OpenGL issues after changing GPU from nVidia to Intel
After changing GPU from nVidia GeForce 210 (nvidia-340xx) to integrated Intel (because of reasons...) and after re-installing drivers via mhwd it can't recognize or find OpenGL renderer and fails to open WebGL apps like Figma. Can you help?
$ inxi -Fxxxza --no-host
System:    Kernel: 4.19.85-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=8350ebb0-15a1-42d5-9f97-72ed4188e13a rw quiet
           Desktop: Xfce 4.14.1 tk: Gtk 3.24.12 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
           Mobo: ASUSTeK model: H81M-K v: Rev X.0x serial: <filter> BIOS: American Megatrends v: 1002 date: 08/12/2014
CPU:       Topology: Quad Core model: Intel Core i5-4460 bits: 64 type: MCP arch: Haswell family: 6 model-id: 3C (60)
           stepping: 3 microcode: 27 L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25554
           Speed: 799 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 799
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics:  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:0412
           Display: x11 server: X.Org 1.20.5 driver: intel resolution: 1920x1080~60Hz, 1920x1080~60Hz
           OpenGL: renderer: N/A v: N/A direct render: N/A
Audio:     Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:8c20
           Sound Server: ALSA v: k4.19.85-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8168 v: 8.047.04-NAPI
           port: e000 bus ID: 03:00.0 chip ID: 10ec:8168
           IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
           IF-ID-1: br-0170cb68f6d8 state: down mac: <filter>
           IF-ID-2: docker0 state: down mac: <filter>
Drives:    Local Storage: total: 585.00 GiB used: 64.45 GiB (11.0%)
           ID-1: /dev/sda vendor: A-Data model: SP600 size: 119.24 GiB block size: physical: 512 B logical: 512 B
           speed: 6.0 Gb/s serial: <filter> rev: 5.28 scheme: MBR
           ID-2: /dev/sdb vendor: Toshiba model: DT01ACA050 size: 465.76 GiB block size: physical: 4096 B logical: 512 B
           speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A750 scheme: GPT
Partition: ID-1: / raw size: 119.24 GiB size: 116.87 GiB (98.01%) used: 64.45 GiB (55.1%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 29.8 C mobo: 27.8 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 184 Uptime: 14m Memory: 15.54 GiB used: 1.71 GiB (11.0%) Init: systemd v: 242 Compilers: gcc: 9.2.0
           clang: 9.0.0 Shell: zsh v: 5.7.1 running in: guake inxi: 3.0.36
$ cat /var/log/Xorg.0.log
[     3.622]
X.Org X Server 1.20.5
[     3.622] Build Operating System: Linux Arch Linux
[     3.622] Current Operating System: Linux ########## 4.19.85-1-MANJARO #1 SMP PREEMPT Thu Nov 21 10:38:39 UTC 2019 x86_64
[     3.622] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=8350ebb0-15a1-42d5-9f97-72ed4188e13a rw quiet
[     3.622] Build Date: 27 October 2019  08:49:23AM
[     3.622]
[     3.622] Current version of pixman: 0.38.4
[     3.622] 	Before reporting problems, check http://wiki.x.org
[     3.622] Markers: (--) probed, (**) from config file, (==) default setting,
[     3.622] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Dec  3 12:28:31 2019
[     3.624] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     3.624] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     3.625] (==) No Layout section.  Using the first Screen section.
[     3.625] (==) No screen section available. Using defaults.
[     3.625] (**) |-->Screen "Default Screen Section" (0)
[     3.625] (**) |   |-->Monitor "<default monitor>"
[     3.626] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[     3.626] (**) |   |-->Device "Intel Graphics"
[     3.626] (==) No monitor specified for screen "Default Screen Section".
[     3.626] (==) Automatically adding devices
[     3.626] (==) Automatically enabling devices
[     3.626] (==) Automatically adding GPU devices
[     3.626] (==) Automatically binding GPU devices
[     3.626] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     3.627] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     3.627] 	Entry deleted from font path.
