OpenRC and 73-seat-late.rules. Why deleting it was a good thing
The rules file /usr/lib/udev/rules.d/73-seat-late.rules is included in the udev-systemd package (despite the name, it’s actually a compat lib). The rules file will cause OpenRC init errors. It was also responsible for my broadcom-wl-dmks module segfaulting.
Unfortunately I don’t have access to the dmesg anymore but I highly recommend you check yours and see if that rule is outputting errors. If it is, you can delete it no problem. Like it says, it’s a part of systemd.
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published
by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
ACTION=="remove", GOTO="seat_late_end"
ENV{ID_SEAT}=="", ENV{ID_AUTOSEAT}=="1", ENV{ID_FOR_SEAT}!="",
ENV{ID_SEAT}="seat-$env{ID_FOR_SEAT}"
ENV{ID_SEAT}=="", IMPORT{parent}="ID_SEAT"
ENV{ID_SEAT}!="", TAG+="$env{ID_SEAT}"
TAG=="uaccess", ENV{MAJOR}!="", RUN{builtin}+="uaccess"
LABEL="seat_late_end"
Thanks. Sounds like there’s a long and awful story behind that one.
Makes me wonder how many other files in that folder could just be safely junked too. I checked a couple and at least one had the same comment up top.
I would not recommend you to try, it will make your hardware stop working.
