[openbox] v18.0 - basic edition
openbox
iso
#21
I don’t know - I have never made an install to an usb. You should probably watch out for grub.
I think this link could be of help
https://wiki.archlinux.org/index.php/Installing_Arch_Linux_on_a_USB_key
Is there a way to create a tails like installation of manjaro?
#22
OK I did it. It installed perfectly to my USB stick. I stuck the bootloader to the stick also. And it did not mess with my bootloader on the internal drive. Could you please tell me what I need to install to get multimedia working? Thanks a lot. Mike
#23
Have a look a the Desktop-Packages for the more complete openbox.
It is WIP but lines with
  • >basic pkg is only installed to minimal edition
  • >extra pkg is only installed to full edition
The rest installs to both editions
#24
Thank you much appreciated.
#25
Select not to install Grub on the USB stick (not to install it at all, actually) if you don’t want to boot it on a different machine.
The main system’s Grub will be able to detect the OS on the USB stick through sudo update-grub
#26
Cool. Thanks!
closed #27
