Can we please have an option in settings to disable the middle click paste shortcut?
In which DE? In Gnome, there is an option in Tweaks (gnome-tweaks
) under âKeyboard and Mouseâ.
The middle mouse paste buffer is really hardcoded in the system.
I wonder if somebody will bring you solution.
Super hard.
Maybe if you would be willing to sacrifice the middleclick alltogether.
EDIT: or isntall the sxhkd but still uggly solution
Impossible to answer question without knowing what Desktop (window manager - xwindows or wayland) is being used, like @flibby.jibbit mentioned.
KDE has an option in settings. KDE Doc - KDE Mouse Actions - https://docs.kde.org/stable5/en/kde-workspace/plasma-desktop/desktop.html
IMWheel - https://wiki.archlinux.org/index.php/IMWheel
- is a tool for tweaking mouse wheel behavior, on a per-program basis.
In the archived manjaro forum - How to deactivate middle mouse button paste - https://archived.forum.manjaro.org/t/how-to-deactivate-middle-mouse-button-paste/19794
There were more search hits at the archived forum: https://archived.forum.manjaro.org/search?q=middle%20mouse%20paste
PS: Seems to be a problem with the forum. Canât not add hyperlinks.
Doesnât that disable middle click altogether? The advantage of the sxhkd method is that it doesnât disable middle click, just the pasting.
Hello everyone.
I have a slightly different question to this, but I didnât think it was different enough so as to start a new thread.
I am on KDE Plasma, and sometime ago there was a keybinding that when clicking the middle-click on the desktop, a sticky note widget appeared. This is no longer possible. Do you know if and how I can bring it back? The âRight-click>Configure Desktop>Mouse Actions and delete middle-buttonâ advice I have found for the opposite of what I want, canât be used because the set of actions in the respective menu is standard.
Is there a way or should I try something custom?
Sorry for jumping in.
I donât get it. Firefox seems to pretty easily get it to Autoscroll on middle click and at the same time, use its paste function when you Middle Click on the right spot. Thatâs actually pretty useful and Iâd consider it to be the best GUI implementation.
Then why is it so hard for other applications? Am I missing something?
