@xircon already tick that but not effecting…
Opulent October (2018) Screenshots
Just for fun:
https://imgur.com/boCwXc1
Theme: oomox-arc-base with “dracula” colour theme
icons: Ozon-Teal, with moka as fallback
I googled “sesame Street wallpapers” and browsed the image results, then visited the source site of various images. Found a “best sesame Street wallpapers” type of page and downloaded a few wallpapers there, including this one.
But you can just Google “sesame Street wallpaper zombie” for this specific wallpaper.
I am very boring nowadays, so I hardly customize stuff. Specially since I like Manjaro defaults a lot.
The picture is from Unsplash by the user Bence Boros.
@GrayJack could you help me with installing your configs? I ■■■■■■■ LOVE this desktop. I see your fetch says KDE but this sure as hell looks like i3 with polybar… If you could PM me, I’d really appreciate it!
Here are the conky files:
conkyrc:
conky.config = {
background = false,
update_interval = 1,
override_utf8_locale = true,
double_buffer = true,
no_buffers = true,
text_buffer_size = 2048,
imlib_cache_size = 0,
own_window = true,
own_window_type = 'normal',
own_window_transparent = true,
own_window_argb_visual = true,
own_window_hints = 'undecorated,below,sticky,skip_taskbar,skip_pager',
border_inner_margin = 0,
border_outer_margin = 0,
minimum_width = 213, minimum_height = 700,--width height
alignment = 'middle_left',
gap_x = 10,
gap_y = 0,
draw_shades = true,
draw_outline = false,
draw_borders = false,
draw_graph_borders = false,
use_xft = true,
font = 'pftempestafivecondensed:size=6',
xftalpha = 0.5,
uppercase = false,
lua_load = '~/.conky/Conky_Revisited_2/Conky_Square_Vertical/settings.lua',
-- lua_load = 'settings.lua',
lua_draw_hook_pre = 'start_widgets',
conky.text = [[
settings.lua:
---------------- USER CONFIGURATION ----------------
Change the parameters below to fit your needs.
-- Colors
HTML_color_battery = "#FFFFFF"
HTML_color_drive_1 = "#FFFFFF"
HTML_color_drive_2 = "#FFFFFF"
HTML_color_drive_3 = "#FFFFFF"
HTML_color_CPU = "#FFFFFF"
HTML_color_RAM = "#FFFFFF"
HTML_color_CPURAM = "#FFFFFF"
HTML_color_INFO = "#FFFFFF"
HTML_color_BORDER = "#34BE5B"
transparency_battery = 0.5
transparency_drive_1 = 0.5
transparency_drive_2 = 0.5
transparency_drive_3 = 0.5
transparency_CPU = 0.5
transparency_RAM = 0.5
transparency_CPURAM = 0.5
transparency_INFO = 0.5
transparency_border = 0.8
Show battery:
true
false
battery = true
Battery number. Default=BAT0. Change this number if you get following errors:
conky: can't open /sys/class/power_supply/BAT0/uevent
conky: can't open /proc/acpi/battery/BAT0/state: No such file or directory
Try with number BAT1 or BAT2 e.t.c.
battery_number="BAT1"
Modes:
1 = Show squared background area
2 = No background area (style 1)
3 = Hides text. Show circular background area
mode = 1
-- Path of drives for free space status.
drive_paths = {"/", "/home", "/mnt/Data"}
-- Names of drives for free space status.
drive_names = {"Root", "Home", "Data"}
-- Number of drives to show free space status. Adjust the conky "height"-parameter in config manually to adjust for the increase in Conky height when adding more drives.
drives = 3
-- Number of CPUs
number_of_cpus = 4
-- Network-interfaces
iface_c = "enp4s0" --wired
iface_w = "wlp5s0" --wireless
-- Mount point local for external server
server_path = "/mnt/Mediashare"
-- Special border width
special_border = 2
-- Normal border size
border_size = 0
-- Distance between each area
gap_y = -1
-- DON'T EDIT BELOW IF YOU DO NOT KNOW WHAT YOU ARE DOING!!!
