Black screen crash when entering sleep mode
Hi there,
I am observing black screen crashes when entering sleep mode with my MSI Laptop with AMD Ryzen 9 5900HX with Radeon Graphics. I am on 5.15.94-1-MANJARO. (Also happens on Kernel > 6)
It happens random, and I cannot figure out any schematic.
The end result is a black screen, the fan still running and the keyboard layout being turned on. It does not shut off / sleep properly.
I would be very thankful if somebody would invest the time to debug this with me :slight_smile:
I might be getting a similar experience. I can’t pinpoint whether black screen crash on sleep or on resume.
My laptop is typically connected to a monitor (built in KVM) via thunderbolt 4. This also provides the power. When I switch off monitor the laptop usually goes into sleep. When I resume I usually turn on screen then monetarily open/shut the laptop lid to resume the system.
Since the last month (or so) I find that it doesn’t always come back up, just seeing a blank screen on the laptop monitor. Like I said, might be when trying to sleep or when coming back up.
I’m having both. By enabling sleep mode and by waking up. At entering sleep mode is more frequent though.
I also have those issues without external Power sources etc.
Some issues came from IOMMU errors in the past, but I am flushing this one. Now I am back on less frequent errors as you are describing @johnnyfleet
so when it happens next time, reboot, and then provide logs from the failed suspend:
journalctl -b-1 -p4 --no-pager
@brahma there we go :frowning: Happened straight today:
full log is here: https://pastebin.mozilla.org/D5D5tv2K
Last 500 lines:
                                                    refreshPropertyOnProxy@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/util.js:73:39
                                                    _translateNewSignals/<@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:265:18
                                                    _translateNewSignals@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:264:50
                                                    _onProxySignal/<@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:291:56
                                                    _onProxySignal@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:291:38
                                                    async*AppIndicatorsAppIndicator/<@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:102:76
Mär 03 12:17:23 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1301-panel' in path /tmp/.org.chromium.Chromium.QUUHP9
Mär 03 12:17:23 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1302-panel' in path /tmp/.org.chromium.Chromium.DOAwpR
Mär 03 12:17:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
                                                    _promisify/proto[asyncFunc]/</<@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:446:45
                                                    ### Promise created here: ###
                                                    getProxyProperty@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/util.js:55:31
Mär 03 12:17:32 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1303-panel' in path /tmp/.org.chromium.Chromium.fYnGdJ
Mär 03 12:17:32 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1304-panel' in path /tmp/.org.chromium.Chromium.xLu1av
Mär 03 12:17:40 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1305-panel' in path /tmp/.org.chromium.Chromium.ajgik6
Mär 03 12:17:40 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1306-panel' in path /tmp/.org.chromium.Chromium.2co789
Mär 03 12:17:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:18:06 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1307-panel' in path /tmp/.org.chromium.Chromium.A38939
Mär 03 12:18:07 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1308-panel' in path /tmp/.org.chromium.Chromium.NvEDx2
Mär 03 12:18:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:18:31 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1309-panel' in path /tmp/.org.chromium.Chromium.YXj9pn
Mär 03 12:18:31 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1310-panel' in path /tmp/.org.chromium.Chromium.QTUiiI
Mär 03 12:18:32 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1311-panel' in path /tmp/.org.chromium.Chromium.AWu22G
Mär 03 12:18:32 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1312-panel' in path /tmp/.org.chromium.Chromium.Xva2QQ
Mär 03 12:18:48 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1313-panel' in path /tmp/.org.chromium.Chromium.Hwtamd
Mär 03 12:18:49 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1314-panel' in path /tmp/.org.chromium.Chromium.Aihbs6
Mär 03 12:18:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:19:13 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1315-panel' in path /tmp/.org.chromium.Chromium.2Dc25Z
Mär 03 12:19:13 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1316-panel' in path /tmp/.org.chromium.Chromium.6HtHnD
