Kernel: 6.14.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
root=UUID=41fd8083-4e6d-43c6-b78e-8c11b36d8410 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: ROG CROSSHAIR VIII FORMULA v: Rev X.0x
serial: <filter> part-nu: SKU uuid: 45b5c92c-34fc-b797-6ece-fc3497b76ecd
UEFI: American Megatrends v: 4201 date: 04/26/2022
ID-1: hidpp_battery_1 charge: 60% condition: N/A volts: 3.9 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: <filter> status: discharging
System RAM: total: 32 GiB available: 31.25 GiB used: 10.65 GiB (34.1%)
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: G Skill Intl
part-no: F4-3200C14-8GFX serial: N/A
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:03.1
children: 1: 09:00.0 class-ID: 0604 type: bridge children: 1: 0a:00.0
class-ID: 0604 type: bridge children: 1: 0b:00.0 class-ID: 0300
type: display 2: 0b:00.1 class-ID: 0403 type: audio
Slot: 1 type: PCIe status: available length: long volts: 3.3
bus-ID: 00:1f.7
Slot: 2 type: PCIe status: available length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 3 type: PCIe status: available length: short volts: 3.3
bus-ID: 00:1f.7
Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP
arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3599 min/max: 550/3801 boost: enabled
base/boost: 3800/4850 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3599 2: 3599 3: 3599 4: 3599
5: 3599 6: 3599 7: 3599 8: 3599 9: 3599 10: 3599 11: 3599 12: 3599
13: 3599 14: 3599 15: 3599 16: 3599 bogomips: 121599
xsaves xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 14 [Radeon RX 5500/5500M /
Pro 5500M] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-1
code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3
bus-ID: 0b:00.0 chip-ID: 1002:7340 class-ID: 0300
Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 6080x2160 s-dpi: 96 s-size: 1608x571mm (63.31x22.48")
s-diag: 1706mm (67.18")
Monitor-1: DP-1 pos: primary,right model: LG (GoldStar) 27GN950
serial: <filter> built: 2021 res: mode: 3840x2160 hz: 144 scale: 100% (1)
dpi: 163 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green: x: 0.267
y: 0.686 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
modes: 3840x2160, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
1440x900, 1280x800, 1280x720, 1024x768, 800x600, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unknown tag 112
Monitor-2: HDMI-A-1 pos: left model: Idek Iiyama PLE2607WS
serial: <filter> built: 2008 res: mode: 2240x1400 hz: 60 scale: 100% (1)
dpi: 103 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green: x: 0.282
y: 0.600 blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
size: 550x344mm (21.65x13.54") diag: 649mm (25.5") ratio: 16:10
modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
720x480, 640x480, 720x400
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5500 XT (radeonsi
navi14 LLVM 19.1.7 DRM 3.61 6.14.0-1-MANJARO) device-ID: 1002:7340
memory: 7.81 GiB unified: no
API: Vulkan v: 1.4.309 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon RX 5500 XT (RADV NAVI14) driver: mesa radv v: 25.0.3-arch1.1
device-ID: 1002:7340 surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio vendor: ASRock
bus-ID: 0b:00.1 chip-ID: 1002:ab38 class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.14.0-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 1 link-max: lanes: 4 port: N/A bus-ID: 03:00.0 chip-ID: 1d6a:11b1
class-ID: 0200
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
IF-ID-1: wg0-mullvad state: unknown speed: 10000 Mbps duplex: full
mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
Info: services: NetworkManager,wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0029
class-ID: e001
Device-2: Microsoft Nano Transceiver v1.0 for Bluetooth
driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-3.1:5 chip-ID: 045e:0745 class-ID: 0300
Local Storage: total: 1.26 TiB used: 923.2 GiB (71.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 830 Series
family: based SSDs size: 119.24 GiB block-size: physical: 512 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 3B1Q temp: 37 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 9y 314d 1h cycles: 4982
