I get this output when installing packages from Pamac:
Found Manjaro Linux on /dev/mapper/luks-95a9c47a-ede8-438c-a436-9e117a7636a9
Found Debian GNU/Linux 10 (buster) on /dev/mapper/luks-95a9c47a-ede8-438c-a436-9e117a7636a9
Found Ubuntu 20.04.3 LTS on /dev/mapper/luks-95a9c47a-ede8-438c-a436-9e117a7636a9
After each kernel update, it does sudo update-grub that you can also launch manually.
Within grub config, you get os-prober that is launched alongside.
As @papajoke said, it’s only for kernel related updates, so not as often that regular packages.
Edit: do you complete the update of all the packages? Or do you perform partial updating?
Not even close. Throw in a laptop with WiFi, hybrid AMD/Nvidia graphics, a touchpad, a Bluetooth dongle, a dual-boot setup with Windows 11, and a n00b who likes hardcore gaming through Steam and Lutris on triple monitors with a HDMI connection, and then you’ll be closer to winning the prize.
But of course, btrfs with Docker containers on LUKS is a good start.
I had no docker containers, volumes or images installed. Seems that os-prober was picking up the btrfs snapshots. I just removed the offending snapshots.