Mär 03 12:19:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:19:28 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1317-panel' in path /tmp/.org.chromium.Chromium.pCESjq
Mär 03 12:19:28 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1318-panel' in path /tmp/.org.chromium.Chromium.7yKZf6
Mär 03 12:19:29 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1319-panel' in path /tmp/.org.chromium.Chromium.BCp6Ah
Mär 03 12:19:29 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1320-panel' in path /tmp/.org.chromium.Chromium.7gHuTi
Mär 03 12:19:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:20:02 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1321-panel' in path /tmp/.org.chromium.Chromium.Cg3Hru
Mär 03 12:20:03 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1322-panel' in path /tmp/.org.chromium.Chromium.hDzHnc
Mär 03 12:20:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:20:26 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1323-panel' in path /tmp/.org.chromium.Chromium.2WBlER
Mär 03 12:20:26 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1324-panel' in path /tmp/.org.chromium.Chromium.XFhXo2
Mär 03 12:20:26 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1324-panel' in path /tmp/.org.chromium.Chromium.u05Sv1
Mär 03 12:20:27 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1326-panel' in path /tmp/.org.chromium.Chromium.1rk8dB
Mär 03 12:20:27 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1327-panel' in path /tmp/.org.chromium.Chromium.nI3US9
Mär 03 12:20:28 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1328-panel' in path /tmp/.org.chromium.Chromium.3FiY8s
Mär 03 12:20:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:21:05 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1329-panel' in path /tmp/.org.chromium.Chromium.Paq7KX
Mär 03 12:21:06 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1330-panel' in path /tmp/.org.chromium.Chromium.guBCYq
Mär 03 12:21:06 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1332-panel' in path /tmp/.org.chromium.Chromium.6OWPno
Mär 03 12:21:21 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1333-panel' in path /tmp/.org.chromium.Chromium.L9WJsh
Mär 03 12:21:22 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1334-panel' in path /tmp/.org.chromium.Chromium.ntFxGk
Mär 03 12:21:22 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1335-panel' in path /tmp/.org.chromium.Chromium.yQSzW1
Mär 03 12:21:23 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1336-panel' in path /tmp/.org.chromium.Chromium.pYpAyb
Mär 03 12:21:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:21:45 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1337-panel' in path /tmp/.org.chromium.Chromium.bQEeRT
Mär 03 12:21:46 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1338-panel' in path /tmp/.org.chromium.Chromium.yIwJJp
Mär 03 12:21:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:22:05 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1339-panel' in path /tmp/.org.chromium.Chromium.qi1PbM
Mär 03 12:22:05 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1340-panel' in path /tmp/.org.chromium.Chromium.w1Ijod
Mär 03 12:22:07 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1341-panel' in path /tmp/.org.chromium.Chromium.pevpDh
Mär 03 12:22:07 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1342-panel' in path /tmp/.org.chromium.Chromium.HRo1FY
Mär 03 12:22:11 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1343-panel' in path /tmp/.org.chromium.Chromium.9RTk0A
Mär 03 12:22:11 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1344-panel' in path /tmp/.org.chromium.Chromium.rQdXGo
Mär 03 12:22:16 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1345-panel' in path /tmp/.org.chromium.Chromium.OVRY75
Mär 03 12:22:16 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1346-panel' in path /tmp/.org.chromium.Chromium.92mnox
Mär 03 12:22:17 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1347-panel' in path /tmp/.org.chromium.Chromium.4ymjLk
Mär 03 12:22:17 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1348-panel' in path /tmp/.org.chromium.Chromium.KACyiS
Mär 03 12:22:18 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1349-panel' in path /tmp/.org.chromium.Chromium.U6UUsK
Mär 03 12:22:19 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1350-panel' in path /tmp/.org.chromium.Chromium.bIX4qp
Mär 03 12:22:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:22:36 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1351-panel' in path /tmp/.org.chromium.Chromium.e25upc
Mär 03 12:22:36 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1352-panel' in path /tmp/.org.chromium.Chromium.3bnSWQ
Mär 03 12:22:41 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1353-panel' in path /tmp/.org.chromium.Chromium.2l1zIT
Mär 03 12:22:41 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1354-panel' in path /tmp/.org.chromium.Chromium.7bbMQw
Mär 03 12:22:44 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1355-panel' in path /tmp/.org.chromium.Chromium.r3CAQJ
