Kde Plasma Slow Opening apps
Hello.
First, yes, I have checked forum and red all the topics about this, but none solution works (neither june’s update bug).
Some apps, like LibreOffice or pamac-manager take some time to startup, in contrast to other SO in the same laptop.
❯ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 6.6.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    root=UUID=7fed8359-6cfc-4797-b1eb-e7ee9a9f6cce rw udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: SLIMBOOK product: PROX15-AMD v: Standard
    serial: <superuser required>
  Mobo: SLIMBOOK model: PROX15-AMD v: Standard serial: <superuser required>
    UEFI: American Megatrends v: N.1.07GRP05 date: 07/28/2022
  ID-1: BAT0 charge: 56.5 Wh (84.0%) condition: 67.3/91.6 Wh (73.4%)
    volts: 12.5 min: 11.6 model: standard type: Li-ion serial: <filter>
    status: charging
  System RAM: total: 16 GiB note: est. available: 15.04 GiB
    used: 5.4 GiB (35.9%)
  Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600103
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 2234 high: 4243 min/max: 1400/2900 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1885 2: 1885
    3: 1400 4: 4232 5: 1476 6: 1400 7: 1400 8: 4232 9: 4243 10: 4232 11: 1885
    12: 1400 13: 1400 14: 1400 15: 1884 16: 1400 bogomips: 92657
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spec_rstack_overflow mitigation: safe RET
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Renoir vendor: Tongfang Hongkong driver: amdgpu v: kernel
    arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: none
    bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 43.0 C
  Device-2: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 04f2:b68b
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
    s-diag: 1055mm (41.54")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: left model: LG (GoldStar) FULL HD
    serial: <filter> built: 2020 res: 1920x1080 hz: 75 dpi: 102 gamma: 1.2
    size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Monitor-2: eDP-1 mapped: eDP pos: primary,right model: Sharp LQ156M1JW01
    built: 2019 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
    16.0.6 DRM 3.54 6.6.0-1-MANJARO) device-ID: 1002:1636 memory: 500 MiB
    unified: no
  API: Vulkan v: 1.3.264 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.1.9-manjaro1.1
    device-ID: 1002:1636 surfaces: xcb,xlib
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Tongfang Hongkong
    bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Tongfang Hongkong
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Tongfang Hongkong
    bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.6.0-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
    vendor: Tongfang Hongkong driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.4:6 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: yes pairing: yes class-ID: 7c010c
  Local Storage: total: 931.52 GiB used: 618.55 GiB (66.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR013 temp: 30.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Garmin model: FR735XT size: 10.1 MiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 12 Mb/s
    lanes: 1 mode: 1.1 tech: N/A serial: <filter> fw-rev: 1.00
  ID-1: / raw-size: 121.01 GiB size: 118.55 GiB (97.97%)
    used: 82.28 GiB (69.4%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
    label: N/A uuid: 7fed8359-6cfc-4797-b1eb-e7ee9a9f6cce
    used: 32.5 MiB (33.8%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: F442-AC33
  ID-3: /mnt/DATOS raw-size: 658.76 GiB size: 658.76 GiB (100.00%)
    used: 463.42 GiB (70.3%) fs: ntfs dev: /dev/nvme0n1p10 maj-min: 259:10
    label: DATOS uuid: F098A2F298A2B70E
  ID-4: /mnt/SO raw-size: 134.6 GiB size: 134.6 GiB (100.00%)
    used: 72.82 GiB (54.1%) fs: ntfs dev: /dev/nvme0n1p4 maj-min: 259:4 label: SO
    uuid: 08B69AE5B69AD294
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: partition size: 15.42 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p9 maj-min: 259:9 label: N/A
    uuid: cf155454-7d0b-4dfb-a764-27beb6525d95
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs label: N/A
    uuid: A65C39B15C397CDD
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 637 MiB fs: ntfs label: N/A
    uuid: C02CEB4C2CEB3C52
  ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 1024 KiB fs: <superuser required>
  ID-5: /dev/nvme0n1p7 maj-min: 259:7 size: 513 MiB fs: vfat label: N/A
    uuid: 6F2A-E0D4
  Device-1: 1-2:2 info: BY Tech Usb Gaming Keyboard type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:0016 class-ID: 0300
  Device-2: 1-3:3 info: Chicony HD Webcam type: video driver: uvcvideo
    interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b68b class-ID: 0e02 serial: <filter>
  Hub-2: 1-4:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-4.3:5 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-2: 1-4.4:6 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Garmin Forerunner 735XT type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 091e:086e class-ID: 0806
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 84.9 C mobo: N/A gpu: amdgpu temp: 42.0 C
  Fan Speeds (rpm): N/A
  Processes: 397 Uptime: 8m wakeups: 1 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1855
  pm: pacman pkgs: 1840 libs: 434 tools: pamac,yay pm: flatpak pkgs: 15
  Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.30
And LibreOffice shows:
(soffice:29935): Gdk-WARNING **: 18:53:39.556: XSetErrorHandler() called with a GDK error trap pushed. Don't do that
Any suggestion?
Create a new user, reboot, login into this new one and report if anything changed.
What says Htop?
I was having similar sluggish issues of late as well.
Inexplicably, they have now ceased. No clue as to why. But my Plasma was so sluggish after a while. Like the system just would become sluggish for zero (known) reason.
Sometimes my system would just lock up entirely to the point where I would have to hard reboot.
But like I said, these past days the system is quick and responsive. No clue what changed.
New user has the same problems.
What do you mean exactly? I don’t see any unexpected process
Have you checked the solution provided here already?
There isn’t any xdg-desktop-portal-gnome on my system. Only:
 ~  xdg-desktop-
xdg-desktop-icon  xdg-desktop-menu
And yes, I tried it.
Have you tried to install the proper “xdg-desktop-portal” version then?
sudo pacman -Syu xdg-desktop-portal-kde
Yes, I did it. :smiling_face_with_tear:
When I open pamac-manager, it takes some time to and it show this:
(pamac-manager:4674): Adwaita-WARNING **: 10:36:02.408: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
Any idea?