[     3.627] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     3.627] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     3.627] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     3.627] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     3.627] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     3.627] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     3.627] (==) ModulePath set to "/usr/lib/xorg/modules"
[     3.627] (II) The server relies on udev to provide the list of input devices.
[     3.627] (II) Module ABI versions:
[     3.627] 	X.Org ANSI C Emulation: 0.4
[     3.627] 	X.Org Video Driver: 24.0
[     3.627] 	X.Org XInput driver : 24.1
[     3.627] 	X.Org Server Extension : 10.0
[     3.627] (++) using VT number 7
[     3.628] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     3.628] (II) xfree86: Adding drm device (/dev/dri/card0)
[     3.638] (--) PCI:*(0@0:2:0) 8086:0412:1043:8534 rev 6, Mem @ 0xf7800000/4194304, 0xe0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[     3.638] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     3.638] (II) LoadModule: "glx"
[     3.644] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     3.644] (EE) Failed to load /usr/lib/xorg/modules/extensions/libglx.so: /usr/lib/xorg/modules/extensions/libglx.so: cannot open shared object file: No such file or directory
[     3.644] (EE) Failed to load module "glx" (loader failed, 0)
[     3.644] (II) LoadModule: "intel"
[     3.647] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[     3.649] (II) Module intel: vendor="X.Org Foundation"
[     3.649] 	compiled for 1.20.5, module version = 2.99.917
[     3.649] 	Module class: X.Org Video Driver
[     3.649] 	ABI class: X.Org Video Driver, version 24.0
[     3.649] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[     3.650] (II) intel: Driver for Intel(R) HD Graphics
[     3.650] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[     3.650] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[     3.657] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20180719
[     3.657] (II) intel(0): SNA compiled from 2.99.917-893-gbff5eca4
[     3.659] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4600
[     3.659] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[     3.659] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     3.659] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[     3.659] (==) intel(0): RGB weight 888
[     3.659] (==) intel(0): Default visual is TrueColor
[     3.659] (**) intel(0): Option "DRI" "3"
[     3.659] (**) intel(0): Option "TearFree" "true"
[     3.659] (II) intel(0): Output VGA1 has no monitor section
[     3.659] (II) intel(0): Enabled output VGA1
[     3.659] (II) intel(0): Output HDMI1 has no monitor section
[     3.659] (II) intel(0): Enabled output HDMI1
[     3.659] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[     3.660] (II) intel(0): Output VIRTUAL1 has no monitor section
[     3.660] (II) intel(0): Enabled output VIRTUAL1
[     3.660] (--) intel(0): Output VGA1 using initial mode 1920x1080 on pipe 0
[     3.660] (--) intel(0): Output HDMI1 using initial mode 1920x1080 on pipe 1
[     3.660] (**) intel(0): TearFree enabled
[     3.660] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[     3.660] (==) intel(0): DPI set to (96, 96)
[     3.660] (II) Loading sub module "dri3"
[     3.660] (II) LoadModule: "dri3"
[     3.660] (II) Module "dri3" already built-in
[     3.660] (II) Loading sub module "dri2"
[     3.660] (II) LoadModule: "dri2"
[     3.660] (II) Module "dri2" already built-in
[     3.660] (II) Loading sub module "present"
[     3.660] (II) LoadModule: "present"
[     3.660] (II) Module "present" already built-in
[     3.662] (II) intel(0): SNA initialized with Haswell (gen7.5, gt2) backend
[     3.662] (==) intel(0): Backing store enabled
[     3.662] (==) intel(0): Silken mouse disabled
[     3.662] (II) intel(0): HW Cursor enabled
[     3.663] (==) intel(0): DPMS enabled
[     3.663] (==) intel(0): Display hotplug detection enabled
[     3.664] (II) intel(0): [DRI2] Setup complete
[     3.664] (II) intel(0): [DRI2]   DRI driver: i965
[     3.664] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[     3.664] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[     3.664] (II) intel(0): hardware support for Present enabled
[     3.664] (II) Initializing extension Generic Event Extension
[     3.664] (II) Initializing extension SHAPE
[     3.664] (II) Initializing extension MIT-SHM
[     3.664] (II) Initializing extension XInputExtension
[     3.664] (II) Initializing extension XTEST
[     3.664] (II) Initializing extension BIG-REQUESTS
[     3.664] (II) Initializing extension SYNC
[     3.664] (II) Initializing extension XKEYBOARD
[     3.664] (II) Initializing extension XC-MISC
[     3.664] (II) Initializing extension SECURITY
[     3.664] (II) Initializing extension XFIXES
[     3.665] (II) Initializing extension RENDER
[     3.665] (II) Initializing extension RANDR