Mär 03 12:22:45 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1356-panel' in path /tmp/.org.chromium.Chromium.jZyKV1
Mär 03 12:22:47 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1357-panel' in path /tmp/.org.chromium.Chromium.3ntGpN
Mär 03 12:22:50 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1358-panel' in path /tmp/.org.chromium.Chromium.saCpct
Mär 03 12:22:52 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1359-panel' in path /tmp/.org.chromium.Chromium.LaZZ7i
Mär 03 12:22:53 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1360-panel' in path /tmp/.org.chromium.Chromium.Ku7ZZY
Mär 03 12:22:54 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1361-panel' in path /tmp/.org.chromium.Chromium.inY1t1
Mär 03 12:22:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:22:55 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1362-panel' in path /tmp/.org.chromium.Chromium.SQbHlC
Mär 03 12:22:58 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1363-panel' in path /tmp/.org.chromium.Chromium.ix6KOf
Mär 03 12:23:00 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1364-panel' in path /tmp/.org.chromium.Chromium.Haafb6
Mär 03 12:23:01 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1366-panel' in path /tmp/.org.chromium.Chromium.AYEhCp
Mär 03 12:23:04 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1367-panel' in path /tmp/.org.chromium.Chromium.uzS00c
Mär 03 12:23:06 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1368-panel' in path /tmp/.org.chromium.Chromium.ZkoEjP
Mär 03 12:23:08 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1369-panel' in path /tmp/.org.chromium.Chromium.lxigKP
Mär 03 12:23:08 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1370-panel' in path /tmp/.org.chromium.Chromium.EDO2Y3
Mär 03 12:23:08 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1371-panel' in path /tmp/.org.chromium.Chromium.EDO2Y3
Mär 03 12:23:08 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1371-panel' in path /tmp/.org.chromium.Chromium.TuVvLc
Mär 03 12:23:10 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1372-panel' in path /tmp/.org.chromium.Chromium.daIipT
Mär 03 12:23:19 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1373-panel' in path /tmp/.org.chromium.Chromium.7JwOmv
Mär 03 12:23:20 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1374-panel' in path /tmp/.org.chromium.Chromium.AxcGzL
Mär 03 12:23:24 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1375-panel' in path /tmp/.org.chromium.Chromium.Sch6lv
Mär 03 12:23:24 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1376-panel' in path /tmp/.org.chromium.Chromium.oZa9pN
Mär 03 12:23:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:23:26 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1377-panel' in path /tmp/.org.chromium.Chromium.4PivUE
Mär 03 12:23:27 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1378-panel' in path /tmp/.org.chromium.Chromium.yeclw3
Mär 03 12:23:28 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1379-panel' in path /tmp/.org.chromium.Chromium.P5iqDo
Mär 03 12:23:30 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1380-panel' in path /tmp/.org.chromium.Chromium.1VzeLk
Mär 03 12:23:31 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1381-panel' in path /tmp/.org.chromium.Chromium.TFCNa7
Mär 03 12:23:32 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1382-panel' in path /tmp/.org.chromium.Chromium.Xsp9eX
Mär 03 12:23:33 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1383-panel' in path /tmp/.org.chromium.Chromium.eHXNH4
Mär 03 12:23:38 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1384-panel' in path /tmp/.org.chromium.Chromium.R51eR4
Mär 03 12:23:40 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1385-panel' in path /tmp/.org.chromium.Chromium.b37gN7
Mär 03 12:23:43 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1386-panel' in path /tmp/.org.chromium.Chromium.9qXtSJ
Mär 03 12:23:45 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1387-panel' in path /tmp/.org.chromium.Chromium.W4dJZM
Mär 03 12:23:45 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1388-panel' in path /tmp/.org.chromium.Chromium.skn8sm
Mär 03 12:23:45 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1389-panel' in path /tmp/.org.chromium.Chromium.Cas7D8
Mär 03 12:23:47 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1390-panel' in path /tmp/.org.chromium.Chromium.80oQHl
Mär 03 12:23:47 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1390-panel' in path /tmp/.org.chromium.Chromium.Aq02vW
Mär 03 12:23:48 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1392-panel' in path /tmp/.org.chromium.Chromium.OOUmzM
Mär 03 12:23:48 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1393-panel' in path /tmp/.org.chromium.Chromium.3J1Pcz
Mär 03 12:23:54 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1394-panel' in path /tmp/.org.chromium.Chromium.9x3w8U
Mär 03 12:23:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:24:07 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1395-panel' in path /tmp/.org.chromium.Chromium.yZts4R