require 'cairo'
operator = {CAIRO_OPERATOR_SOURCE,
CAIRO_OPERATOR_CLEAR
operator_transpose = {CAIRO_OPERATOR_CLEAR,
function hex2rgb(hex)
hex = hex:gsub("#","")
return (tonumber("0x"..hex:sub(1,2))/255), (tonumber("0x"..hex:sub(3,4))/255), tonumber(("0x"..hex:sub(5,6))/255)
end
r_battery, g_battery, b_battery = hex2rgb(HTML_color_battery)
r_CPU, g_CPU, b_CPU = hex2rgb(HTML_color_CPU)
r_RAM, g_RAM, b_RAM = hex2rgb(HTML_color_RAM)
r_CPURAM, g_CPURAM, b_CPURAM = hex2rgb(HTML_color_CPURAM)
r_INFO, g_INFO, b_INFO = hex2rgb(HTML_color_INFO)
r_border, g_border, b_border = hex2rgb(HTML_color_BORDER)
r_drive_1, g_drive_1, b_drive_1 = hex2rgb(HTML_color_drive_1)
r_drive_2, g_drive_2, b_drive_2 = hex2rgb(HTML_color_drive_2)
r_drive_3, g_drive_3, b_drive_3 = hex2rgb(HTML_color_drive_3)
drive_colors = {{r_drive_1, g_drive_1, b_drive_1,transparency_drive_1},
{r_drive_2, g_drive_2, b_drive_2,transparency_drive_2},
{r_drive_3, g_drive_3, b_drive_3,transparency_drive_3}}
function draw_square(cr,pos_x,pos_y,rectangle_x,rectangle_y,color1,color2,color3, trans)
cairo_set_operator(cr, operator[mode])
cairo_set_source_rgba(cr, color1,color2,color3,trans)
cairo_set_line_width(cr, 2)
cairo_rectangle(cr, pos_x, pos_y, rectangle_x,rectangle_y)
cairo_fill(cr)
cairo_set_operator(cr, operator_transpose[mode])
cairo_set_line_width(cr, special_border)
cairo_set_source_rgba(cr, color1,color2,color3, trans)
cairo_move_to(cr,pos_x+3,pos_y+3)
cairo_rel_line_to(cr,rectangle_x-6,0)
cairo_rel_line_to(cr,0, rectangle_y-6)
cairo_rel_line_to(cr,-(rectangle_x-6))
cairo_close_path(cr)
cairo_stroke(cr)
cairo_set_source_rgba(cr, r_border,g_border,b_border,transparency_border)
cairo_set_line_width(cr, border_size)
cairo_stroke(cr)
end
function draw_battery(cr,pos_x, pos_y,start_rect_height,color1,color2,color3,trans,gap_y_text)
set_battery_blocks_x = 0
battery_gap_y = (start_rect_height/2)-27/2+pos_y
cairo_move_to(cr,pos_x,battery_gap_y)
cairo_rel_line_to(cr,64,0)
cairo_rel_line_to(cr,0,((27-10)/2))
cairo_rel_line_to(cr,5,0)
cairo_rel_line_to(cr,0,10)
cairo_rel_line_to(cr,-5,0)
cairo_rel_line_to(cr,-64,0)
cairo_fill(cr)
number_of_charges = math.floor((12 / 100)*tonumber(conky_parse('${battery_percent ' .. battery_number .. '}')))
for i=1,number_of_charges do
cairo_rectangle(cr,pos_x+3+set_battery_blocks_x,3+battery_gap_y,3,21)
cairo_fill(cr)
set_battery_blocks_x = set_battery_blocks_x + 5
end
percent_font_size = 21
cairo_set_font_size(cr,percent_font_size)
cairo_move_to(cr,pos_x+69+10, gap_y_text+pos_y)
percent = conky_parse('${battery_percent ' .. battery_number .. '}')
--ct = cairo_text_extents_t:create()
--cairo_text_extents(cr,percent,ct)
if string.len(percent) == 1 then
cairo_show_text(cr,"0" .. percent .. "%")
elseif string.len(percent) == 3 then
cairo_show_text(cr,"100%")
else
cairo_show_text(cr,percent .. "%")
end
cairo_move_to(cr,pos_x+69+10, gap_y_text+18+pos_y)
cairo_set_font_size(cr,12)
status = conky_parse('${battery ' .. battery_number .. '}')
if string.find(status, "discharging") then
status = "Discharging"
elseif string.find(status, "charging") then
status = "Charging"
elseif string.find(status, "charged") then
status = "Charged"
end
if status == "" then
