! I am running a very old hardware
systemd-analyze
Startup finished in 2.838s (kernel) + 21.110s (userspace) = 23.949s
graphical.target reached after 20.393s in userspace
systemd-analyze blame
8.071s lvm2-monitor.service
7.728s udisks2.service
7.685s dev-sda1.device
7.196s polkit.service
3.712s avahi-daemon.service
3.705s NetworkManager.service
3.625s systemd-logind.service
3.564s systemd-udevd.service
3.259s systemd-journal-flush.service
1.700s upower.service
1.522s ldconfig.service
1.293s ModemManager.service
1.037s alsa-restore.service
1.030s user@1000.service
712ms tlp.service
665ms systemd-tmpfiles-setup.service
574ms systemd-sysusers.service
442ms modprobe@drm.service
359ms systemd-random-seed.service
276ms dev-hugepages.mount
275ms dev-mqueue.mount
275ms sys-kernel-debug.mount
274ms sys-kernel-tracing.mount
273ms kmod-static-nodes.service
265ms systemd-journal-catalog-update.service
264ms modprobe@configfs.service
263ms modprobe@fuse.service
242ms systemd-udev-trigger.service
229ms systemd-journald.service
217ms systemd-sysctl.service
212ms dev-disk-by\x2duuid-69f52ae2\x2d6ba0\x2d47de\x2db293\x2daad95bb50a6e.swap
184ms systemd-modules-load.service
183ms systemd-tmpfiles-setup-dev.service
61ms systemd-remount-fs.service
54ms systemd-user-sessions.service
53ms rtkit-daemon.service
51ms systemd-update-utmp.service
34ms systemd-update-done.service
30ms sys-kernel-config.mount
21ms user-runtime-dir@1000.service
4ms tmp.mount
4ms sys-fs-fuse-connections.mount
systemd-analyze critical-chain
graphical.target @20.393s
ββmulti-user.target @20.393s
ββModemManager.service @19.098s +1.293s
ββpolkit.service @11.899s +7.196s
ββbasic.target @11.885s
ββsockets.target @11.885s
ββdbus.socket @11.885s
ββsysinit.target @11.866s
ββsystemd-update-done.service @11.831s +34ms
ββldconfig.service @10.306s +1.522s
ββlocal-fs.target @10.305s
ββlocal-fs-pre.target @10.305s
ββlvm2-monitor.service @2.234s +8.071s
ββsystemd-journald.socket @2.223s
ββsystem.slice @2.149s
ββ-.slice @2.149s
inxi -Fxz
Kernel: 5.4.134-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.3 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Hewlett-Packard product: HP Compaq 6000 Pro MT PC
v: N/A serial: <filter>
Mobo: Hewlett-Packard model: 3048h serial: <filter> BIOS: Hewlett-Packard
v: 786G2 v02.03 date: 10/19/2015
Info: Dual Core model: Intel Core2 Duo E7500 bits: 64 type: MCP
arch: Penryn rev: A cache: L2: 3 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 11709
Speed: 1596 MHz min/max: 1596/2933 MHz Core speeds (MHz): 1: 1596 2: 1596
Device-1: NVIDIA GF116 [GeForce GTX 550 Ti] vendor: ASUSTeK
driver: nouveau v: kernel bus-ID: 01:00.0
Device-2: Microdia Dual Mode Camera (8006 VGA) type: USB
driver: hid-generic,usbhid bus-ID: 3-1:2
Display: x11 server: X.Org 1.20.11 driver: loaded: nouveau
unloaded: modesetting s-res: 1920x1080
OpenGL: renderer: NVCF v: 4.3 Mesa 21.1.5 direct render: Yes
Device-1: Intel 82801JD/DO HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GF116 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 8-1:2
Sound Server-1: ALSA v: k5.4.134-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Intel 82567LM-3 Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: 3.2.6-k port: 2100 bus-ID: 00:19.0
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 232.89 GiB used: 8.2 GiB (3.5%)
ID-1: /dev/sda vendor: Samsung model: HD254GJ size: 232.89 GiB
ID-1: / size: 219.51 GiB used: 8.2 GiB (3.7%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
dev: /dev/sda2
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nouveau temp: 50.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1170
Processes: 141 Uptime: 9m Memory: 5.74 GiB used: 1.4 GiB (24.4%)
Init: systemd Compilers: gcc: N/A Packages: 1094 Shell: Bash v: 5.1.8
inxi: 3.3.05
neofetch
neofetch
ββββββββββββββββββ ββββββββ sage@sage-pc
ββββββββββββββββββ ββββββββ ------------
ββββββββββββββββββ ββββββββ OS: Manjaro Linux x86_64
ββββββββββββββββββ ββββββββ Host: xx
ββββββββ ββββββββ Kernel: 5.4.134-1-MANJARO
ββββββββ ββββββββ ββββββββ Uptime: 10 mins
ββββββββ ββββββββ ββββββββ Packages: 1095 (pacman)
ββββββββ ββββββββ ββββββββ Shell: bash 5.1.8
ββββββββ ββββββββ ββββββββ Resolution: 1920x1080
ββββββββ ββββββββ ββββββββ DE: Plasma 5.22.3
ββββββββ ββββββββ ββββββββ WM: KWin
ββββββββ ββββββββ ββββββββ Theme: Breath [GTK2/3]
ββββββββ ββββββββ ββββββββ Icons: breath2 [GTK2/3]
ββββββββ ββββββββ ββββββββ Terminal: konsole
CPU: Intel Core 2 Duo E7500 (2) @ 2.933GHz
GPU: NVIDIA GeForce GTX 550 Ti
Memory: 1188MiB / 5875MiB
EDIT: Here is the .svg file!
https://svgshare.com/i/ZUA.svg