Mär 03 12:24:07 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1396-panel' in path /tmp/.org.chromium.Chromium.fSNWWw
Mär 03 12:24:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:24:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:25:04 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1397-panel' in path /tmp/.org.chromium.Chromium.vdgN9W
Mär 03 12:25:06 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1398-panel' in path /tmp/.org.chromium.Chromium.kQQ6Ar
Mär 03 12:25:08 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1399-panel' in path /tmp/.org.chromium.Chromium.uE6Hmq
Mär 03 12:25:09 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1400-panel' in path /tmp/.org.chromium.Chromium.86Itvj
Mär 03 12:25:17 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1401-panel' in path /tmp/.org.chromium.Chromium.8iqHoJ
Mär 03 12:25:19 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1402-panel' in path /tmp/.org.chromium.Chromium.ynUHmI
Mär 03 12:25:22 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1403-panel' in path /tmp/.org.chromium.Chromium.ntirS4
Mär 03 12:25:23 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1404-panel' in path /tmp/.org.chromium.Chromium.YqKUq5
Mär 03 12:25:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:25:29 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1405-panel' in path /tmp/.org.chromium.Chromium.KTJZ6X
Mär 03 12:25:29 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1406-panel' in path /tmp/.org.chromium.Chromium.c2JZDA
Mär 03 12:25:31 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1407-panel' in path /tmp/.org.chromium.Chromium.obPUDw
Mär 03 12:25:32 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1408-panel' in path /tmp/.org.chromium.Chromium.jnucEV
Mär 03 12:25:33 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1409-panel' in path /tmp/.org.chromium.Chromium.TPWRTL
Mär 03 12:25:35 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1410-panel' in path /tmp/.org.chromium.Chromium.8K2Rv3
Mär 03 12:25:35 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1411-panel' in path /tmp/.org.chromium.Chromium.Zsnac9
Mär 03 12:25:36 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1412-panel' in path /tmp/.org.chromium.Chromium.OYTt3W
Mär 03 12:25:37 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1413-panel' in path /tmp/.org.chromium.Chromium.Sn60DV
Mär 03 12:25:38 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1414-panel' in path /tmp/.org.chromium.Chromium.sWyff8
Mär 03 12:25:40 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1415-panel' in path /tmp/.org.chromium.Chromium.nfnlLd
Mär 03 12:25:40 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1416-panel' in path /tmp/.org.chromium.Chromium.tV0Tfr
Mär 03 12:25:40 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1417-panel' in path /tmp/.org.chromium.Chromium.huMiUD
Mär 03 12:25:41 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1418-panel' in path /tmp/.org.chromium.Chromium.vQBpFy
Mär 03 12:25:44 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1419-panel' in path /tmp/.org.chromium.Chromium.l3pgyJ
Mär 03 12:25:46 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1420-panel' in path /tmp/.org.chromium.Chromium.A6Ppnd
Mär 03 12:25:46 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1420-panel' in path /tmp/.org.chromium.Chromium.YEXFwQ
Mär 03 12:25:47 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1422-panel' in path /tmp/.org.chromium.Chromium.JgdJz3
Mär 03 12:25:49 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1423-panel' in path /tmp/.org.chromium.Chromium.Nmfboy
Mär 03 12:25:50 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1424-panel' in path /tmp/.org.chromium.Chromium.GQApWt
Mär 03 12:25:51 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1425-panel' in path /tmp/.org.chromium.Chromium.3RHSek
Mär 03 12:25:54 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1426-panel' in path /tmp/.org.chromium.Chromium.2Dip95
Mär 03 12:25:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:25:59 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1427-panel' in path /tmp/.org.chromium.Chromium.fAevXa
Mär 03 12:26:00 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1428-panel' in path /tmp/.org.chromium.Chromium.IfHmWI
Mär 03 12:26:01 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1429-panel' in path /tmp/.org.chromium.Chromium.pOQIXn
Mär 03 12:26:03 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1430-panel' in path /tmp/.org.chromium.Chromium.gnRaPs
Mär 03 12:26:06 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1431-panel' in path /tmp/.org.chromium.Chromium.f1HquI
Mär 03 12:26:07 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1432-panel' in path /tmp/.org.chromium.Chromium.E3XcG9
Mär 03 12:26:15 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1433-panel' in path /tmp/.org.chromium.Chromium.vry4oN
Mär 03 12:26:15 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1434-panel' in path /tmp/.org.chromium.Chromium.zn9i5q