[     3.665] (II) Initializing extension COMPOSITE
[     3.665] (II) Initializing extension DAMAGE
[     3.665] (II) Initializing extension MIT-SCREEN-SAVER
[     3.665] (II) Initializing extension DOUBLE-BUFFER
[     3.665] (II) Initializing extension RECORD
[     3.665] (II) Initializing extension DPMS
[     3.665] (II) Initializing extension Present
[     3.665] (II) Initializing extension DRI3
[     3.665] (II) Initializing extension X-Resource
[     3.665] (II) Initializing extension XVideo
[     3.666] (II) Initializing extension XVideo-MotionCompensation
[     3.666] (II) Initializing extension GLX
[     3.666] (II) Initializing extension XFree86-VidModeExtension
[     3.666] (II) Initializing extension XFree86-DGA
[     3.666] (II) Initializing extension XFree86-DRI
[     3.666] (II) Initializing extension DRI2
[     3.669] (II) intel(0): switch to mode 1920x1080@60.0 on VGA1 using pipe 0, position (0, 0), rotation normal, reflection none
[     3.670] (II) intel(0): switch to mode 1920x1080@60.0 on HDMI1 using pipe 1, position (0, 0), rotation normal, reflection none
[     3.687] (II) intel(0): Setting screen physical size to 508 x 285
[     3.726] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     3.726] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     3.726] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     3.726] (**) Power Button: Applying InputClass "system-keyboard"
[     3.726] (II) LoadModule: "libinput"
[     3.726] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     3.729] (II) Module libinput: vendor="X.Org Foundation"
[     3.729] 	compiled for 1.20.5, module version = 0.29.0
[     3.729] 	Module class: X.Org XInput Driver
[     3.729] 	ABI class: X.Org XInput driver, version 24.1
[     3.729] (II) Using input driver 'libinput' for 'Power Button'
[     3.729] (**) Power Button: always reports core events
[     3.729] (**) Option "Device" "/dev/input/event1"
[     3.729] (**) Option "_source" "server/udev"
[     3.735] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     3.735] (II) event1  - Power Button: device is a keyboard
[     3.735] (II) event1  - Power Button: device removed
[     3.756] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     3.756] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     3.756] (**) Option "xkb_model" "pc105"
[     3.757] (**) Option "xkb_layout" "us"
[     3.758] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     3.758] (II) event1  - Power Button: device is a keyboard
[     3.759] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[     3.759] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     3.759] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     3.759] (**) Video Bus: Applying InputClass "system-keyboard"
[     3.759] (II) Using input driver 'libinput' for 'Video Bus'
[     3.759] (**) Video Bus: always reports core events
[     3.759] (**) Option "Device" "/dev/input/event11"
[     3.759] (**) Option "_source" "server/udev"
[     3.760] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[     3.760] (II) event11 - Video Bus: device is a keyboard
[     3.761] (II) event11 - Video Bus: device removed
[     3.823] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input11/event11"
[     3.823] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     3.823] (**) Option "xkb_model" "pc105"
[     3.823] (**) Option "xkb_layout" "us"
[     3.825] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[     3.825] (II) event11 - Video Bus: device is a keyboard
[     3.826] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     3.826] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     3.826] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     3.826] (**) Power Button: Applying InputClass "system-keyboard"
[     3.826] (II) Using input driver 'libinput' for 'Power Button'
[     3.826] (**) Power Button: always reports core events
[     3.826] (**) Option "Device" "/dev/input/event0"
[     3.827] (**) Option "_source" "server/udev"
[     3.828] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     3.828] (II) event0  - Power Button: device is a keyboard
[     3.828] (II) event0  - Power Button: device removed
[     3.850] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     3.850] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[     3.850] (**) Option "xkb_model" "pc105"
[     3.850] (**) Option "xkb_layout" "us"
[     3.851] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     3.851] (II) event0  - Power Button: device is a keyboard
[     3.853] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event2)
[     3.853] (**) Logitech USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[     3.853] (**) Logitech USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[     3.853] (II) Using input driver 'libinput' for 'Logitech USB Optical Mouse'
[     3.853] (**) Logitech USB Optical Mouse: always reports core events
[     3.853] (**) Option "Device" "/dev/input/event2"
[     3.853] (**) Option "_source" "server/udev"
