Hi, everyone. I recently tried to update Manjaro with pacman and pamac, but failed. After rebooting, I got this:
[FAILED] Failed to start Monitoring dmeventd or progress polling.
[FAILED] Failed to start Avahi mDNS/DNS-SD Stack.
[FAILED] Failed to start Network Manager.
[FAILED] Failed to start Author ization Manager.
[DEPEND] Dependency failed for Moden Manager.
[FAILED] Failed to start Bluetooth service.
[FAILED] Failed to start D-Bus Systen Message Bus.
[FAILED] Failed to start PostgreSQL database seruer.
[FAILED] Failed to start Light Display Manager.
[FAILED] Failed to start Network Manager .
[FAILED] Failed to start D- Bus System Message Bus .
[FAILED] Failed to start D-Bus System Message Bus.
[FAILED] Failed to start Light Display Manager .
[FAILED] Failed to start Network Manager 。
[FAILED] Failed to start D-Bus Systen Message Bus .
[FAILED] Failed to listen on D-Bus System Message Bus Socket.
[DEPEND] Dependency failed for User Login Managenent.
[DEPEND] Dependency failed for Light Display Manager.
Then the booting stops. I can switch to tty2/3/… with keyboard. But there is only a black screen with the cursor blinking on top left, no response for other inputs.
Any ideas? I found this: https://forum.manjaro.org/t/fix-can-t-login-black-screen-chroot-guide/3904. So, I should try the chroot way?
