I now have some orphaned files after installing pacnew-chaser (from the AUR) that I don’t really know what to do with:
autoconf
automake
bison
fakeroot
flex
make
patch
pkgconf
I was able to find out something about each, but can’t really do anything with them. Some seem to come from compiling from the AUR. Please give me a hint what should be marked as explicitly installed and what can go away!
Those are not “created”, those are packages that need to be installed from official repository before dealing with the AUR, otherwise you will have build failures
Ok, I don’t know if I’ll ever use the AUR again, so I marked them as explicitly installed for now and good riddance. That should have solved the problem.
