nift.d
October 18, 2021, 12:20pm
1
Hey there,
I just installed OpenModelica and now I cant start it.
I tried
pamac list --files ompenmodelica
It says it installed to /user/share, but I dont really know what to look for. I have been using modelica with Windows. Just typing “OMedit” in KRunner did not do the trick either.
How does this work?
cscs
October 18, 2021, 12:24pm
2
According to the user guide you should be using
OMEdit
…if you run that from terminal, what happens?
Lolix
October 18, 2021, 12:40pm
3
List of stuff that ends in /usr/bin for this package
$ l
FMIWrapper
omc
omc-diff
OMEdit
OMNotebook
OMPlot
OMShell
OMShell-terminal
OMSimulator
OMSimulatorPython3
StartTLMFmiWrapper
OMSimulatorPython3 and StartTLMFmiWrapper are bash scripts, the other are binaries
nift.d
October 18, 2021, 12:48pm
5
I want to start OMedit and if there is no .exe I am screwed, tbh.
Lolix
October 18, 2021, 12:50pm
6
nift.d:
type OMEdit
in the terminal
nift.d
October 18, 2021, 12:53pm
9
OK, this is embarrasing. thx
system
Closed
October 21, 2021, 2:54am
10
