I don’t think this will solve your problem.
If you don’t have the bluez packages in your cache try the Arch Linux Archive (ALA). You can install downgrade
to ease the search.
to ease the search.
So, i’ve applied
sudo DOWNGRADE_FROM_ALA=1 downgrade bluez
and selected version 5.61.1.
This is the first time I use downgrade and I am still unsure about dependencies, but everything seems ok.
Blueberry does no longer work. Anyway I have usedbluetoothctl
and I am now connected to my headset.
But it’s still impossible to get connected to my keyboard.
connect 2B:24:13:DB:7C:99
Attempting to connect to 2B:24:13:DB:7C:99
Failed to connect: org.bluez.Error.Failed Input/output
I also downgrades bluez-utils
and bluez-libs
to the same version.
