Hello.
I want to screen share with Discord to watch movies and stuff along with my friends, the problem is that audio sharing is a feature not compatible with Linux so, I searched around a bit and found that you can output your system audio through your microphone along with your voice. I wanted to ask you guys what is the easiest way you know to do this.
I found some methods but I could not really understand them, and not everybody uses the same scripts and software so I got a bit confused.
Sorry if it is a dumb question, thanks in advance.
Hello,
this tutorial should work:
What exactly didn’t you understand? Be more specific…
Thanks dude, the indications on the thread worked flawlessly.