written: 37.39 TiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1B6Q temp: 42 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 4y 309d 2h cycles: 1297
written: 34.96 TiB
ID-3: /dev/sdc maj-min: 8:32 vendor: Lexar model: 256GB SSD
size: 238.47 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: .0 temp: 38 C
scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 116d 20h cycles: 687
read: 41 KiB written: 93 KiB
ID-1: / raw-size: 117.19 GiB size: 114.79 GiB (97.95%)
used: 50.97 GiB (44.4%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 41fd8083-4e6d-43c6-b78e-8c11b36d8410
ID-2: /boot/efi raw-size: 2.05 GiB size: 2.05 GiB (99.80%)
used: 288 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/sda2 maj-min: 8:2
label: N/A uuid: B6FE-6408
ID-3: /home raw-size: 930.66 GiB size: 914.98 GiB (98.31%)
used: 829.28 GiB (90.6%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: f18e7382-b9e7-4ab1-84ec-8fc5127f31d3
ID-4: /run/media/jorgecpd/root raw-size: 238.33 GiB
size: 233.53 GiB (97.99%) used: 42.95 GiB (18.4%) fs: ext4
block-size: 4096 B dev: /dev/sdc2 maj-min: 8:34 label: root
uuid: 6c260c5f-0db1-468c-bf06-2b3c928b1a0d
ID-1: /dev/sdb1 maj-min: 8:17 size: 868 MiB fs: vfat label: N/A
uuid: A567-7EF7
ID-2: /dev/sdc1 maj-min: 8:33 size: 149 MiB fs: vfat label: boot
uuid: 128E-E778
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5.3:4 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Device-2: 1-5.4:5 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:1872 class-ID: 0300
serial: <filter>
Device-3: 1-6:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Hub-5: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Hub-6: 3-2.2:4 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8142
Hub-7: 3-2.2.2:30 info: VIA Labs VL812 Hub ports: 4 rev: 2.0
chip-ID: 2109:0812 class-ID: 0900
Device-1: 3-2.2.2.2:31 info: Logitech Lightspeed Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c539 class-ID: 0300
Device-2: 3-2.2.4:51 info: LG USA Monitor Controls
type: HID,abstract (modem),CDC-data driver: cdc_acm,hid-generic,usbhid
interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
chip-ID: 043e:9a8a class-ID: 0a00 serial: <filter>
Hub-8: 3-3:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
Device-1: 3-3.1:5 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
Device-2: 3-3.2:7 info: HP HP Color LaserJet Pro M478f-9f type: printer
driver: usblp interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 2mA chip-ID: 03f0:c52a class-ID: 0701 serial: <filter>
Hub-9: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-10: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
Hub-11: 4-2.2:4 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
chip-ID: 0451:8140 class-ID: 0900
Hub-12: 4-2.2.2:6 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
Hub-13: 4-3:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
Hub-14: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-15: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 48.0 C mobo: 43.0 C gpu: amdgpu temp: 52.0 C
mem: 0.0 C
Fan Speeds (rpm): cpu: 817 gpu: amdgpu fan: 1481
Packages: 1741 pm: pacman pkgs: 1731 libs: 463 tools: pamac pm: flatpak
pkgs: 10
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
4: https://mirror.23m.com/manjaro/stable/$repo/$arch
5: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
6: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
7: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
8: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
CPU top: 5 of 424
1: cpu: 6.7% command: firefox pid: 184549 mem: 702.4 MiB (2.1%)
2: cpu: 6.2% command: firefox pid: 185860 mem: 373.2 MiB (1.1%)
3: cpu: 6.0% command: mullvad-daemon pid: 823 mem: 51.4 MiB (0.1%)
4: cpu: 5.1% command: firefox pid: 2854 mem: 1368.4 MiB (4.2%)
5: cpu: 3.6% command: firefox pid: 181347 mem: 678.6 MiB (2.1%)
Memory top: 5 of 424
1: mem: 2288.7 MiB (7.1%) command: qbittorrent pid: 1840 cpu: 2.1%
2: mem: 1368.4 MiB (4.2%) command: firefox pid: 2854 cpu: 5.1%
3: mem: 829.2 MiB (2.5%) command: firefox pid: 154150 cpu: 0.9%
4: mem: 797.2 MiB (2.4%) command: firefox pid: 3022 cpu: 1.4%
5: mem: 739.4 MiB (2.3%) command: firefox pid: 116219 cpu: 0.3%
Processes: 424 Power: uptime: 1d 17h 11m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