status = "N/A"
end
cairo_show_text(cr, status)
cairo_move_to(cr,pos_x+69+10, gap_y_text+18+14+pos_y)
battery_time = conky_parse('${battery_time ' .. battery_number .. '}')
if battery_time == "" then
battery_time = "AC-power"
end
cairo_show_text(cr, battery_time)
end
function draw_folder(cr,x_pos,y_pos,start_rect_height,hdd,folder_name,r_color_drive,g_color_drive,b_color_drive,transparency_drive,gap_y_text)
-- Draw indicator
cairo_set_source_rgba(cr,r_color_drive,g_color_drive,b_color_drive,transparency_drive)
local distance_between_arcs = 0
local number_of_arcs = 20
local arcs_length = (360 - (number_of_arcs*distance_between_arcs)) / number_of_arcs
local start_angel = 270
local used_blocks = math.floor((number_of_arcs / 100) * tonumber(conky_parse('${fs_used_perc ' .. hdd .. '}')))
local radius_outer = 34
local radius_inner = 24
local radius = 29
-- cairo_arc(cr,x_pos+10+34,(start_rect_height/2)+y_pos,radius_outer,start_angel*math.pi/180,(start_angel+360)*math.pi/180)
-- cairo_stroke(cr)
-- cairo_arc(cr,x_pos+10+34,(start_rect_height/2)+y_pos,radius_inner,start_angel*math.pi/180,(start_angel+360)*math.pi/180)
-- cairo_stroke(cr)
cairo_set_line_width(cr, 6)
cairo_arc(cr,x_pos+10+34,(start_rect_height/2)+y_pos,radius,start_angel*math.pi/180,(start_angel+360)*math.pi/180)
cairo_stroke(cr)
cairo_set_line_width(cr, 3)
for i=1, used_blocks do
cairo_arc(cr, x_pos+10+34,(start_rect_height/2)+y_pos,radius,start_angel*math.pi/180,(start_angel+arcs_length)*math.pi/180)
cairo_stroke(cr)
start_angel = start_angel+arcs_length+distance_between_arcs
end
cairo_move_to(cr,x_pos+10+34-15,(start_rect_height/2-5.5)+y_pos)
cairo_rel_line_to(cr,15,-9)
cairo_rel_line_to(cr,15,9)
cairo_rel_line_to(cr,0,4)
cairo_rel_line_to(cr,-15,-9)
cairo_rel_line_to(cr,-15,9)
cairo_fill(cr)
cairo_move_to(cr,x_pos+10+34-15+24,(start_rect_height/2-5.5)-6+y_pos)
cairo_rel_line_to(cr,4,2)
cairo_rel_line_to(cr,0,-5)
cairo_rel_line_to(cr,-4,0)
cairo_fill(cr)
cairo_move_to(cr,x_pos+10+34-15+4,(start_rect_height/2-5.5)+5+y_pos)
cairo_rel_line_to(cr,11,-7)
cairo_rel_line_to(cr,11,7)
cairo_rel_line_to(cr,0,15)
cairo_rel_line_to(cr,-(11*2-math.abs(-8))/2,0)
cairo_rel_line_to(cr,0,-6)
cairo_rel_line_to(cr,-8,0)
cairo_rel_line_to(cr,0,6)
cairo_fill(cr)
str = folder_name .. ": " .. conky_parse('${fs_used_perc ' .. hdd .. '}') .. "%"
cairo_set_font_size(cr, 21)
cairo_move_to(cr,x_pos+10+34+34+10,gap_y_text+y_pos)
cairo_show_text(cr, conky_parse('${fs_used_perc ' .. hdd .. '}') .. "%")
cairo_move_to(cr, x_pos+10+34+34+10,gap_y_text+18+y_pos)
cairo_show_text(cr,folder_name .. " used")
cairo_move_to(cr, x_pos+10+34+34+10,gap_y_text+18+14+y_pos)
cairo_show_text(cr,conky_parse('${fs_used ' .. hdd .. '}') .. "/" .. conky_parse('${fs_size ' .. hdd .. '}'))
end
function draw_cpu(cr,number_of_cpus,x_pos,y_pos,r,g,b,transparency,gap_y_text)
cairo_set_source_rgba(cr,r,g,b,transparency)
multipler = 68/100
for i=1,number_of_cpus do
cairo_rectangle(cr,x_pos+((68-(5*(number_of_cpus-1)))/number_of_cpus+5)*(i-1),y_pos+68+10,(68-(5*(number_of_cpus-1)))/number_of_cpus,-multipler*tonumber(conky_parse('${cpu cpu' .. tostring(i) .. '}')))
cairo_fill(cr)
end
cairo_move_to(cr,x_pos+68+10,gap_y_text+y_pos)
