TL;DR: the generation of a grub config gets stuck for 12h+ (as in generates no more output in the terminal). Also sudo parted -l
and sudo fdisk -l
get stuck too after sdc.
Hello there
I installed manjaro (the xfce flavour) alongside windows 10 a few weeks ago. Everything worked fine until I tried switching to a newer kernel (5.15). I think I noticed grub getting stuck while generating a new grub config. Which looked something like this:
[dermuuux@OldButGold ~]$ sudo update-grub
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
The os-prober then gets stuck for even 12h+ (I let it run overnight one time, because I read the os-prober can take some time on certain machines).
So I researched this os-prober thing and ended up changing GRUB_DISABLE_OS_PROBER=false
to GRUB_DISABLE_OS_PROBER=true
in /etc/grub/default.
After doing that grub generated it’s config as it should and I managed to upgrade the kernel.
But now I can’t boot into my windows 10. And I can’t figure out why or where os-prober gets stuck. That’s why I’m coming to you asking for help.
Here are some informations about my system:
[dermuuux@OldButGold ~]$ inxi -Fxxxza --no-host
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e11c8490-f553-479b-ac67-d931f7cd81d8 rw quiet
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P7P55D-E PRO v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 1703
date: 06/26/2012
Info: model: Intel Core i7 K 875 bits: 64 type: MT MCP arch: Nehalem
family: 6 model-id: 0x1E (30) stepping: 5 microcode: 0xA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1440 high: 2152 min/max: 1200/2934 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1204 2: 1341
3: 1204 4: 2152 5: 1204 6: 1222 7: 1204 8: 1992 bogomips: 47097
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: l1tf
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 44
size: 1107x623mm (43.6x24.5") diag: 1270mm (50")
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
vendor: ASUSTeK M4A785/P7P55 driver: r8169 v: kernel port: d800
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 5.46 TiB used: 62.69 GiB (1.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000525SV
type: HDD rpm: 7200 serial: <filter> rev: CV12 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST31000525SV
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD30EURS-63R8UY0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 0A80
scheme: GPT
ID-1: / raw-size: 98.1 GiB size: 96 GiB (97.86%) used: 62.69 GiB (65.3%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 30.5 C mobo: 30.0 C gpu: amdgpu temp: 34.0 C
Fan Speeds (RPM): cpu: 878 psu: 0 case-1: 0 case-2: 0 gpu: amdgpu
fan: 1618
Power: 12v: 12.15 5v: N/A 3.3v: 3.42 vbat: N/A gpu: amdgpu watts: 40.24
Processes: 256 Uptime: 1h 21m wakeups: 0 Memory: 7.76 GiB
used: 2.56 GiB (33.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 958 lib: 283 Shell: Bash v: 5.1.12
running-in: xfce4-terminal inxi: 3.3.10
[dermuuux@OldButGold ~]$ sudo parted -l
[sudo] password for dermuuux:
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sda: 1000GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 106MB 105MB primary ntfs
2 106MB 894GB 894GB primary ntfs
3 894GB 894GB 597MB primary ntfs msftres
4 894GB 1000GB 105GB primary ext4 boot
Model: ATA ST31000525SV (scsi)
Disk /dev/sdb: 1000GB
Disk Flags:
1 1049kB 1000GB 1000GB primary ntfs
Disk /dev/sdc: 1000GB
Disk Flags:
1 32,3kB 1000GB 1000GB primary
[dermuuux@OldButGold ~]$ sudo fdisk -l
Disk /dev/sda: 931,51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Samsung SSD 850
Disklabel type: dos
Disk identifier: 0xcacd885d
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 206847 204800 100M 7 HPFS/NTFS/exFAT
/dev/sda2 206848 1745711259 1745504412 832,3G 7 HPFS/NTFS/exFAT
/dev/sda3 1745713152 1746878463 1165312 569M 27 Hidden NTFS WinRE
/dev/sda4 * 1746878914 1952600063 205721150 98,1G 83 Linux
Disk /dev/sdb: 931,51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: ST31000525SV
Disklabel type: dos
Disk identifier: 0x6391841b
/dev/sdb1 2048 1953521663 1953519616 931,5G 7 HPFS/NTFS/exFAT
Disk /dev/sdc: 931,51 GiB, 1000204886016 bytes, 1953525168 sectors
Disklabel type: dos
Disk identifier: 0x2e092a02
/dev/sdc1 63 1953523119 1953523057 931,5G 42 SFS
[dermuuux@OldButGold ~]$ efibootmgr -v
EFI variables are not supported on this system.
[dermuuux@OldButGold ~]$ test -d /sys/firmware/efi && echo efi || echo bios
bios
[dermuuux@OldButGold ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 931,5G 0 disk
├─sda1 8:1 0 100M 0 part
├─sda2 8:2 0 832,3G 0 part
├─sda3 8:3 0 569M 0 part
└─sda4 8:4 0 98,1G 0 part /
sdb 8:16 0 931,5G 0 disk
└─sdb1 8:17 0 931,5G 0 part
sdc 8:32 0 931,5G 0 disk
├─sdc1 8:33 0 99M 0 part
└─sdc2 8:34 0 931,4G 0 part
sdd 8:48 0 2,7T 0 disk
sr0 11:0 1 1024M 0 rom
Now, after gathering these informations about my system, I noticed that sudo parted -l
and sudo fdisk -l
both get stuck (as in don’t generate anymore output in the terminal) after sdc. That’s why I included the output for lsblk
I don’t know if os-prober gets stuck on the same thing as parted and fdisk, but I thought I mention it.
Big thanks in advance for any help!
edit1: spelling
edit2: switched german console output to it’s english equivalent