[     3.855] (II) event2  - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[     3.855] (II) event2  - Logitech USB Optical Mouse: device is a pointer
[     3.856] (II) event2  - Logitech USB Optical Mouse: device removed
[     3.903] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.0/0003:046D:C077.0001/input/input2/event2"
[     3.903] (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 9)
[     3.903] (**) Option "AccelerationScheme" "none"
[     3.903] (**) Logitech USB Optical Mouse: (accel) selected scheme none/0
[     3.903] (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[     3.903] (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[     3.905] (II) event2  - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[     3.905] (II) event2  - Logitech USB Optical Mouse: device is a pointer
[     3.906] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
[     3.906] (II) No input driver specified, ignoring this device.
[     3.906] (II) This device may have been added with another device file.
[     3.907] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event3)
[     3.907] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     3.907] (**) Logitech USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     3.907] (**) Logitech USB Keyboard: Applying InputClass "system-keyboard"
[     3.907] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
[     3.907] (**) Logitech USB Keyboard: always reports core events
[     3.907] (**) Option "Device" "/dev/input/event3"
[     3.907] (**) Option "_source" "server/udev"
[     3.909] (II) event3  - Logitech USB Keyboard: is tagged by udev as: Keyboard
[     3.909] (II) event3  - Logitech USB Keyboard: device is a keyboard
[     3.909] (II) event3  - Logitech USB Keyboard: device removed
[     3.930] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/0003:046D:C31C.0002/input/input3/event3"
[     3.930] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 10)
[     3.930] (**) Option "xkb_model" "pc105"
[     3.930] (**) Option "xkb_layout" "us"
[     3.932] (II) event3  - Logitech USB Keyboard: is tagged by udev as: Keyboard
[     3.933] (II) event3  - Logitech USB Keyboard: device is a keyboard
[     3.934] (II) config/udev: Adding input device Logitech USB Keyboard Consumer Control (/dev/input/event4)
[     3.934] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     3.934] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     3.934] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     3.934] (II) Using input driver 'libinput' for 'Logitech USB Keyboard Consumer Control'
[     3.934] (**) Logitech USB Keyboard Consumer Control: always reports core events
[     3.934] (**) Option "Device" "/dev/input/event4"
[     3.934] (**) Option "_source" "server/udev"
[     3.937] (II) event4  - Logitech USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     3.937] (II) event4  - Logitech USB Keyboard Consumer Control: device is a keyboard
[     3.937] (II) event4  - Logitech USB Keyboard Consumer Control: device removed
[     3.983] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.1/0003:046D:C31C.0003/input/input4/event4"
[     3.983] (II) XINPUT: Adding extended input device "Logitech USB Keyboard Consumer Control" (type: KEYBOARD, id 11)
[     3.983] (**) Option "xkb_model" "pc105"
[     3.983] (**) Option "xkb_layout" "us"
[     3.986] (II) event4  - Logitech USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     3.986] (II) event4  - Logitech USB Keyboard Consumer Control: device is a keyboard
[     3.988] (II) config/udev: Adding input device Logitech USB Keyboard System Control (/dev/input/event5)
[     3.988] (**) Logitech USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[     3.988] (**) Logitech USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[     3.988] (**) Logitech USB Keyboard System Control: Applying InputClass "system-keyboard"
[     3.988] (II) Using input driver 'libinput' for 'Logitech USB Keyboard System Control'
[     3.988] (**) Logitech USB Keyboard System Control: always reports core events
[     3.988] (**) Option "Device" "/dev/input/event5"
[     3.988] (**) Option "_source" "server/udev"
[     3.990] (II) event5  - Logitech USB Keyboard System Control: is tagged by udev as: Keyboard
[     3.990] (II) event5  - Logitech USB Keyboard System Control: device is a keyboard
[     3.991] (II) event5  - Logitech USB Keyboard System Control: device removed
[     4.010] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.1/0003:046D:C31C.0003/input/input5/event5"
[     4.010] (II) XINPUT: Adding extended input device "Logitech USB Keyboard System Control" (type: KEYBOARD, id 12)
[     4.010] (**) Option "xkb_model" "pc105"
[     4.010] (**) Option "xkb_layout" "us"
[     4.012] (II) event5  - Logitech USB Keyboard System Control: is tagged by udev as: Keyboard
[     4.012] (II) event5  - Logitech USB Keyboard System Control: device is a keyboard
[     4.013] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event10)
[     4.013] (II) No input driver specified, ignoring this device.