cairo_show_text(cr, conky_parse('${cpu cpu0}' .. "%"))
cairo_move_to(cr, x_pos+68+10,gap_y_text+18+y_pos)
cairo_show_text(cr, conky_parse("CPU temp: " .. "${execi 10 sensors | grep 'Core 0' |cut -c 17-18}" .. "°C"))
cairo_move_to(cr, x_pos+68+10,gap_y_text+18+14+y_pos)
cairo_show_text(cr,conky_parse("Speed: " .. '${freq_g 0}' .. "GHz"))
end
function draw_ram(cr,x_pos,y_pos, radius,r_RAM, g_RAM, b_RAM, transparency_RAM,gap_y_text)
cairo_set_source_rgba(cr,r_RAM,g_RAM,b_RAM,transparency_RAM)
local align_middle = 14 -- 50 pixel height
cairo_arc(cr,x_pos+radius,y_pos+radius+align_middle,radius,180*math.pi/180,(180+90)*math.pi/180)
cairo_arc(cr,x_pos+radius+(68-2*radius),y_pos+radius+align_middle,radius,-90*math.pi/180,(0)*math.pi/180)
cairo_arc(cr,x_pos+radius+(68-2*radius),y_pos+radius+20+align_middle,radius,0*math.pi/180,(90)*math.pi/180)
cairo_arc(cr,x_pos+radius,y_pos+radius+20+align_middle,radius,90*math.pi/180,(180)*math.pi/180)
cairo_fill(cr)
local multipler = 7/100
local free_memory = math.floor((conky_parse('${memperc}'))*multipler)
for i=1, 7 do
cairo_move_to(cr,x_pos+radius+(8*(i-1))-2,y_pos+radius+20+align_middle+10+1+2+1)
cairo_rel_line_to(cr,4,0)
cairo_arc(cr,x_pos+radius+(8*(i-1)),y_pos+radius+20+align_middle+10+1+2+1+4,2,0*math.pi/180,(180)*math.pi/180)
if i <= free_memory then
cairo_stroke_preserve(cr)
cairo_fill(cr)
else
cairo_stroke(cr)
end
cairo_move_to(cr,x_pos+radius+(8*(i-1))+2,y_pos+align_middle-4)
cairo_arc(cr,x_pos+radius+(8*(i-1)),y_pos+align_middle-4-4,2,180*math.pi/180,(0)*math.pi/180)
cairo_fill(cr)
else
cairo_stroke(cr)
end
end
cairo_move_to(cr,x_pos-1+33-22,y_pos+align_middle+1+19+8)
cairo_show_text(cr, "RAM")
cairo_move_to(cr,x_pos+68+10,gap_y_text+y_pos-10)
cairo_show_text(cr, tostring(conky_parse('${memperc}')) .. "%")
cairo_move_to(cr, x_pos+68+10,gap_y_text+18+y_pos-10)
cairo_show_text(cr,"Used RAM")
cairo_move_to(cr, x_pos+68+10,gap_y_text+18+14+y_pos-10)
cairo_show_text(cr,conky_parse('${mem}') .. '/' .. conky_parse('${memmax}'))
end
function draw_cpuram(cr,x_pos,y_pos, radius,r_CPURAM, g_CPURAM, b_CPURAM, transparency_CPURAM,gap_y_text)
cairo_set_source_rgba(cr,r_CPURAM,g_CPURAM,b_CPURAM,transparency_CPURAM)
cairo_set_font_size(cr, 12)
cairo_move_to(cr,x_pos,gap_y_text+y_pos-27)
cairo_show_text(cr, "TOP PROCESS")
cairo_move_to(cr,x_pos+112,gap_y_text+y_pos-27)
cairo_show_text(cr, "CPU")
cairo_move_to(cr,x_pos+151,gap_y_text+y_pos-27)
cairo_set_font_size(cr, 10)
cairo_move_to(cr,x_pos,gap_y_text+14+y_pos-27)
cairo_show_text(cr, conky_parse('${top name 1}'))
cairo_move_to(cr,x_pos+108,gap_y_text+14+y_pos-27)
cairo_show_text(cr, conky_parse('${top cpu 1}'))
cairo_move_to(cr,x_pos+148,gap_y_text+14+y_pos-27)
cairo_show_text(cr, conky_parse('${top mem 1}'))
cairo_move_to(cr,x_pos,gap_y_text+14+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top name 2}'))
cairo_move_to(cr,x_pos+108,gap_y_text+14+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top cpu 2}'))
cairo_move_to(cr,x_pos+148,gap_y_text+14+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top mem 2}'))
cairo_move_to(cr,x_pos,gap_y_text+14+10+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top name 3}'))
