Cubik
10 June 2021 12:04
1
I’ve customied my manjaro xfce:
Install Manjaro xfce
install theme
install icons and cursors
install plank dock and it’s theme
install ulauncher and it’s theme
configure panel, only elements and appearance
Now when I open panel settings and close them
Panel is premanently bordered with red line and active application in the plank dock shown.
Application is called “Create launch icon on the panel”
And I can’t close it!
After reboot all works fine
Screenshot: screenshot — ImgBB
What can possibly cause it and is there a way to fix it?
Cubik
10 June 2021 12:06
3
System info:
Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
root=UUID=f118723a-d875-4ba1-9d25-e2e93640ba87 rw rootflags=subvol=@ quiet
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel, plank wm: xfwm4
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Acer product: Extensa 215-51 v: V1.06 serial: <filter>
Mobo: WL model: Taurus_WC v: V1.06 serial: <filter> UEFI: Insyde v: 1.06
date: 09/23/2019
ID-1: BAT1 charge: 29.7 Wh (100.0%) condition: 29.7/37.0 Wh (80.1%)
volts: 8.3 min: 7.7 model: PANASONIC PABAS0241231 type: Li-ion
serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 7.62 GiB used: 2.16 GiB (28.4%)
Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: DE cache: L2: 6 MiB bogomips: 28808
Speed: 600 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 600 2: 600 3: 600
4: 600 5: 663 6: 600 7: 600 8: 600
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Chicony VGA WebCam type: USB driver: uvcvideo bus-ID: 1-7:4
chip-ID: 04f2:b5e0 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 4480x1454 s-dpi: 96 s-size: 1185x385mm (46.7x15.2")
s-diag: 1246mm (49.1")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
Monitor-2: HDMI1 res: 2560x1440 hz: 60 dpi: 108 size: 600x340mm (23.6x13.4")
diag: 690mm (27.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:9dc8
class-ID: 0403
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel port: 4040 bus-ID: 01:00.0
chip-ID: 168c:0042 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-10:5 chip-ID: 04ca:3015 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 1.16 TiB used: 105.58 GiB (8.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: GOODRAM model: SSDPR-PX500-256-80
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: V1.0.5 temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
rotation: 5400 rpm serial: <filter> rev: 1J scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Transcend
model: JetFlash Transcend size: 15.11 GiB block-size: physical: 512 B
logical: 512 B rotation: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 101.48 GiB size: 101.48 GiB (100.00%)
used: 10.29 GiB (10.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: f118723a-d875-4ba1-9d25-e2e93640ba87
ID-2: /boot/efi raw-size: 285 MiB size: 284.4 MiB (99.80%)
used: 7.1 MiB (2.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 6571-498E
ID-3: /home raw-size: 101.48 GiB size: 101.48 GiB (100.00%)
ID-4: /media/1tb-volume raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 95.28 GiB (10.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 2d1de759-b464-4d8a-a0c7-8be5aff0b034
ID-5: /var/cache raw-size: 101.48 GiB size: 101.48 GiB (100.00%)
ID-6: /var/log raw-size: 101.48 GiB size: 101.48 GiB (100.00%)
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 136.72 GiB fs: btrfs label: N/A
uuid: 434dd1dd-8922-4d8e-ae29-f0f7d3ac15af
ID-2: /dev/sdb1 maj-min: 8:17 size: 2.4 GiB fs: iso9660
label: MANJARO_XFCE_2105 uuid: 2021-05-19-14-20-20-00
ID-3: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 9C90-90E8
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Transcend Information JetFlash type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 8564:1000 class-ID: 0806
Device-2: 1-4:3 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-3: 1-7:4 info: Chicony VGA WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b5e0
Device-4: 1-10:5 info: Lite-On Qualcomm Atheros QCA9377 Bluetooth
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04ca:3015 class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 272 Uptime: 12m wakeups: 3 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1205 lib: 332 flatpak: 0
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04
Hi @Cubik ,
I wonder whether you could provide the theme, icon and cursors name and url where you downloaded them, in order to replicate your problem.
Regards,
Cubik
11 June 2021 16:14
5
Hi @Cubik ,
I followed your instructions and I installed all but TCE Uppercap and nothing happened, everything is working all right.
I add a picture of my desktop.
My XFCE Desktop with Plank
I wonder whether a different plank theme may change something, but I am not sure.
I usually prefer the Cairo Dock, which brings many alternatives as TCE Uppercap.
Hope it help, regards
Cubik
16 June 2021 12:25
7
Hi @j8a ,
I really appreciate your help, will test Cairo as soon as possible
And maybe I won’t use any of these docks and will just configure the panels to show launch icons and window buttons.
Thank you once more!
Hi @Cubik ,
I finally install the TCE and it looks good, although I could not see the problem you have reported before.
Another screenshot of my XFCE desktop
Reagards
Cubik
16 June 2021 21:42
9
Hi @j8a ,
Could you try to change settings of panels and then close this window?
j8a
17 June 2021 13:38
10
Hi @Cubik ,
I change my panel settings under appearance in Style from Dracula-slim to vimix-dark, the Icons from Tela Purple to Tela Yellow and in Windows decoration from Dracula-slim to vimix-dark and the result is the same.
Here is the screenshot: XFCE after changing settings
Then, here is my desktop with all the windows closed: XFCE Desktop after the recent changes
Regards,