Mär 03 12:26:16 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1435-panel' in path /tmp/.org.chromium.Chromium.2HVsxH
Mär 03 12:26:17 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1436-panel' in path /tmp/.org.chromium.Chromium.IsLtzz
Mär 03 12:26:20 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1437-panel' in path /tmp/.org.chromium.Chromium.eNqWiW
Mär 03 12:26:21 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1438-panel' in path /tmp/.org.chromium.Chromium.XkHIyI
Mär 03 12:26:24 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1439-panel' in path /tmp/.org.chromium.Chromium.rZxlLh
Mär 03 12:26:24 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1440-panel' in path /tmp/.org.chromium.Chromium.HfRW9e
Mär 03 12:26:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:26:34 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1441-panel' in path /tmp/.org.chromium.Chromium.KBqQ7n
Mär 03 12:26:35 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1442-panel' in path /tmp/.org.chromium.Chromium.phgXhr
Mär 03 12:26:35 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1443-panel' in path /tmp/.org.chromium.Chromium.obT18X
Mär 03 12:26:36 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1444-panel' in path /tmp/.org.chromium.Chromium.hYX6Kq
Mär 03 12:26:40 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1445-panel' in path /tmp/.org.chromium.Chromium.W7H3bp
Mär 03 12:26:41 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1446-panel' in path /tmp/.org.chromium.Chromium.48BOrv
Mär 03 12:26:43 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1447-panel' in path /tmp/.org.chromium.Chromium.ULoaSB
Mär 03 12:26:44 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1448-panel' in path /tmp/.org.chromium.Chromium.qVhgzv
Mär 03 12:26:45 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1449-panel' in path /tmp/.org.chromium.Chromium.Gk4hJp
Mär 03 12:26:46 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1450-panel' in path /tmp/.org.chromium.Chromium.1qnI2D
Mär 03 12:26:46 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1450-panel' in path /tmp/.org.chromium.Chromium.8OIfRU
Mär 03 12:26:48 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1452-panel' in path /tmp/.org.chromium.Chromium.M0awLE
Mär 03 12:26:50 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1453-panel' in path /tmp/.org.chromium.Chromium.qI4SYD
Mär 03 12:26:51 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1454-panel' in path /tmp/.org.chromium.Chromium.fOgvqQ
Mär 03 12:26:51 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1918]: discord1, Impossible to lookup icon for 'discord1_1454-panel' in path /tmp/.org.chromium.Chromium.CkivG0
Mär 03 12:26:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:27:05 florian-manjaro bluetoothd[1258]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Mär 03 12:27:05 florian-manjaro gsd-media-keys[2204]: Unable to get default sink
Mär 03 12:27:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:27:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:28:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:28:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:29:25 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:29:55 florian-manjaro gnome-shell[1918]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 03 12:30:24 florian-manjaro kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0x98 on isa0060/serio0).
Mär 03 12:30:24 florian-manjaro kernel: atkbd serio0: Use 'setkeycodes e018 <keycode>' to make it known.
Mär 03 12:30:24 florian-manjaro kernel: atkbd serio0: Unknown key released (translated set 2, code 0x98 on isa0060/serio0).
Mär 03 12:30:24 florian-manjaro gnome-shell[1918]: Ignoring length property that isn't a number at line 21, col 17
Mär 03 12:30:24 florian-manjaro gnome-shell[1918]: Ignoring length property that isn't a number at line 22, col 18
Mär 03 12:30:24 florian-manjaro gnome-shell[1918]: Ignoring length property that isn't a number at line 1, col 13
Mär 03 12:30:24 florian-manjaro gnome-shell[1918]: Ignoring length property that isn't a number at line 1, col 32
Mär 03 12:30:24 florian-manjaro gnome-shell[1918]: Ignoring length property that isn't a number at line 1, col 31
Mär 03 12:30:24 florian-manjaro gnome-shell[1918]: Ignoring length property that isn't a number at line 1, col 39
Mär 03 12:30:24 florian-manjaro gnome-shell[1918]: Ignoring length property that isn't a number at line 1, col 50
Mär 03 12:30:24 florian-manjaro gnome-shell[1918]: g_signal_handler_disconnect: assertion 'handler_id > 0' failed
there are the same logs repeating over and over, and nothing about suspension…
provide system info:
inxi -zav7
and also try with the 6.1 kernel
I am already on the 6.1 Kernel because I thought about this as source also :confused:
  Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID= rw quiet
    cryptdevice=UUID= luks
    root=/dev/mapper/luks- splash
    iommu.strict=1 apparmor=1 security=apparmor udev.log_priority=3
    pci=nommconf resume=UUID=