cairo_move_to(cr,x_pos+108,gap_y_text+14+10+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top cpu 3}'))
cairo_move_to(cr,x_pos+148,gap_y_text+14+10+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top mem 3}'))
cairo_move_to(cr,x_pos,gap_y_text+14+10+10+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top name 4}'))
cairo_move_to(cr,x_pos+108,gap_y_text+14+10+10+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top cpu 4}'))
cairo_move_to(cr,x_pos+148,gap_y_text+14+10+10+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top mem 4}'))
cairo_move_to(cr,x_pos,gap_y_text+14+10+10+10+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top name 5}'))
cairo_move_to(cr,x_pos+108,gap_y_text+14+10+10+10+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top cpu 5}'))
cairo_move_to(cr,x_pos+148,gap_y_text+14+10+10+10+10+y_pos-27)
cairo_show_text(cr, conky_parse('${top mem 5}'))
end
function draw_info(cr,x_pos,y_pos, radius,r_INFO, g_INFO, b_INFO, transparency_INFO,gap_y_text)
cairo_set_source_rgba(cr,r_INFO,g_INFO,b_INFO,transparency_INFO)
cairo_show_text(cr, "OS:")
cairo_move_to(cr,x_pos+60,gap_y_text+y_pos-27)
cairo_show_text(cr, "Manjaro Linux")
cairo_show_text(cr, "Kernel:")
cairo_move_to(cr,x_pos+60,gap_y_text+14+y_pos-27)
cairo_show_text(cr, conky_parse('${kernel}'))
cairo_move_to(cr,x_pos,gap_y_text+14+14+y_pos-27)
cairo_show_text(cr, "Uptime:")
cairo_move_to(cr,x_pos+60,gap_y_text+14+14+y_pos-27)
cairo_show_text(cr, conky_parse('${uptime}'))
if conky_parse('${addr ' .. iface_c .. '}') == "No Address" then
cairo_move_to(cr,x_pos,gap_y_text+14+14+14+y_pos-27)
cairo_show_text(cr, "IP(wifi):")
cairo_move_to(cr,x_pos+60,gap_y_text+14+14+14+y_pos-27)
cairo_show_text(cr, conky_parse('${addr ' .. iface_w .. '}'))
else
cairo_show_text(cr, "IP(cable):")
cairo_show_text(cr, conky_parse('${addr ' .. iface_c .. '}'))
end
cairo_move_to(cr,x_pos,gap_y_text+14+14+14+14+y_pos-27)
cairo_show_text(cr, "Server:")
cairo_move_to(cr,x_pos+60,gap_y_text+14+14+14+14+y_pos-27)
cairo_show_text(cr, conky_parse('${if_mounted ' .. server_path .. '}Connected${else}Not connected${endif}'))
end
function draw_function(cr)
local w,h=conky_window.width,conky_window.height
cairo_select_font_face (cr, "Dejavu Sans Book", CAIRO_FONT_SLANT_NORMAL, CAIRO_FONT_WEIGHT_NORMAL);
local start_rect_height = 88
-- Start with 172
local start_rect_width = 200
local gap_y_text = (start_rect_height/2)-7
local gap_x = 10
local gap_x_fix = 2
local gap_y_fix = 2
local radius = 10
local start_rect_height_no_battery = 50
if battery then
draw_square(cr,gap_x_fix,gap_y_fix, start_rect_width, start_rect_height,r_battery, g_battery, b_battery, transparency_battery)
draw_battery(cr,gap_x+gap_x_fix, gap_y_fix,start_rect_height,r_battery, g_battery, b_battery, transparency_battery,gap_y_text)
for i=1,drives do
draw_square(cr,gap_x_fix,(start_rect_height+gap_y)*i+gap_y_fix, start_rect_width, start_rect_height,drive_colors[i][1], drive_colors[i][2], drive_colors[i][3], drive_colors[i][4])
draw_folder(cr,gap_x_fix,(start_rect_height+gap_y)*i+gap_y_fix,start_rect_height,drive_paths[i],drive_names[i],drive_colors[i][1], drive_colors[i][2], drive_colors[i][3], drive_colors[i][4],gap_y_text)
end
