Come on you replied twice to say nothing of importance.
Iām sorry I forgot about that, I just did it and OriginThinSetup is being installed again, we will see if it crashes when it is in the middle of its download or not
delete a folder as you told me and now the game starts, I hear the famous āEA SPORTSā but the whole screen is black. Everything is in automatic and resolution 1280x720
You can try some workarounds:
Navigate to ../compatdata/1506830/pfx/drive_c/users/steamuser/Documents/FIFA 22
and edit fifasetup.ini
Change from default DX12 to Dx11 by setting it to 1
DIRECTX_SELECT = 1
If that doesnāt help you can try some tweaks for DX12:
DIRECTX_SELECT = 0
MSAA_LEVEL = 3
RENDERINGQUALITY = 4
(May not be necessary)
WAITFORVSYNC = 0
After you saved that file, do not open the Graphics settings in the GUI on launch since they will be reset.
If nothing of that helps Iām out of ideas and, as pointed out it could be the GPU.
Thanks friend, DIRECTX_SELECT = 1 was enough. For those who have the same problem, my solution was first to delete the folder 1506830 (answer 4) and then the answer 24