    resume_offset=16764928
  Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
  Type: Laptop System: Micro-Star product: Delta 15 A5EFK v: REV:1.0
  Mobo: Micro-Star model: MS-15CK v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: E15CKAMS.106 date: 04/07/2022
  ID-1: BAT1 charge: 68.3 Wh (92.5%) condition: 73.8/80.3 Wh (91.9%)
    volts: 16.6 min: 15.2 model: MSI Corp. MS-15CK type: Li-ion serial: N/A
    status: not charging
  RAM: total: 30.74 GiB used: 7.67 GiB (24.9%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1430 high: 3300 min/max: 1200/4679 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1361 2: 1200
    3: 1200 4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 9: 1915 10: 1200 11: 1198
    12: 1200 13: 1915 14: 1200 15: 1200 16: 3300 bogomips: 105449
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 03:00.0
    chip-ID: 1002:73df class-ID: 0380
  Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: none
    bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 32.0 C
  Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: Sharp LQ156M1JW03 built: 2021 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon Graphics (renoir LLVM
    15.0.7 DRM 3.49 6.1.12-1-MANJARO) direct-render: Yes
  Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
    class-ID: 0403
  Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Micro-Star MSI
    driver: snd_rn_pci_acp3x v: kernel
    alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
  Sound Interface: sndio v: N/A running: no
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2725
    class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:2
    chip-ID: 8087:0032 class-ID: e001
  Device-1: luks- maj-min: 254:1
    type: LUKS dm: dm-1 size: 931.5 GiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 931.51 GiB
  Device-2: luks- maj-min: 254:0
    type: LUKS dm: dm-0 size: 931.21 GiB
  Components:
  p-1: nvme1n1p2 maj-min: 259:8 size: 931.22 GiB
  Local Storage: total: 2.75 TiB used: 984.41 GiB (34.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: P6MA001 temp: 28.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Samsung model: SSD 980 1TB
    lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 26.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Toshiba model: MQ01UBD100
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: HDD
    rpm: 5400 serial: <filter> scheme: GPT
  ID-1: / raw-size: 931.21 GiB size: 915.52 GiB (98.32%)
    used: 514.77 GiB (56.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks- label: N/A
    uuid:
    used: 476 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:7
    label: NO_LABEL uuid: 2AB8-0BAC
  ID-3: /run/timeshift/4970/backup raw-size: 931.5 GiB
    size: 915.8 GiB (98.32%) used: 469.65 GiB (51.3%) fs: ext4 dev: /dev/dm-1
    maj-min: 254:1 mapped: luks
    label: LinuxBackup1 uuid:
  ID-1: swap-1 type: file size: 38 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: SYSTEM
    uuid: 343B-9A99
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 932.72 GiB fs: bitlocker
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 900 MiB fs: ntfs
    label: WinRE tools uuid: 98D43CA7D43C8A10
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 19.85 GiB fs: ntfs
    label: BIOS_RVY uuid:
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 1-4:2 info: Micro Star MysticLight MS-1562 type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 1462:1564 class-ID: 0300 serial: <filter>
  Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-2:2 info: Toshiba America External USB 3.0 type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
    chip-ID: 0480:a200 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-3:2 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
    class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 38.8 C mobo: N/A
  GPU: device: amdgpu temp: 31.0 C device: amdgpu temp: 32.0 C mem: 28.0 C
    fan: 0 watts: 7.00
  Processes: 513 Uptime: 4h 12m wakeups: 1841 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 1717 pm: pacman pkgs: 1714 libs: 388
  tools: gnome-software,pamac,yay pm: flatpak pkgs: 3 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.25
I deleted the UUIDs for privacy reasons.
Thank you very much for helping me here :slight_smile:
in the pastebin logs there is nothing related to suspending… it looks like it didnt even suspended… but i found this there:
Mär 03 10:54:29 florian-manjaro kernel: ACPI: button: The lid device is not compliant to SW_LID.
and also looking at the inxi output, you are on wayland:
so switch to xorg and see if it helped
So that means, closing the LID does not work ?
Interestingly, it works sometimes. I would avoid switching to xorg TBH, it causes systems freezes for me, but I can try if absolutely necessary.
thats the only log i found that is related to suspending… as mentioned there si nothing else, it just looks like the system didnt even suspended… there should be some logs, like: the system is suspending…
did xorg causes also issues on the 6.1 kernel?
Not tested, yet will try out!
