It still finds the wifi stick through “lsusb” but there is no way to connect to any network.
Hi @uzhBFDVHDBSBHIVBS, and welcome!
More information is definitey needed. Please see:
- [HowTo] Provide System Information,
- [HowTo] post screenshots and links,
- [HowTo] Increase your chances of solving your issue, and
- [HowTo] Use preformatting in a forum post.
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead off like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Does this help? I really dont understand what Im doing tbh.
Kernel: 5.10.84-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=274e5602-f24e-4220-82b9-e72f9d121b12 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX II (MS-7C02) v: 3.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: H.00
date: 09/17/2020
RAM: total: 31.37 GiB used: 6.77 GiB (21.6%)
RAM Report:
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4199 high: 4200 min/max: N/A cores: 1: 4200 2: 4200
3: 4199 4: 4199 5: 4200 6: 4200 7: 4200 8: 4199 9: 4200 10: 4200 11: 4200
12: 4199 bogomips: 100845
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: PC Partner Limited driver: amdgpu v: kernel bus-ID: 26:00.0
chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: AMD Radeon RX 470 Graphics (POLARIS10 DRM 3.40.0
5.10.84-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus-ID: 26:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 28:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.10.84-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 22:00.0
IF: enp34s0 state: down mac: <filter>
Device-2: Ralink 802.11 n WLAN type: USB driver: N/A bus-ID: 1-2:2
chip-ID: 148f:e670 class-ID: 0000 serial: <filter>
IF-ID-1: enp3s0f0u8 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: pan1 state: down mac: <filter>
IP v4: <filter> scope: global
Device-1: Xiaomi Mi/Redmi series (RNDIS) type: USB driver: rndis_host
v: kernel bus-ID: 1-8:4 chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb v: 0.8 bus-ID: 3-1:2 chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 1.13 TiB used: 753.98 GiB (65.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: B1D2 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZRX-00A8LB0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1A01
scheme: MBR
ID-1: / raw-size: 223.57 GiB size: 219.06 GiB (97.98%)
used: 205.88 GiB (94.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 274e5602-f24e-4220-82b9-e72f9d121b12
ID-2: /mnt/Storage raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 548.1 GiB (59.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Storage
uuid: 21242928-ed3b-468b-8907-dff3d3045d56
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-2:2 info: Ralink 802.11 n WLAN type: WiFi driver: N/A
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 450mA chip-ID: 148f:e670
Device-2: 1-8:4 info: Xiaomi Mi/Redmi series (RNDIS)
type: Bluetooth,CDC-Data driver: rndis_host interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 2717:ff80 class-ID: 0a00
serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Device-2: 3-2:3 info: Areson Corp 2.4G Receiver type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 25a7:fa67 class-ID: 0301
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 53.9 C mobo: 28.0 C gpu: amdgpu temp: 32.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1744 fan-3: 0 fan-4: 0 fan-5: 0 fan-6: 0
gpu: amdgpu fan: 1066
Processes: 325 Uptime: 3h 20m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1423 lib: 487
flatpak: 0 Shell: Bash v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
That would explain it.
Please provide the output for:
sudo lsusb
Okay, thanks. Im still kind of confused because it worked perfectly yesterday. Where did the driver go?
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 25a7:fa67 Areson Technology Corp 2.4G Receiver
Bus 003 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 2717:ff80 Xiaomi Inc. Mi/Redmi series (RNDIS)
Bus 001 Device 002: ID 148f:e670 Ralink Technology, Corp. 802.11 n WLAN
Now that I don’t know.
After spending some time reading, according to this page it would seem the driver is built into the kernel:
The device is supported by kernel versions 2.6.34 and newer according to the LKDDb:
So, this is just a hunch based on this page:
Try installing linux-firmware
from the core
repository:
pamac install linux-firmware
I tried that just now and restarted my pc. It doesn’t seem to change anything though
Bummer! Oh well…
I don’t know what, if any good I’ll be able to gather from this, but it might do someone some good. Please provide a new, update output for:
inxi --admin --verbosity=7 --filter --width
And then the output for:
rfkill
…please.
Also, like I said, I don’t know what to do or where to go next. I’m wingin’ it here. With that in mind, just know that I might dissapear any time now.
Uhm, okay. Thanks anyway.
