Out of the box systemd-nspawn networking is misconfigured
Hello,
I’m using systemd-nspawn on a Manjaro host with NetworkManager disabled and instead systemd-networkd active:
● systemd-networkd.service - Network Management
     Loaded: loaded (/usr/lib/systemd/system/systemd-networkd.service; enabled;>
     Active: active (running)
When following instructions from the Archlinux wiki:
  • install a minimal image with pacstrap (base only) in /var/lib/machines
  • change the root password
  • log out
  • start the container with machinectl
  • login in the container as root
    • start systemd-networkd
When systemd-networkd is launched, the container interface is misconfigured with the wrong IPv4 address.
Below is the interface on the host. Note that the interface has two IPv4 addresses.
$ ip a show ve-root
4: ve-root@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether da:f0:45:50:e7:3b brd ff:ff:ff:ff:ff:ff link-netnsid 1
    inet 169.254.192.63/16 metric 2048 brd 169.254.255.255 scope link ve-root
       valid_lft forever preferred_lft forever
    inet 192.168.232.177/28 brd 192.168.232.191 scope global ve-root
    inet6 fe80::d8f0:45ff:fe50:e73b/64 scope link proto kernel_ll
On the container side, the interface is:
[root@root ~]# ip a show host0
2: host0@if5: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether ee:47:cd:86:53:d5 brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet 169.254.193.148/16 metric 2048 brd 169.254.255.255 scope link host0
    inet6 fe80::ec47:cdff:fe86:53d5/64 scope link proto kernel_ll
For some reason, the address is 169.254.193.148/16 while it should match the other one 192.168.232.177/28.
Indeed, if I manually add the other IP address and the route, the network is fine:
[root@root ~]# ip a add dev host0 192.168.232.176/28 metric 1024 brd 192.168.232.191 scope global
[root@root ~]# ip route add default via 192.168.232.177 dev host0 proto dhcp src 192.168.232.176 metric 1024
2: host0@if4: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    inet 192.168.232.176/28 metric 1024 brd 192.168.232.191 scope global host0
169.254.0.0/16 dev host0 proto kernel scope link src 169.254.193.148 metric 2048
192.168.232.176/28 dev host0 proto kernel scope link src 192.168.232.176 metric 1024
root@root ~]# ping 1.1.1.1
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
64 bytes from 1.1.1.1: icmp_seq=1 ttl=48 time=14.0 ms
64 bytes from 1.1.1.1: icmp_seq=2 ttl=48 time=14.2 ms
I ignore why the container IP address is wrong. Any help would be appreciated :slight_smile:
EDIT: behaviour is the same using Archlinux host with ufw firewall enabled
It seems related to ufw on the host. When ufw is disabled, the container gets the correct address
ufw is probably blocking DHCP. Does this article help?
https://www.cyberciti.biz/faq/open-ufw-allow-dhcp-port-linux-command/
It does ! Thanks, it didn’t come to my mind the firewall could block an internal dhcp request but it makes sense
