Not yet; I 'll do so today, after seeing if restarting PulseAudio works
Somehow, restarting PulseAudio a number of times got it to work. I’m not sure how.
I’ll update this thread in the future if the error recurs, or if this doesn’t fix it in future sessions.
The problem recurs after pausing; restarting PulseAudio, closing the audio-playing windows (Firefox tabs, Spotify &c) and starting it again allows one to hear something; older windows can’t continue to play.
I am having a similar problem with pulseaudio but I can get it to work usually by changing the Configuration from Analog Stereo to Digital stereo and back. I don’t know what that works, but it’s still pretty annoying. When this happens pacmd says suspend cause: APPLICATION
I’m using vanilla arch, might try a new profile as a troubleshooting step.
edit: i think this fixed it for me: i had an asound.conf file in /etc that i just renamed to asound.conf.old forgot i had done that at one point when I was trying to ditch pulseaudio. After doing that and rebooting, everything seems to work without having to change the configuration in pavucontrol!
This just occurred to me upon reading the most recent response: I have a file /usr/share/alsa/alsa.conf.d/99-pulseaudio-default.conf
with the contents that you’ve listed, but I also have 50-pulseaudio.conf
, whose contents are:
# Add a specific named PulseAudio pcm and ctl (typically useful for testing)
pcm.pulse {
@args [ DEVICE ]
@args.DEVICE {
type string
default ""
type pulse
device $DEVICE
hint {
show {
@func refer
name defaults.namehint.basic
description "PulseAudio Sound Server"
ctl.pulse {
@args [ DEVICE ]
@args.DEVICE {
type string
default ""
type pulse
device $DEVICE
as well as 99-pipewire-default.conf
pcm.!default {
type pipewire
playback_node "-1"
capture_node "-1"
hint {
show on
description "Default ALSA Output (currently PipeWire Media Server)"
ctl.!default {
type pipewire
and 50-pipewire.conf
# Add a specific named PipeWire pcm
defaults.pipewire.server "pipewire-0"
defaults.pipewire.node "-1"
defaults.pipewire.exclusive false
defaults.pipewire.role ""
pcm.pipewire {
@args [ SERVER NODE EXCLUSIVE ROLE ]
@args.SERVER {
type string
default {
@func refer
name defaults.pipewire.server
@args.NODE {
type string
default {
@func refer
name defaults.pipewire.node
@args.EXCLUSIVE {
type integer
default {
@func refer
name defaults.pipewire.exclusive
@args.ROLE {
type string
default {
@func refer
name defaults.pipewire.role
type pipewire
server $SERVER
playback_node $NODE
capture_node $NODE
exclusive $EXCLUSIVE
role $ROLE
hint {
show on
description "PipeWire Sound Server"
ctl.pipewire {
@args.SERVER {
type string
default {
@func refer
type pipewire
server $SERVER
Is this at all significant or helpful?
Update: switching to Pipewire seems to have fixed the problem in toto.