Heres the “inxi --admin --verbosity=7 --filter --width”
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
date: 09/17/2020
RAM: total: 31.36 GiB used: 2.68 GiB (8.5%)
RAM Report:
Speed (MHz): avg: 4200 min/max: N/A cores: 1: 4200 2: 4200 3: 4200 4: 4200
5: 4200 6: 4200 7: 4200 8: 4200 9: 4200 10: 4200 11: 4200 12: 4200
bogomips: 100830
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
OpenGL: renderer: AMD Radeon RX 470 Graphics (POLARIS10 DRM 3.42.0
5.15.21-1-MANJARO LLVM 13.0.0)
class-ID: 0403
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
IF-ID-1: enp3s0f0u8 state: unknown speed: -1 duplex: half mac: <filter>
Local Storage: total: 1.13 TiB used: 753.78 GiB (65.3%)
scheme: MBR
used: 205.68 GiB (93.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
serial: <filter>
System Temperatures: cpu: 33.0 C mobo: 28.0 C gpu: amdgpu temp: 31.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1748 fan-3: 0 fan-4: 0 fan-5: 0 fan-6: 0
gpu: amdgpu fan: 1058
Processes: 300 Uptime: 24m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1424 lib: 487 flatpak: 0
And heres the “rfkill”
ID TYPE DEVICE SOFT HARD
0 bluetooth hci0 unblocked unblocked
I have also just been reminded to make sure the USB device has sufficient power. That’s something that I frequently, and quite easily forget.
Edit:
Ensure that it’s not connected VIA USB hub or something like that.
Im 100% confused by this.
Do you mean the Wifi stick isnt getting enough power?
Can I adjust how much power comes through the USB Slot I use?
Its plugged in one of the Motherboards USB Slots directly.
Indeed. When using unpowered USB hubs, the power must be split between all the devices on the hub, which can lead to problems.
No.
That’s perfect!
IF perhaps, you can get your hands on another one you know works, to test with, you can at least rule out or confirm a hardware problem.
That was actually the first thing I thought of
I tested it with a laptop running Windows. The stick works there.
I also tested another Wifi stick, works on the Laptop but not my PC.
Also: The light on the stick blinks the same way on either computer. Not sure if this is valuable info in any way.
Well, my knowledge is officially exhausted. I really have no further idea.
Except:
I have read somewhere to install the mt7601u
driver. Which is the AUR:
$ pamac search 7601
mt7601u-dkms-git latest-1 AUR
mt7601u DKMS driver
But that’s for MediaTek, so I left it. Then, just now I saw:
- 2011: Ralink was acquired by MediaTek
(Source)
No, I don’t know how reliable a source that is.
So I thought trying the driver might be a good idea. And seeing as it’s in the AUR, it can be easily installed with:
pamac build mt7601u-dkms-git
So, go ahead and try it, and see if it works.
The light on the Wifi stick is now just constantly on instead of blinking but apart from that nothing changed
Updated
…please?
Sure, there you go
date: 09/17/2020
RAM: total: 31.36 GiB used: 2.14 GiB (6.8%)
RAM Report:
3: 4200 4: 4200 5: 4200 6: 4200 7: 4199 8: 4200 9: 4200 10: 4200 11: 4200
12: 4200 bogomips: 100827
class-ID: 0403
Device-2: Ralink 802.11 n WLAN type: USB driver: N/A bus-ID: 1-2:6
Local Storage: total: 1.13 TiB used: 753.79 GiB (65.3%)
scheme: MBR
used: 205.69 GiB (93.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
Device-1: 1-2:6 info: Ralink 802.11 n WLAN type: WiFi driver: N/A
serial: <filter>
System Temperatures: cpu: 27.0 C mobo: 26.0 C gpu: amdgpu temp: 27.0 C
Processes: 294 Uptime: 14m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1426 lib: 487 flatpak: 0
Nope. Sadly still looks like the error.
OK, I’m officially out of ideas. I really have no idea what else to try. Or even think, because to me it looks like a hardware problem. And if it is, no amount of tinkering with software will help…
Well thats annoying
Thank you very much for all your work though!
try to load from a live-iso and check if your hardware get’s detected with the live iso, if possible try your hardware at another system to figure out if it’s a hardware related problem.
