Hi, I have a problem with optimus-manager and optimus-manager-qt. Both of these programs worked perfectly before last update of kernel. When I just type optimus manager
I have this error:
ERROR: the latest GPU setup attempt failed at Xorg pre-start hook.
Log at /var/log/optimus-manager/switch/switch-20220526T092223.log
Cannot execute command because of previous errors.
When I run systemctl status optimus-manager.service
Output is:
● optimus-manager.service - Optimus Manager Commands Daemon
Loaded: loaded (/usr/lib/systemd/system/optimus-manager.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2022-05-26 09:22:23 CEST; 8min ago
Process: 658 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_daemon_start (code=exited, status=0/SUCCESS)
Process: 732 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_xorg_start (code=exited, status=1/FAILURE)
Main PID: 785 (python3)
Tasks: 1 (limit: 18988)
Memory: 13.1M
CPU: 296ms
CGroup: /system.slice/optimus-manager.service
└─ 785 /usr/bin/python3 -u -m optimus_manager.daemon
kvě 26 09:22:23 aurelius-msi python3[732]: _load_module(available_modules, "nvidia", options=nvidia_options)
kvě 26 09:22:23 aurelius-msi python3[732]: File "/usr/lib/python3.10/site-packages/optimus_manager/kernel.py", line 241, in _load_module
kvě 26 09:22:23 aurelius-msi python3[732]: raise KernelSetupError(
kvě 26 09:22:23 aurelius-msi python3[732]: optimus_manager.kernel.KernelSetupError: module nvidia is not available for current kernel. Is the corresponding package installed ?
kvě 26 09:22:23 aurelius-msi python3[732]: [144] INFO: Removing /etc/X11/xorg.conf.d/10-optimus-manager.conf (if present)
kvě 26 09:22:23 aurelius-msi python3[732]: [144] INFO: Writing state {'type': 'pre_xorg_start_failed', 'switch_id': '20220526T092223', 'requested_mode': 'hybrid'}
kvě 26 09:22:23 aurelius-msi systemd[1]: Started Optimus Manager Commands Daemon.
kvě 26 09:22:23 aurelius-msi python3[785]: [1] INFO: # Commands daemon
kvě 26 09:22:23 aurelius-msi python3[785]: [1] INFO: Opening UNIX socket
kvě 26 09:22:23 aurelius-msi python3[785]: [1] INFO: Awaiting commands
I tried to reinstall nvidia drivers. Nvidia drivers I have:
local/egl-wayland 2:1.1.9+r3+g582b2d3-1
EGLStream-based Wayland external platform
local/lib32-libvdpau 1.5-1
Nvidia VDPAU library
local/lib32-nvidia-utils 510.73.05-1
NVIDIA drivers utilities (32-bit)
local/libvdpau 1.5-1
local/libxnvctrl 510.73.05-1
NVIDIA NV-CONTROL X extension
local/linux414-nvidia 510.73.05-1 (linux414-extramodules)
NVIDIA drivers for linux.
local/mhwd-nvidia 510.73.05-1
MHWD module-ids for nvidia 510.73.05
local/mhwd-nvidia-390xx 390.151-1
MHWD module-ids for nvidia 390.151
local/mhwd-nvidia-470xx 470.129.06-1
MHWD module-ids for nvidia 470.129.06
local/nvidia-prime 1.0-4
NVIDIA Prime Render Offload configuration and utilities
local/nvidia-utils 510.73.05-1
version of Manjaro: 5.15.41-1-MANJARO
I tried to run prime-offload prime-run and so on. In /etc/sddm.conf
I commented 2 lines in xorg config:
#DisplayCommand=/usr/share/sddm/scripts/Xsetup
#DisplayStopCommand=/usr/share/sddm/scripts/Xstop
but nothing works. can someone kindly help me in this situation?
Thank you in advance
