Open GL EGL crashed
Hello,
While playing Asphalt Unite the screen goes black and stays black as if it was running in the background. I can’t make any changes to the game, I can’t click on any of the options, and then when I was looking for the problem, I saw that OpenGL EGL crashed and gave me an error and stopped working. I tried to delete Mesa completely and reinstall it, I couldn’t remove it because of dependencies. Then I did a clean install on the system, that is, I installed manjaro via usb. At first everything seemed fine, after installing the unstable open source nvidia driver, I saw that it crashed again. and the kernel started to appear untainted. What should I do?
the error when i command eglinfo
Device #1:
EGL device extensions string:
    EGL_EXT_device_drm, EGL_EXT_device_drm_render_node
Platform Device platform:
libEGL warning: egl: failed to create dri2 screen
zsh: segmentation fault (core dumped)  eglinfo
journald
21.03.2025 11:13	systemd-coredump	Process 3024 (eglinfo) of user 1000 dumped core.
Stack trace of thread 3024:
#0  0x000071dec763c44f n/a (libgallium-25.0.1-arch1.2.so + 0x3c44f)
#1  0x000071dec7637516 driCreateNewScreen3 (libgallium-25.0.1-arch1.2.so + 0x37516)
#2  0x000071dec9fc9cba n/a (libEGL_mesa.so.0 + 0x1acba)
#3  0x000071dec9fcb536 n/a (libEGL_mesa.so.0 + 0x1c536)
#4  0x000071dec9fca589 n/a (libEGL_mesa.so.0 + 0x1b589)
#5  0x000071dec9fb897a n/a (libEGL_mesa.so.0 + 0x997a)
#6  0x0000650fa63e51cd n/a (/usr/bin/eglinfo + 0x91cd)
#7  0x0000650fa63dd704 n/a (/usr/bin/eglinfo + 0x1704)
#8  0x000071ded06a7488 n/a (libc.so.6 + 0x27488)
#9  0x000071ded06a754c __libc_start_main (libc.so.6 + 0x2754c)
#10 0x0000650fa63dd7a5 n/a (/usr/bin/eglinfo + 0x17a5)
inxi -zv8
inxi -zv8         SEGV ✘
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=bdf63bd3-6ab8-4123-982d-f55802e2b6e2 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
  Type: Laptop System: LENOVO product: 82Y7 v: Yoga Pro 7 14IRH8
    serial: <superuser required> Chassis: type: 10 v: Yoga Pro 7 14IRH8
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76462 WIN
    serial: <superuser required> part-nu: LENOVO_MT_82Y7_BU_idea_FM_Yoga Pro 7
    14IRH8 uuid: <superuser required> UEFI: LENOVO v: LWCN27WW
    date: 04/03/2024
  ID-1: BAT0 charge: 67.6 Wh (100.0%) condition: 67.6/73.0 Wh (92.6%)
    volts: 17.3 min: 15.5 model: SMP L22M4PF4 type: Li-ion serial: <filter>
    status: full cycles: 131
  System RAM: total: 16 GiB available: 15.34 GiB used: 4.06 GiB (26.5%)
  Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
    size: 2 GiB speed: spec: 6400 MT/s actual: 5200 MT/s volts: curr: 0.5
    width (bits): data: 16 total: 16 manufacturer: Micron Technology
    part-no: MT62F1G32D4DR-031 serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
  Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
  Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
  Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
  Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
  Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
  Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
  Info: model: 13th Gen Intel Core i7-13700H bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
    microcode: 0x4124
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
    st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
    KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
    desc: 1x24 MiB
  Speed (MHz): avg: 400 min/max: 400/4800:5000:3700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 116780
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Lenovo driver: i915
    v: kernel alternate: xe arch: Xe process: Intel 7 (10nm) built: 2022+ ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:a7a0 class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile] vendor: Lenovo
    driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:28a1 class-ID: 0302
  Device-3: Bison Integrated RGB Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 5986:215d
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
    alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3072x1920 s-dpi: 96 s-size: 812x508mm (31.97x20.00")
    s-diag: 958mm (37.71") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: Lenovo 0x8ab1 built: 2022 res: 3072x1920 dpi: 250
    gamma: 1.2 chroma: red: x: 0.678 y: 0.318 green: x: 0.263 y: 0.690 blue:
    x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 312x195mm (12.28x7.68")
    diag: 368mm (14.5") ratio: 16:10 modes: 3072x1920
  EDID-Warnings: 1: parse_edid: unknown tag 112
    drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 25.0.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (RPL-P)
