Hi,
I updated my system today. Last time I updated was about 1 month ago. Nvidia drivers and optimus-manager were working ok before the update.
After the update, I can no longer launch optimus-manager. The error I get is
john@ja-clevo ~]$ optimus-manager
> ERROR: the latest GPU setup attempt failed at Xorg pre-start hook.
> Log at /var/log/optimus-manager/switch/switch-20211203T172638.log
> Cannot execute command because of previous errors
john@ja-clevo ~]$ optimus-manager-qt
Unable to read current mode from Optimus Manager state file
Aborted (core dumped)
When I view the optimus manager log, I see:
optimus-manager log
8] INFO: # Xorg pre-start hook
[8] INFO: Previous state was: {'type': 'pending_pre_xorg_start', 'requested_mode': 'hybrid', 'current_mode': None}
[8] INFO: Requested mode is: hybrid
[442] INFO: Available modules: ['nouveau', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
[442] INFO: Unloading modules ['nouveau'] (if loaded)
[445] INFO: switching=none, nothing to do
[485] INFO: Loading module nvidia
[662] ERROR: Xorg pre-start setup error
File "/usr/lib/python3.9/site-packages/optimus_manager/kernel.py", line 245, in _load_module
subprocess.check_call(
File "/usr/lib/python3.9/subprocess.py", line 373, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command 'modprobe nvidia NVreg_UsePageAttributeTable=1' returned non-zero exit status 1.
The above exception was the direct cause of the following exception:
File "/usr/lib/python3.9/site-packages/optimus_manager/hooks/pre_xorg_start.py", line 51, in main
setup_kernel_state(config, prev_state, requested_mode)
File "/usr/lib/python3.9/site-packages/optimus_manager/kernel.py", line 22, in setup_kernel_state
_nvidia_up(config, hybrid=(requested_mode == "hybrid"))
File "/usr/lib/python3.9/site-packages/optimus_manager/kernel.py", line 95, in _nvidia_up
_load_nvidia_modules(config, available_modules)
File "/usr/lib/python3.9/site-packages/optimus_manager/kernel.py", line 164, in _load_nvidia_modules
_load_module(available_modules, "nvidia", options=nvidia_options)
File "/usr/lib/python3.9/site-packages/optimus_manager/kernel.py", line 249, in _load_module
raise KernelSetupError(f"Error running modprobe for {module}: {e.stderr}") from e
optimus_manager.kernel.KernelSetupError: Error running modprobe for nvidia: None
[663] INFO: Removing /etc/X11/xorg.conf.d/10-optimus-manager.conf (if present)
[663] INFO: Writing state {'type': 'pre_xorg_start_failed', 'switch_id': '20211203T172638', 'requested_mode': 'hybrid'}
I tried stopping and starting the optimus manager service but it still gives me an error exit code:
optimus-manager.service
● optimus-manager.service - Optimus Manager Commands Daemon
Loaded: loaded (/usr/lib/systemd/system/optimus-manager.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2021-12-03 17:50:42 EST; 4s ago
Process: 4802 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_daemon_start (code=exited, status=0/SUCCESS)
Process: 4803 ExecStartPre=/usr/bin/python3 -u -m optimus_manager.hooks.pre_xorg_start (code=exited, status=1/FAILURE)
Main PID: 4818 (python3)
Tasks: 1 (limit: 38044)
Memory: 6.3M
CPU: 728ms
CGroup: /system.slice/optimus-manager.service
└─4818 /usr/bin/python3 -u -m optimus_manager.daemon
Dec 03 17:50:42 ja-clevo python3[4803]: _load_module(available_modules, "nvidia", options=nvidia_options)
Dec 03 17:50:42 ja-clevo python3[4803]: File "/usr/lib/python3.9/site-packages/optimus_manager/kernel.py", line 249, in _load_module
Dec 03 17:50:42 ja-clevo python3[4803]: raise KernelSetupError(f"Error running modprobe for {module}: {e.stderr}") from e
Dec 03 17:50:42 ja-clevo python3[4803]: optimus_manager.kernel.KernelSetupError: Error running modprobe for nvidia: None
Dec 03 17:50:42 ja-clevo python3[4803]: [617] INFO: Removing /etc/X11/xorg.conf.d/10-optimus-manager.conf (if present)
Dec 03 17:50:42 ja-clevo python3[4803]: [617] INFO: Writing state {'type': 'pre_xorg_start_failed', 'switch_id': '20211203T175041', 'requested_mode': 'hybrid'}
Dec 03 17:50:42 ja-clevo systemd[1]: Started Optimus Manager Commands Daemon.
Dec 03 17:50:42 ja-clevo python3[4818]: [1] INFO: # Commands daemon
Dec 03 17:50:42 ja-clevo python3[4818]: [1] INFO: Opening UNIX socket
Dec 03 17:50:42 ja-clevo python3[4818]: [1] INFO: Awaiting commands
inxi -Fza
System: Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: initrd=\amd-ucode.img initrd=\Manjaro\amd-ucode.img initrd=\intel-ucode.img
initrd=\initramfs-5.14-x86_64.img root=UUID=c4cf79bc-b324-4058-83ba-bead81dc6c08 rw
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: CLEVO/KAPOK driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: CLEVO/KAPOK driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-8:2 chip-ID: 5986:9102 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.5 direct render: Yes
I’ve been through the troubleshooting guide on https://github.com/Askannz/optimus-manager/blob/master/README.md#important–manjaro-kde-users but my system check out.
I’d appreciate any tips or advise to help resolve.
Thanks,
