Opening Choice of Game showing white screen
When I click to open Mask of Plague Doctor in Steam-native I am greeted with a white window and tried other games I have played in the past using the same game engine im met with the same result.
I ran the game using terminal and got these messages:
GameAction [AppID 1244930, ActionID 8] : LaunchApp changed task to ProcessingInstallScript with “”
GameAction [AppID 1244930, ActionID 8] : LaunchApp changed task to SynchronizingCloud with “”
GameAction [AppID 1244930, ActionID 8] : LaunchApp changed task to SiteLicenseSeatCheckout with “”
GameAction [AppID 1244930, ActionID 8] : LaunchApp changed task to CreatingProcess with “”
GameAction [AppID 1244930, ActionID 8] : LaunchApp waiting for user response to CreatingProcess “”
GameAction [AppID 1244930, ActionID 8] : LaunchApp continues with user response “CreatingProcess”
Game update: AppID 1244930 “”, ProcID 26804, IP 0.0.0.0:0
Starting app 1244930
>>> Adding process 26804 for game ID 1244930
ERROR: ld.so: object ‘/home/canisl/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so’ from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 1244930, ActionID 8] : LaunchApp changed task to WaitingGameWindow with “”
ERROR: ld.so: object ‘/home/canisl/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so’ from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
GameAction [AppID 1244930, ActionID 8] : LaunchApp changed task to Completed with “”
>>> Adding process 26807 for game ID 1244930
(MaskOfThePlagueDoctor:26807): Gtk-WARNING **: 09:35:37.385: Unable to locate theme engine in module_path: "adwaita",
(MaskOfThePlagueDoctor:26807): Gtk-WARNING **: 09:35:37.394: Unable to locate theme engine in module_path: "murrine",
(MaskOfThePlagueDoctor:26807): Gtk-WARNING **: 09:35:37.395: Unable to locate theme engine in module_path: "murrine",
(MaskOfThePlagueDoctor:26807): Gtk-WARNING **: 09:35:37.396: Unable to locate theme engine in module_path: "murrine",
(MaskOfThePlagueDoctor:26807): Gtk-WARNING **: 09:35:37.397: Unable to locate theme engine in module_path: "murrine",
Game update: AppID 1244930 "", ProcID 26807, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 26807): SteamUser017 / User
RecordSteamInterfaceCreation (PID 26807): SteamFriends014 / Friends
RecordSteamInterfaceCreation (PID 26807): SteamUtils007 / Utils
RecordSteamInterfaceCreation (PID 26807): SteamMatchMaking009 / Matchmaking
RecordSteamInterfaceCreation (PID 26807): SteamMatchMakingServers002 / MatchmakingServers
RecordSteamInterfaceCreation (PID 26807): STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
RecordSteamInterfaceCreation (PID 26807): STEAMAPPS_INTERFACE_VERSION006 / Apps
RecordSteamInterfaceCreation (PID 26807): SteamNetworking005 / Networking
RecordSteamInterfaceCreation (PID 26807): STEAMREMOTESTORAGE_INTERFACE_VERSION012 / RemoteStorage
RecordSteamInterfaceCreation (PID 26807): STEAMSCREENSHOTS_INTERFACE_VERSION002 / Screenshots
RecordSteamInterfaceCreation (PID 26807): STEAMHTTP_INTERFACE_VERSION002 / HTTP
RecordSteamInterfaceCreation (PID 26807): STEAMUNIFIEDMESSAGES_INTERFACE_VERSION001 / UnifiedMessages
RecordSteamInterfaceCreation (PID 26807): STEAMCONTROLLER_INTERFACE_VERSION / Controller
RecordSteamInterfaceCreation (PID 26807): STEAMUGC_INTERFACE_VERSION002 / UGC
RecordSteamInterfaceCreation (PID 26807): STEAMAPPLIST_INTERFACE_VERSION001 / AppList
RecordSteamInterfaceCreation (PID 26807): STEAMMUSIC_INTERFACE_VERSION001 / Music
Setting breakpad minidump AppID = 1244930
Steam_SetMinidumpSteamID:  Caching Steam ID:  76561198044451820 [API loaded no]
ERROR: ld.so: object '/home/canisl/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
** Message: 09:35:37.460: Steam folder: /home/canisl/.local/share/Steam/steamapps/common/Mask of the Plague Doctor
** Message: 09:35:37.462: Loaded icon16.png, 1
** Message: 09:35:37.462: Loaded icon32.png, 1
** Message: 09:35:37.463: Loaded icon48.png, 1
** Message: 09:35:37.464: Couldn't load app icon icon64.png: Failed to open file ?icon64.png?: No such file or directory
** Message: 09:35:37.464: Couldn't load app icon icon128.png: Failed to open file ?icon128.png?: No such file or directory
** Message: 09:35:37.464: Couldn't load app icon icon256.png: Failed to open file ?icon256.png?: No such file or directory
** Message: 09:35:37.464: Loaded 3 icons
../../sandbox/linux/seccomp-bpf-helpers/sigsys_handlers.cc:**CRASHING**:seccomp-bpf failure in syscall 0422
>>> Adding process 26809 for game ID 1244930
inxi CPU: Quad Core AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx (-MT MCP-) speed/max: 1398/1600 MHz Kernel: 5.9.16-1-MANJARO x86_64 Up: 11h 37m Mem: 4198.8/14966.9 MiB (28.1%) Storage: 1.82 TiB (26.8% used) Procs: 289 Shell: Bash inxi: 3.3.00