draw_square(cr,gap_x_fix,(start_rect_height+gap_y)*(drives+1)+gap_y_fix, start_rect_width, start_rect_height,r_CPU, g_CPU, b_CPU, transparency_CPU)
draw_cpu(cr,number_of_cpus,gap_x+gap_x_fix,(start_rect_height+gap_y)*(drives+1)+gap_y_fix,r_CPU, g_CPU, b_CPU, transparency_CPU,gap_y_text)
draw_square(cr,gap_x_fix,(start_rect_height+gap_y)*(drives+2)+gap_y_fix, start_rect_width, start_rect_height,r_RAM, g_RAM, b_RAM, transparency_RAM)
draw_ram(cr,gap_x+gap_x_fix,(start_rect_height+gap_y)*(drives+2)+10+gap_y_fix, radius, r_RAM, g_RAM, b_RAM, transparency_RAM,gap_y_text)
draw_square(cr,gap_x_fix,(start_rect_height+gap_y)*(drives+3)+gap_y_fix, start_rect_width, start_rect_height,r_CPURAM, g_CPURAM, b_CPURAM, transparency_CPURAM)
draw_cpuram(cr,gap_x+gap_x_fix,(start_rect_height+gap_y)*(drives+3)+10+gap_y_fix, radius, r_CPURAM, g_CPURAM, b_CPURAM, transparency_CPURAM,gap_y_text)
draw_square(cr,gap_x_fix,(start_rect_height+gap_y)*(drives+4)+gap_y_fix, start_rect_width, start_rect_height,r_INFO, g_INFO, b_INFO, transparency_INFO)
draw_info(cr,gap_x+gap_x_fix,(start_rect_height+gap_y)*(drives+4)+10+gap_y_fix, radius, r_INFO, g_INFO, b_INFO, transparency_INFO,gap_y_text)
else
for i=1,drives do
draw_square(cr,gap_x_fix,start_rect_height_no_battery+gap_y_fix, start_rect_width, start_rect_height,drive_colors[i][1], drive_colors[i][2], drive_colors[i][3], drive_colors[i][4])
draw_folder(cr,gap_x_fix,(start_rect_height_no_battery)+gap_y_fix,start_rect_height,drive_paths[i],drive_names[i],drive_colors[i][1], drive_colors[i][2], drive_colors[i][3], drive_colors[i][4],gap_y_text)
start_rect_height_no_battery = start_rect_height_no_battery + gap_y + 88 + gap_y_fix
end
draw_square(cr,gap_x_fix,start_rect_height_no_battery+gap_y_fix, start_rect_width, start_rect_height,r_CPU, g_CPU, b_CPU, transparency_CPU)
draw_cpu(cr,number_of_cpus,gap_x+gap_x_fix,(start_rect_height_no_battery)+gap_y_fix,r_CPU, g_CPU, b_CPU, transparency_CPU,gap_y_text)
draw_square(cr,gap_x_fix,(start_rect_height_no_battery)+gap_y_fix, start_rect_width, start_rect_height,r_RAM, g_RAM, b_RAM, transparency_RAM)
draw_ram(cr,gap_x+gap_x_fix,(start_rect_height_no_battery)+10+gap_y_fix, radius, r_RAM, g_RAM, b_RAM, transparency_RAM,gap_y_text)
end
end
function conky_start_widgets()
local function draw_conky_function(cr)
local str=''
local value=0
draw_function(cr)
end
-- Check that Conky has been running for at least 5s
if conky_window==nil then return end
local cs=cairo_xlib_surface_create(conky_window.display,conky_window.drawable,conky_window.visual, conky_window.width,conky_window.height)
local cr=cairo_create(cs)
local updates=conky_parse('${updates}')
update_num=tonumber(updates)
if update_num>5 then
end
cairo_surface_destroy(cs)
cairo_destroy(cr)
end
conky_clock:
-- conky_clock.conf
-- author : vlkon
-- version : 20180805_01
-- conky version : conky 1.10.6_pre compiled Thu Dec 29 16:29:51 UTC 2016 for Linux 4.1.37-1-MANJARO x86_64
-- license:
-- This program is free software: you can redistribute it and/or modify
-- it under the terms of the GNU General Public License as published by
-- the Free Software Foundation, either version 3 of the License, or
-- (at your option) any later version.