[     4.013] (II) This device may have been added with another device file.
[     4.013] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event8)
[     4.014] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event9)
[     4.014] (II) No input driver specified, ignoring this device.
[     4.014] (II) This device may have been added with another device file.
[     4.014] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event7)
[     4.014] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[     4.014] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[     4.014] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[     4.014] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[     4.014] (**) Eee PC WMI hotkeys: always reports core events
[     4.014] (**) Option "Device" "/dev/input/event7"
[     4.014] (**) Option "_source" "server/udev"
[     4.015] (II) event7  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     4.015] (II) event7  - Eee PC WMI hotkeys: device is a keyboard
[     4.016] (II) event7  - Eee PC WMI hotkeys: device removed
[     4.076] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input7/event7"
[     4.076] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 13)
[     4.076] (**) Option "xkb_model" "pc105"
[     4.076] (**) Option "xkb_layout" "us"
[     4.079] (II) event7  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     4.079] (II) event7  - Eee PC WMI hotkeys: device is a keyboard
[     4.080] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[     4.080] (II) No input driver specified, ignoring this device.
[     4.080] (II) This device may have been added with another device file.
[     5.677] (II) intel(0): EDID vendor "ACR", prod id 993
[     5.677] (II) intel(0): Using EDID range info for horizontal sync
[     5.677] (II) intel(0): Using EDID range info for vertical refresh
[     5.677] (II) intel(0): Printing DDC gathered Modelines:
[     5.677] (II) intel(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[     5.677] (II) intel(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     5.677] (II) intel(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[     5.677] (II) intel(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     5.678] (II) intel(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[     5.678] (II) intel(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[     5.678] (II) intel(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     5.678] (II) intel(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     5.678] (II) intel(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     5.678] (II) intel(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     5.678] (II) intel(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     5.678] (II) intel(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     5.678] (II) intel(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     5.678] (II) intel(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     5.678] (II) intel(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[     5.678] (II) intel(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     5.678] (II) intel(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[     5.678] (II) intel(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     5.678] (II) intel(0): Modeline "1280x720"x60.0   74.48  1280 1336 1472 1664  720 721 724 746 -hsync +vsync (44.8 kHz e)
[     5.678] (II) intel(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[     5.678] (II) intel(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[     5.678] (II) intel(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    10.454] (II) intel(0): resizing framebuffer to 3840x1080
[    10.487] (II) intel(0): switch to mode 1920x1080@60.0 on HDMI1 using pipe 1, position (1920, 0), rotation normal, reflection none
can you return
sudo mhwd -li
error from
For Intel and AMD GPUs, OpenGL is managed by Mesa, check if mesa package is installed. If it is, install mesa-demos and use glxinfo command.
glxinfo|grep OpenGL
$ sudo mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
         network-r8168            2016.04.20                true            PCI
And also, @Pouet, mesa package was installed all this time and still no progress.
$ glxinfo | grep OpenGL
Error: couldn't find RGB GLX visual or fbconfig
UPD
Solved by reinstalling /usr/lib/xorg/modules/extensions/libglx.so- all this time it was link to nvidia's libglx.so, my bad...