What still makes me wonder, is that the notebook crashed. Like no GUI / Black screen and this also does not show up in the logs.
Thank you for looking into this, is it okay, when I would reopen this on the next event?
Okay next crash @brahma
Mär 09 20:18:46 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:19:16 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:19:47 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:20:16 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:20:46 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:21:16 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:21:46 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:22:16 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:22:46 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:23:16 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:23:46 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:24:16 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:24:46 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:25:16 florian-manjaro gnome-shell[1836]: JS ERROR: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownProperty: Property org.kde.StatusNotifierItem.IconAccessibleDesc was not found in object /StatusNotifierItem
Mär 09 20:25:44 florian-manjaro kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0x98 on isa0060/serio0).
Mär 09 20:25:44 florian-manjaro kernel: atkbd serio0: Use 'setkeycodes e018 <keycode>' to make it known.
Mär 09 20:25:44 florian-manjaro kernel: atkbd serio0: Unknown key released (translated set 2, code 0x98 on isa0060/serio0).
Mär 09 20:25:44 florian-manjaro gnome-shell[1836]: JS ERROR: Extension x11gestures@joseexposito.github.io: TypeError: obj._toucheggTracker is undefined
                                                    unhook@/usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/src/v40/EntryPoint40.js:171:5
                                                    stop@/usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/src/v40/EntryPoint40.js:160:23
                                                    disable@/usr/share/gnome-shell/extensions/x11gestures@joseexposito.github.io/extension.js:63:18
                                                    _callExtensionDisable@resource:///org/gnome/shell/ui/extensionSystem.js:125:32
                                                    _onEnabledExtensionsChanged/<@resource:///org/gnome/shell/ui/extensionSystem.js:536:45
                                                    _onEnabledExtensionsChanged@resource:///org/gnome/shell/ui/extensionSystem.js:536:24
                                                    _sessionUpdated@resource:///org/gnome/shell/ui/extensionSystem.js:658:14
                                                    _emit@resource:///org/gnome/gjs/modules/core/_signals.js:114:47
                                                    _sync@resource:///org/gnome/shell/ui/sessionMode.js:204:14
                                                    pushMode@resource:///org/gnome/shell/ui/sessionMode.js:163:14
                                                    activate@resource:///org/gnome/shell/ui/screenShield.js:620:34
                                                    lock@resource:///org/gnome/shell/ui/screenShield.js:666:14
                                                    _prepareForSleep@resource:///org/gnome/shell/ui/screenShield.js:250:22
                                                    _prepareForSleep@resource:///org/gnome/shell/misc/loginManager.js:205:14
                                                    _convertToNativeSignal@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:152:19
Mär 09 20:25:44 florian-manjaro gnome-shell[1836]: g_signal_handler_disconnect: assertion 'handler_id > 0' failed
Mär 09 20:25:45 florian-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Mär 09 20:25:46 florian-manjaro org.gnome.Nautilus[4608]: Traceback (most recent call last):
Mär 09 20:25:46 florian-manjaro org.gnome.Nautilus[4608]:   File "/usr/share/nautilus-python/extensions/syncstate-Nextcloud.py", line 234, in get_file_items
Mär 09 20:25:46 florian-manjaro org.gnome.Nautilus[4608]:     return self.ask_for_menu_items(files)
Mär 09 20:25:46 florian-manjaro org.gnome.Nautilus[4608]:   File "/usr/share/nautilus-python/extensions/syncstate-Nextcloud.py", line 251, in ask_for_menu_items
Mär 09 20:25:46 florian-manjaro org.gnome.Nautilus[4608]:     if not socketConnect.read_socket_data_with_timeout(timeout - dt):
Mär 09 20:25:46 florian-manjaro org.gnome.Nautilus[4608]:   File "/usr/share/nautilus-python/extensions/syncstate-Nextcloud.py", line 118, in read_socket_data_with_timeout
Mär 09 20:25:46 florian-manjaro org.gnome.Nautilus[4608]:     self._sock.settimeout(timeout)
Mär 09 20:25:46 florian-manjaro org.gnome.Nautilus[4608]: OSError: [Errno 9] Ungßltiger Dateideskriptor
Mär 09 20:25:46 florian-manjaro file-roller[6535]: Using GtkSettings:gtk-application-prefer-dark-theme together with HdyStyleManager is unsupported. Please use HdyStyleManager:color-scheme instead.