-- This program is distributed in the hope that it will be useful,
-- but WITHOUT ANY WARRANTY; without even the implied warranty of
-- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-- GNU General Public License for more details.
-- You should have received a copy of the GNU General Public License
-- along with this program. If not, see <https://www.gnu.org/licenses/>.
conky.config = {
-- This is a comment
-- Create own window instead of using desktop
own_window = true,
own_window_colour = '000000', -- 000000 is black
own_window_transparent = false, -- set transparency level to 0 (redundant with argb value 0)
own_window_argb_visual = true, -- use transparency
own_window_argb_value = 0, -- transparency level (0-255 -> 0%-100%)
double_buffer = true, -- eliminates flicker
--Window size
minimum_width = 425,
maximum_width = 425,
minimum_height = 185,
-- Window position
alignment = 'top_middle',
-- Gap between borders of screen and text
gap_x = 0,
gap_y = 0,
--Window borders
stippled_borders = 1, -- border dash legth (pixel)
border_width = 2, -- border dash width (pixel)
--Border margins (offset)
-- Font - not really necessary since everything is in a lua script
use_spacer = 'none',
use_xft = true, -- anti-aliased font and stuff
xftalpha = 1.0, -- value between 0.0 and 1.0
font = 'Liberation Sans:pixelsize=12',
draw_outline = false, -- amplifies text if yes
draw_shades = false,
uppercase = false, -- set to yes if you want all text to be in uppercase
pad_percents = 3, -- fix percents to 3 digits (keep format)
format_human_readable = false, -- volumes are in KiB, MiB or GiB - keep 'false' for lua script
-- Update interval in seconds
update_interval = 1.0,
-- update_interval_on_battery 5.0, -- only for laptop
-- Misc
total_run_times = 0, -- 0=run forever
-- text_buffer_size = 256, -- default buffer size
temperature_unit = 'celsius',
no_buffers = true, -- memory usage doesn't contain cache and buffers -- keep for lua script
if_up_strictness = 'link', -- 'up', 'link' or 'address' -- keep for lua script
-- Number of samples to average - set to 1 to disable averaging
cpu_avg_samples = 1,
diskio_avg_samples = 1,
net_avg_samples = 1,
--Graph setting
show_graph_range = false, -- time range
show_graph_scale = false, -- max graph value
--Colors
default_color = 'FFFFFF', -- default text color
default_shade_color = '000000',
default_outline_color = '000000',
--Templates
--Lua scripts
lua_load = '/home/lucien/.conky/Conky_Revisited_2/Conky_Square_Vertical/conky_clock.lua',
lua_draw_hook_post = 'conky_main'
conky.text = [[#This is comment and everything else is in the lua script]];
conky_clock.lua:
-- conky_clock.lua
-- author : vlkon
-- license:
require 'cairo'
master_settings = {
clock = {status = 1, x = 160.0, y = 80.0}, -- origin position - in this case it is bottom-center of the clock ":"
date = {status = 1, x = 290.0, y = 100.0}, -- origin position - top-right corner of day number
scale = { x = 1.0, y = 1.0} -- scale from top-left corner
-- Slightly finer adjustment of each visual
clock = {
x_offset = 12.0, -- offset hours and minutes from the center
y_offset = 7.0, -- offset colon ":" along y-direction from the center
size = 100.0,
font = 'Alex Brush',
slant = CAIRO_FONT_SLANT_NORMAL,
weight = CAIRO_FONT_WEIGHT_NORMAL,
rgb = 0xFFFFFF,
alpha = 0.6
date = {
day = {
status = 1, -- 1:ON, 0:OFF
x_offset = -15.0, y_offset = 0.0, -- offset from origin (top-right corner of a day number)
size = 52.0, -- font size
rgb = 0x34BE5B,
alpha = 0.8,
text = '${time %_d}',
x_align = 'RIGHT' -- 'LEFT', 'RIGHT' x-alignment of the text
month = {
x_offset = -7.0, y_offset = 0.0, -- offset from origin (top-right corner of a day number)
size = 28.0, -- font size
font = 'Petit Formal Script',
rgb = 0xFFFFFF,
alpha = 0.6,
