparmor=1
  Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
Thanks!
It’s most likely a broken 3rd-party theme and/or something in your user profile. Try creating a new user and see if you can reproduce it.
Found a solution playing with it, apparently “gdm-settings” was creating a conflict in the configuration.
I changed the theme on GDM with this program to a new theme i downloaded and also the shell theme via tweaks.
The problem disappeared with the new theme, then i switched to my previous one for the shell and quick settings, calendar and dock were back to a normal sized interface.
Changed the theme in GDM with gdm-settings to the previous theme and everything is working fine now with the original theme.
Guess if someone reads this in the future, check for conflicts in settings created by other applications.
