Also here the update with nowNVIDIA 470.42.01 did break my opencl.
Darktable no longer is able to work with opencl, what really slows down things.
Any hint to get back to a setup with opencl enabled really would be great:
Kernel: 5.13.1-3-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b3619a0c-320f-40f8-9406-3cfef6e61856 ro quiet apparmor=1
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: MSI product: MS-7996 v: 1.0 serial: <filter>
Mobo: MSI model: H110M PRO-D (MS-7996) v: 1.0 serial: <filter>
UEFI-[Legacy]: American Megatrends v: 2.E0 date: 08/11/2017
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
status: Discharging
RAM: total: 31.32 GiB used: 3.34 GiB (10.7%)
Info: Quad Core model: Intel Core i5-6500 bits: 64 type: MCP arch: Skylake-S
family: 6 model-id: 5E (94) stepping: 3 microcode: EA cache: L2: 6 MiB
bogomips: 25610
Speed: 800 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Gigabyte
driver: nvidia v: 470.42.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c02 class-ID: 0300
Device-2: Logitech B525 HD Webcam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-7:6 chip-ID: 046d:0836 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.7x13.5")
s-diag: 692mm (27.3")
Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 470.42.01 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-3: Logitech [G533 Wireless Headset Dongle] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:4 chip-ID: 046d:0a66
class-ID: 0300
Device-4: Logitech B525 HD Webcam type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.13.1-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-9:8 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 5.46 TiB used: 2.86 TiB (52.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 1T00
rotation: SSD serial: <filter> rev: 00RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD40EZRX-00SPEB0
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EAVS-32D7B1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 1A01 scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224FB rev: SB00
dev-links: cdrom
ID-1: / raw-size: 33.97 GiB size: 33.19 GiB (97.69%) used: 27.58 GiB (83.1%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: b3619a0c-320f-40f8-9406-3cfef6e61856
ID-2: /data/smb/NAS_Home raw-size: N/A size: 5.41 TiB used: 3.95 TiB (73.0%)
fs: cifs dev: /dev/home label: N/A uuid: N/A
ID-3: /data/smb/NAS_Music raw-size: N/A size: 5.41 TiB
used: 3.95 TiB (73.0%) fs: cifs dev: /dev/music label: N/A uuid: N/A
ID-4: /home raw-size: 827.09 GiB size: 813.11 GiB (98.31%)
used: 397.23 GiB (48.9%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
label: LinuxHome_martin uuid: ad104060-2362-420c-8267-2106f5ea6bb2
ID-5: /home/<filter>/mnt/NAS-Backup raw-size: N/A size: 5.41 TiB
used: 3.95 TiB (73.0%) fs: nfs
remote: 192.168.178.39:/volume1/linuxbackup_nfs label: N/A uuid: N/A
ID-6: /media/martin/4TB-WD-Green raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 2.45 TiB (67.2%) fs: fuseblk dev: /dev/sdb2 maj-min: 8:18
label: 4TB-WD-Green uuid: 5CE42F07E42EE34E
ID-1: swap-1 type: partition size: 67.06 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: d32e68c3-cd11-4a58-8371-366197927d43
ID-1: /dev/sda1 maj-min: 8:1 size: 3.39 GiB fs: <superuser required>
ID-2: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
ID-3: /dev/sdc1 maj-min: 8:33 size: 930.99 GiB fs: <superuser required>
label: N/A uuid: DC3C81023C80D8C2
ID-4: /dev/sdc2 maj-min: 8:34 size: 535 MiB fs: <superuser required>
label: N/A uuid: 00FAFA30FAFA2218
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-3:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:4 info: Logitech [G533 Wireless Headset Dongle]
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 046d:0a66 class-ID: 0300
Device-3: 1-6:5 info: X-Rite i1 Display Pro type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0765:5020 class-ID: 0300
Device-4: 1-7:6 info: Logitech B525 HD Webcam type: Audio,Video
power: 500mA chip-ID: 046d:0836 class-ID: 0e02 serial: <filter>
Device-5: 1-8:7 info: Holtek Noppoo Choc Mid type: Keyboard,Mouse
power: 100mA chip-ID: 04d9:1829 class-ID: 0301
Device-6: 1-9:8 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Device-7: 1-10:9 info: Alcor Micro AU6477 Card Reader Controller
type: Mass Storage,HID driver: hid-generic,usb-storage,usbhid interfaces: 2
rev: 2.0 speed: 480 Mb/s power: 250mA chip-ID: 058f:6364 class-ID: 0300
serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-4: 2-1:2 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0620 class-ID: 0900
Device-1: 2-2:3 info: Realtek USB3.0 Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 0bda:0321 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-4:2 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.0 C mobo: 29.8 C gpu: nvidia temp: 58 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 28%
Processes: 251 Uptime: 25m wakeups: 8 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1678 pacman: 1675 lib: 447