text = '${time %B}',
x_align = 'LEFT' -- 'LEFT', 'RIGHT' x-alignment of the text
year = {
x_offset = 40.0, y_offset = 30.0, -- offset from origin (top-right corner of a day number)
size = 26.0, -- font size
rgb = 0x34BE5B,
alpha = 0.8,
text = '${time %Y}',
wday = {
x_offset = 40.0, y_offset = 55.0, -- offset from origin (top-right corner of a day number)
size = 20.0, -- font size
rgb = 0xD0D0D0,
alpha = 0.6,
text = '${time %A}',
-- Functions start here
-- converts color in hex to decimal R,G,B values and pass along alpha value
function convert_rgba_split(rgb, alpha)
return ((rgb / 0x10000) % 0x100) / 255.0, ((rgb / 0x100) % 0x100) / 255.0, (rgb % 0x100) / 255.0, alpha
end
-- print clock in 24h format "HH:MM" with fixed position of ":"
function draw_clock(cr)
if master_settings.clock.status == 0 then return end -- no date visualisation
local x_org = master_settings.clock.x -- clock origin
local y_org = master_settings.clock.y
local x, y = 0, 0 -- generic position variables
local fe=cairo_font_extents_t:create()
tolua.takeownership(fe) -- garbage collection - don't know if used correctly or if it is even needed
local te=cairo_text_extents_t:create()
tolua.takeownership(te) -- garbage collection - don't know if used correctly or if it is even needed
-- get current time
local hour = conky_parse('${time %0H}')
local minute = conky_parse('${time %0M}')
-- string.format('%02d', tonumber(conky_parse('${time %H}'))) -- possible formating
cairo_set_font_size(cr, clock.size)
cairo_set_source_rgba (cr,convert_rgba_split(clock.rgb, clock.alpha))
cairo_select_font_face (cr, clock.font, clock.slant, clock.weight)
cairo_font_extents (cr, fe)
-- print ":"
cairo_text_extents (cr, ':', te)
x = x_org - te.x_bearing - te.width / 2
y = y_org - fe.ascent/2 + te.height/2 + clock.y_offset
cairo_move_to (cr, x, y)
cairo_show_text (cr, ':')
-- print hours
cairo_text_extents (cr, hour, te)
x = x_org - te.x_bearing - te.width - clock.x_offset
y = y_org
cairo_show_text (cr, hour)
--print minutes
cairo_text_extents (cr, minute, te)
x = x_org - te.x_bearing + clock.x_offset
y = y_org
cairo_show_text (cr, minute)
end
-- draw each element present in date
function date_part(cr, x_org, y_org, setting)
if setting.status == 0 then return end -- no date element visualisation
local text = conky_parse(setting.text)
cairo_set_font_size(cr, setting.size)
cairo_set_source_rgba (cr,convert_rgba_split(setting.rgb, setting.alpha))
cairo_select_font_face (cr, setting.font, setting.slant, setting.weight)
cairo_text_extents (cr, text, te)
if setting.x_align == 'RIGHT' then
x = x_org - te.x_bearing - te.width + setting.x_offset
elseif setting.x_align == 'LEFT' then
x = x_org - te.x_bearing + setting.x_offset
else
return -- error in config
end
y = y_org + fe.ascent + setting.y_offset --"+fe.ascent" instead of "-te.y_bearing" also possible but it holds different values depending on the text
cairo_show_text (cr, text)
end
-- main date procedure
function draw_date(cr)
if master_settings.date.status == 0 then return end -- no date visualisation
for iii in pairs(date) do
date_part(cr, master_settings.date.x, master_settings.date.y, date[iii])
end
end
-- Main function called by conky
function conky_main()
if conky_window == nil then
return
end
local cs = cairo_xlib_surface_create(conky_window.display,
conky_window.width,
local cr = cairo_create(cs)
local updates = tonumber(conky_parse('${updates}'))
cairo_save (cr)
cairo_scale (cr, master_settings.scale.x, master_settings.scale.y) -- If you don't want to use a amagnifying glass this scales everything
if updates > 3 then
draw_clock(cr)
draw_date(cr)
end
cairo_restore(cr) -- restore scale setting to 1.0,1.0
cairo_destroy(cr)
end
This topic was automatically closed after 90 days. New replies are no longer allowed.