Mär 09 20:33:02 florian-manjaro kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Mär 09 20:33:02 florian-manjaro kernel: pci 0000:00:00.2: PCI INT A: no GSI
Mär 09 20:33:02 florian-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Mär 09 20:33:08 florian-manjaro appindicatorsupport@rgcjonas.gmail.com[1836]: Impossible to send about-to-show to menu: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.Failed: error occurred in AboutToShow
Mär 09 20:33:10 florian-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Mär 09 20:33:39 florian-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Mär 09 20:33:46 florian-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Mär 09 20:33:56 florian-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Mär 09 20:34:04 florian-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Mär 09 20:34:17 florian-manjaro kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0x98 on isa0060/serio0).
Mär 09 20:34:17 florian-manjaro kernel: atkbd serio0: Use 'setkeycodes e018 <keycode>' to make it known.
Mär 09 20:34:17 florian-manjaro kernel: atkbd serio0: Unknown key released (translated set 2, code 0x98 on isa0060/serio0).
Mär 09 20:34:18 florian-manjaro gnome-shell[1836]: st_scroll_bar_get_adjustment: assertion 'ST_IS_SCROLL_BAR (bar)' failed
Mär 09 20:34:18 florian-manjaro gnome-shell[1836]: invalid (NULL) pointer instance
Mär 09 20:34:18 florian-manjaro gnome-shell[1836]: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
Mär 09 20:34:18 florian-manjaro gnome-shell[1836]: st_adjustment_get_values: assertion 'ST_IS_ADJUSTMENT (adjustment)' failed
Mär 09 20:34:18 florian-manjaro gnome-shell[1836]: g_signal_handler_disconnect: assertion 'handler_id > 0' failed
Mär 09 20:34:18 florian-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Mär 09 20:34:19 florian-manjaro gnome-shell[1836]: invalid unclassed pointer in cast to 'ClutterEffect'
Mär 09 20:34:19 florian-manjaro gnome-shell[1836]: clutter_actor_remove_effect: assertion 'CLUTTER_IS_EFFECT (effect)' failed
Mär 09 20:34:22 florian-manjaro kernel: Bluetooth: hci0: command 0x0c1a tx timeout
Mär 09 20:34:22 florian-manjaro kernel: Bluetooth: hci0: Opcode 0x c1a failed: -110
nothing really there…
i would try also with the latest 6.2 kernel:
sudo mhwd-kernel -i linux62
reboot, boot with it and test…
and you have some kernel parameters:
do you need them?
Yeah the
iommu.strict=1
resolves some issues with high load suspension. At some events the flush helps and I do not have to turn it off completely.
The pci=nommconf as well. Interestingly had this from your own answer :smiley:
Shall I disable both again and we see what happens ? I have the problem that suspensions breaks under high high GPU demand if not enabled
Okay I removed those parameters for now. Seems to work on the LTS 6 - Kernel so far. Let`s see how it is going :slight_smile:
so you had the same errors regarding the nommconf parameter as are in the link?
post output from logs:
journalctl -b0 --no-pager | grep -E 'amdgpu|PCIe|severity'
I had those. Since the last mainboard Firmware upgrade they are gone :slight_smile:
have removed the parameters now and it doesn’t sahow the errors right now., Let’s see how it is going :slight_smile: atm it is stable
I tried another hibernation method now => Hybrid - Standy
And now I finally have kernel message:
Mär 12 00:01:03 florian-manjaro kernel: watchdog: watchdog0: watchdog did not stop!
so there is no output from the journalctl command?
disable watchdog:
open this:
sudo nano etc/default/grub
and in this line GRUB_CMDLINE_LINUX_DEFAULT inside the quotes, put the following kernel parameter:
nowatchdog
dont remove anything from there, just add it to existing parameters, save the file with ctrl+x, press ‘Y’, then enter and update grub:
sudo update-grub
then create this file:
sudo nano /etc/modprobe.d/blacklist.conf
and put there these lines:
blacklist iTCO_wdt
blacklist iTCO_vendor_support
save it with CTRL+X, press ‘Y’, then anter and recreate initframs:
sudo mkinitcpio -P
reboot, and check if the watchdog was disabled with:
cat /proc/sys/kernel/watchdog
cat /proc/sys/kernel/nmi_watchdog
both should return ‘0’
WORKS!
Let’s see how it is going from now on! Thank you very very much!
