Hey I am wondering if there is a way that when I open terminal I can have more than one tab open at launch? And if so, is there a way to have the different tabs run different programs at launch?
When I go into the .zshrc and input gnome-terminal --tab and then launch terminal, I just get a never ending loop of terminal tabs. is there anything I should put at the end of that so I only open the number of tabs I want?
