Just switched over from Windows after dabbling with Ubuntu in the past. Got my system and apps up and running and have checked orphans and not sure which are needed or can be deleted.
Apologies if its a silly question but still learning!
autoconf 2.71-1 core 2.3 MB
automake 1.16.4-1 core 1.6 MB
bison 3.7.6-1 core 2.5 MB
cups-pdf 3.0.1-6 extra 197.8 kB
fakeroot 1.25.3-2 core 141.6 kB
flex 2.6.4-3 core 994.3 kB
folks 0.14-5 extra 11.3 MB
gfbgraph 0.2.4-1 extra 497.9 kB
gst-python 1.18.4-1 extra 132.9 kB
gutenprint 5.3.4-1 extra 33.6 MB
libytnef 1:1.9.3-1 extra 206.1 kB
mailcap 2.1.53-1 extra 111.3 kB
make 4.3-3 core 1.6 MB
patch 2.7.6-8 core 202.5 kB
pkgconf 1.7.3-1 core 160.1 kB
python-pysmbc 1.0.23-2 extra 61.9 kB
python-reportlab 3.5.68-2 community 9.0 MB
splix 2.0.0-15 community 171.6 kB
Some of them (and more) will be needed and will get re-installed as soon as some AUR package is wanted and therefore the base-devel package group is required. splix and gutenprint are printer drivers - only @stu1978 knows whether he will need them - similar for cups-pdf, which can be good to have.
If all of those are removed, some programs functionality as intended and pre-configured for that edition might break - for example folks and gfbgraph
Itās not worth the effort IMO to remove those unless one specifically knows that they are not needed or wanted.
If you frequently use AUR build scripts you can install the base-devel metapackage and some the packages you see will not be shown as orphans - which is - not required by any package.
sudo pacman -Syu base-devel --needed
So unless - though unlikely - a package has a dependency not in the PKGBUILD you can safely remove all orphans.
I have xcursor-chameleon- (three colours) are now marked as an orphan. I took steps to download the zips some time ago - but I will continue using them, my favourite cursorsā¦
So really you need to know before you just decide to delete them all. I didnāt bother and it doesnāt hurt.
$ pacman -Qi software-center-web-jak
Optional Deps : None ā oh yeah can be removed?
Info pamac(Add/Remove Software)
Installed: software-center-web-jak 1.0.2.-1 Really?
Files
/usr/share/applications/discover-software-center-jak.desktop
/usr/share/webapps/software-center-web-jak/software-center-jak
Starting Menu ā Others ā Discover Web Software
$ ps ax | grep software
python /usr/share/webapps/software-center-web-jak/software-center-jak
Comment:
Discover Web Software has been installed by Manjaro(as a goodie I guess).
Obviously files of the installed (but identified as orphaned) package are in use.
Am I wrong? Please let me know.
The handling of so-called orphaned packages is not very sophisticated
and not only unexperienced users have difficulties to decide here what to do.
(true for any distribution, just GoboLinux tries to go in a different direction)
@Wollie
Thats ok but generates a lot confusion by the time.
The question is why the system thinks software-center-web-jak is orphaned?
and Im talking about software installed via standard manjaro installation process.
I have so far always kept it so that I have researched the indicated orphans in the net and if I was not sure whether that would be needed somehow, I have set them to expressly installed. Silence ā¦
Why?
Well, in this case because software-center-web-jak is an installed program.
Iāve never heard that programs can be orphaned unless they get deprecated(and no longer supported by libraries for example) but this is another story.
Before I switched to Manjaro, I had similar problems and after some years there were hundreds of orphaned packages simply because nobody cares.
So an orphaned package should be really orphaned and thrown away if not wanted (without deep thinking).