flatpak: 0 snap: 3 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.05
glxinfo -B
name of display: :0
display: :0 screen: 0
direct rendering: Yes
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 3072 MB
Total available memory: 3072 MB
Currently available dedicated video memory: 2396 MB
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 470.42.01
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6.0 NVIDIA 470.42.01
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 470.42.01
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
clinfo -l
Platform #0: NVIDIA CUDA
`-- Device #0: NVIDIA GeForce GTX 1060 3GB
darktable-cltest does abort with errors …
darktable-cltest
(process:16543): libsecret-CRITICAL **: 15:58:42.839: secret_service_load_collections_sync: assertion 'paths != NULL' failed
0.038198 [opencl_init] opencl related configuration options:
0.038212 [opencl_init]
0.038215 [opencl_init] opencl: 1
0.038217 [opencl_init] opencl_scheduling_profile: 'very fast GPU'
0.038220 [opencl_init] opencl_library: ''
0.038236 [opencl_init] opencl_memory_requirement: 768
0.038241 [opencl_init] opencl_memory_headroom: 400
0.038245 [opencl_init] opencl_device_priority: '*/!0,*/*/*/!0,*'
0.038262 [opencl_init] opencl_mandatory_timeout: 200
0.038266 [opencl_init] opencl_size_roundup: 16
0.038283 [opencl_init] opencl_async_pixelpipe: 0
0.038285 [opencl_init] opencl_synch_cache: active module
0.038289 [opencl_init] opencl_number_event_handles: 25
0.038292 [opencl_init] opencl_micro_nap: 1000
0.038295 [opencl_init] opencl_use_pinned_memory: 0
0.038298 [opencl_init] opencl_use_cpu_devices: 0
0.038300 [opencl_init] opencl_avoid_atomics: 0
0.038303 [opencl_init]
0.038541 [opencl_init] found opencl runtime library 'libOpenCL'
0.038572 [opencl_init] opencl library 'libOpenCL' found on your system and loaded
0.069171 [opencl_init] found 1 platform
0.069190 [opencl_init] found 1 device
0.069365 [opencl_init] device 0 `NVIDIA GeForce GTX 1060 3GB' has sm_20 support.
0.069469 [opencl_init] device 0 `NVIDIA GeForce GTX 1060 3GB' supports image sizes of 16384 x 32768
0.069473 [opencl_init] device 0 `NVIDIA GeForce GTX 1060 3GB' allows GPU memory allocations of up to 753MB
[opencl_init] device 0: NVIDIA GeForce GTX 1060 3GB
GLOBAL_MEM_SIZE: 3014MB
MAX_WORK_GROUP_SIZE: 1024
MAX_WORK_ITEM_DIMENSIONS: 3
MAX_WORK_ITEM_SIZES: [ 1024 1024 64 ]
DRIVER_VERSION: 470.42.01
DEVICE_VERSION: OpenCL 3.0 CUDA
0.136638 [opencl_init] options for OpenCL compiler: -w -cl-fast-relaxed-math -DNVIDIA_SM_20=1 -DNVIDIA=1 -I"/opt/darktable/share/darktable/kernels"
0.136836 [opencl_init] compiling program `demosaic_ppg.cl' ..
0.138229 [opencl_load_program] loaded cached binary program from file '/home/martin/.cache/darktable/cached_kernels_for_NVIDIAGeForceGTX10603GB_4704201/demosaic_ppg.cl.bin' MD5: 'a5fd113ee0bff78399ed254b8d2d5d74'
0.138237 [opencl_load_program] successfully loaded program from '/opt/darktable/share/darktable/kernels/demosaic_ppg.cl' MD5: 'a5fd113ee0bff78399ed254b8d2d5d74'
0.139027 [opencl_build_program] successfully built program
0.139034 [opencl_build_program] BUILD STATUS: 0
0.139036 BUILD LOG:
0.139038
0.139060 [opencl_init] compiling program `atrous.cl' ..
0.139127 [opencl_load_program] loaded cached binary program from file '/home/martin/.cache/darktable/cached_kernels_for_NVIDIAGeForceGTX10603GB_4704201/atrous.cl.bin' MD5: 'de6e8a822faccd9faafee9c1eca6e594'
0.139132 [opencl_load_program] successfully loaded program from '/opt/darktable/share/darktable/kernels/atrous.cl' MD5: 'de6e8a822faccd9faafee9c1eca6e594'
0.139347 [opencl_build_program] successfully built program
0.139353 [opencl_build_program] BUILD STATUS: 0
0.139355 BUILD LOG:
0.139356
0.139377 [opencl_init] compiling program `basic.cl' ..
0.139578 [opencl_fopen_stat] could not open file `/home/martin/.cache/darktable/cached_kernels_for_NVIDIAGeForceGTX10603GB_4704201/basic.cl.bin'!
0.139585 [opencl_load_program] could not load cached binary program, trying to compile source
0.139643 [opencl_load_program] successfully loaded program from '/opt/darktable/share/darktable/kernels/basic.cl' MD5: 'b52d2878385ca5a98f9e430317c4a2eb'
0.262476 [opencl_build_program] could not build program: -9999
0.262490 [opencl_build_program] BUILD STATUS: -2
0.262493 BUILD LOG:
0.262494 ptxas fatal : Unresolved extern function '__nv_fast_log2f'
0.262512 [opencl_init] failed to compile program `basic.cl'!
0.262521 [opencl_init] no suitable devices found.
0.262524 [opencl_init] FINALLY: opencl is NOT AVAILABLE on this system.
0.262526 [opencl_init] initial status of opencl enabled flag is OFF.
So indeed really something regarding the needed opencl lib (?) has happened.
Any hint is welcome!
No. I said it is not in Stable because you wrote 472. Then I edited the post because I noticed you probably meant 470, which you confirmed. I didn’t rewrite the post. 470 is the current driver on all branches.
