Hello,
i experienced yesterday a situation where i removed a few orphans and saw additional errors in journal after a reboot.
pacman -Qi mhwd-nvidia-570xx
Version : 570.211.01-1
Description : MHWD module-ids for nvidia 570.211.01
Architecture : any
URL : http://www.nvidia.com/
Licenses : LicenseRef-custom
Groups : None
Provides : None
Depends On : mhwd
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 1912,00 B
Packager : Mark Wagie <mark@manjaro.org>
Build Date : Di 13 Jan 2026 18:40:41 CET
Install Date : So 28 Jun 2026 11:43:06 CEST
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
$ pacman -Qi mhwd-nvidia-575xx
Version : 575.64.05-3
Description : MHWD module-ids for nvidia 575.64.05
Architecture : any
Groups : None
Provides : None
Depends On : mhwd
Required By : None
Optional For : None
Replaces : None
Installed Size : 1902,00 B
Build Date : Do 18 Dez 2025 19:27:54 CET
Install Date : So 28 Jun 2026 11:43:30 CEST
Install Script : No
I thought okay, there is None on Required By and the same with Optional For⦠as a general rule everyone recommend that its save to remove them.
Im also removed it on my AMD Laptop and got this errorās (that are vanished after reinstalling this packages):
Jun 28 11:37:14 koboldx-tuxedopulse15 kernel: i2c i2c-4: SMBus Timeout!
Jun 28 11:37:14 koboldx-tuxedopulse15 kernel: i2c i2c-4: Failed reset at end of transaction (01)
Jun 28 11:37:14 koboldx-tuxedopulse15 kernel: i2c i2c-4: Failed! (01)
Jun 28 11:44:48 koboldx-tuxedopulse15 pulseaudio[830]: Error opening PCM device front:1: No such file or directory
Isnāt it pure false to widespread recommend this info below, when i hit errors already even with manual investigation from every single orphan?
You cannot remove mhwd-<something> without removing parent mhwd package.
sudo pacman -Rns mhwd
The mentioned mhwd-nvidia- packages is truly orphans - they are not in the repo - but they used to be as they are part of mhwd-db package.
The recommendation in the update thread does not take into account if a system - for one reason or another - has lost track of a few packages.
The mentioned packages serve a database function only, and does not influence a running system in any way.
EDIT:2026-06-28T22:00:00Z
If you - for any reason - wish to keep mhwd around - reinstall the package
sudo pacman -Syu mhwd
mhwd package info
$ pamac info mhwd
Version : 0.6.6-6
Description : Manjaro Linux Hardware Detection library and application
URL :
Licenses : GPL-3.0-or-later
Repository : extra
Installed Size : 209,3 kB
Groups : --
Depends On : hwinfo mesa mhwd-db pacman
Optional Dependencies : grub: for choosing kernels [Installed]
lib32-mesa: for 32bit libgl support [Installed]
Required By : mhwd-nvidia mhwd-nvidia-390xx mhwd-nvidia-470xx mhwd-nvidia-580xx
Optional For : octopi
Provides : libmhwd.so=libmhwd.so-64
Replaces : --
Conflicts With : --
Packager : Philip Mueller <philm@manjaro.org>
Build Date : man 29 sep 2025 00:55:40 CEST
Install Date : ons 22 okt 2025 08:52:04 CEST
Backup files : --
mhwd-db package info
$ pamac info mhwd-db
Version : 20260305-1
Description : Manjaro Linux Hardware Detection Database
URL : https://gitlab.manjaro.org/applications/mhwd-db
Repository : extra
Installed Size : 47,5 kB
Groups : --
Depends On : libnotify mhwd-amdgpu mhwd-ati mhwd-nvidia>=455 mhwd-nvidia-390xx mhwd-nvidia-470xx
mhwd-nvidia-580xx nvidia-driver-assistant
Optional Dependencies : --
Required By : mhwd
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Build Date : fre 27 mar 2026 23:06:11 CET
Install Date : sĆøn 29 mar 2026 10:24:17 CEST
Install Reason : Installed as a dependency for another package
Backup files : --
TBH, im not relying on Legacy Drivers⦠but i donāt like that idea that a Nvidia 900 Gen, no longer gets supported. I understand that backporting patches takes time.
I just feel sorry for the people who are left alone and they probably forced to use Nouveau driver or leaving Manjaro to a Distro like Mint/Kubuntu where ongoing support is granted for several more yearās.
But 6.18 LTS still has support for 570xx and 575xx for a certain time, so idk why you write its coming soon.