    device-ID: 8086:a7a0 memory: 7.49 GiB unified: yes
  API: Vulkan v: 1.4.304 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4050 Laptop GPU driver: N/A device-ID: 10de:28a1
    surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel Iris Xe
    Graphics (RPL-P) driver: N/A device-ID: 8086:a7a0 surfaces: xcb,xlib
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
    x11: xdpyinfo,xprop
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0401
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 476.94 GiB used: 22.7 GiB (4.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GEJ9X115N
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 51020A12 temp: 37.9 C
    scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 22.69 GiB (4.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: bdf63bd3-6ab8-4123-982d-f55802e2b6e2
    used: 8.3 MiB (2.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 44B8-C247
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-6:2 info: Bison Integrated RGB Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 5986:215d class-ID: fe01
    serial: <filter>
  Device-2: 3-10:3 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1217 libs: 350 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors2.manjaro.org/unstable/$repo/$arch
    2: https://manjaro.kurdy.org/unstable/$repo/$arch
    3: https://mirrors.manjaro.org/repo/unstable/$repo/$arch
    4: https://mirror.easyname.at/manjaro/unstable/$repo/$arch
    5: http://ftp.tu-chemnitz.de/pub/linux/manjaro/unstable/$repo/$arch
    6: https://mirror.alpix.eu/manjaro/unstable/$repo/$arch
    7: https://mirror.futureweb.be/manjaro/unstable/$repo/$arch
    8: https://ftp.halifax.rwth-aachen.de/manjaro/unstable/$repo/$arch
    9: https://mirrors.dotsrc.org/manjaro/unstable/$repo/$arch
    10: https://manjaro.ynh.ovh/unstable/$repo/$arch
    11: https://mirrors.up.pt/pub/manjaro/unstable/$repo/$arch
    12: https://ftp.gwdg.de/pub/linux/manjaro/unstable/$repo/$arch
    13: https://mirror.yandex.ru/mirrors/manjaro/unstable/$repo/$arch
    14: https://ipng.mm.fcix.net/manjaro/unstable/$repo/$arch
    15: https://mirror.leitecastro.com/manjaro/unstable/$repo/$arch
    16: https://manjaro.ipacct.com/manjaro/unstable/$repo/$arch
    17: https://mirror.init7.net/manjaro/unstable/$repo/$arch
    18: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/unstable/$repo/$arch
    19: http://manjaro.mirrors.uk2.net/unstable/$repo/$arch
    20: https://ftpmirror1.infania.net/mirror/manjaro/unstable/$repo/$arch
    21: https://mirror.hostiko.network/manjaro/unstable/$repo/$arch
    22: https://ask4.mm.fcix.net/manjaro/unstable/$repo/$arch
    23: https://ftp.lysator.liu.se/pub/manjaro/unstable/$repo/$arch
    24: https://ohioix.mm.fcix.net/manjaro/unstable/$repo/$arch
    25: https://cofractal-ewr.mm.fcix.net/manjaro/unstable/$repo/$arch
    26: https://nnenix.mm.fcix.net/manjaro/unstable/$repo/$arch
    27: https://coresite.mm.fcix.net/manjaro/unstable/$repo/$arch
    28: https://mirror.xenyth.net/manjaro/unstable/$repo/$arch
    29: https://nocix.mm.fcix.net/manjaro/unstable/$repo/$arch
    30: https://mirror.truenetwork.ru/manjaro/unstable/$repo/$arch
    31: https://mirror.raiolanetworks.com/manjaro/unstable/$repo/$arch
    32: https://ridgewireless.mm.fcix.net/manjaro/unstable/$repo/$arch
    33: https://opencolo.mm.fcix.net/manjaro/unstable/$repo/$arch
    34: https://mirror.math.princeton.edu/pub/manjaro/unstable/$repo/$arch
    35: https://volico.mm.fcix.net/manjaro/unstable/$repo/$arch
    36: https://edgeuno-bog2.mm.fcix.net/manjaro/unstable/$repo/$arch
    37: https://codingflyboy.mm.fcix.net/manjaro/unstable/$repo/$arch
    38: https://ziply.mm.fcix.net/manjaro/unstable/$repo/$arch
    39: https://forksystems.mm.fcix.net/manjaro/unstable/$repo/$arch
    40: https://mnvoip.mm.fcix.net/manjaro/unstable/$repo/$arch
    41: http://mirror.fcix.net/manjaro/unstable/$repo/$arch
    42: https://repo.ialab.dsu.edu/manjaro/unstable/$repo/$arch
    43: https://southfront.mm.fcix.net/manjaro/unstable/$repo/$arch
    44: https://irltoolkit.mm.fcix.net/manjaro/unstable/$repo/$arch
    45: https://mirrors.ocf.berkeley.edu/manjaro/unstable/$repo/$arch
    46: https://mirror.ufro.cl/manjaro/unstable/$repo/$arch
    47: https://mirror.archlinux.tw/Manjaro/unstable/$repo/$arch
    48: http://ossmirror.mycloud.services/os/linux/manjaro/unstable/$repo/$arch
    49: https://manjaro.c3sl.ufpr.br/unstable/$repo/$arch
    50: https://mirror.2degrees.nz/manjaro/unstable/$repo/$arch
    51: https://mirror.phoepsilonix.love/manjaro/unstable/$repo/$arch
    52: https://mirror.ufam.edu.br/manjaro/unstable/$repo/$arch
    53: https://mirror.freedif.org/Manjaro/unstable/$repo/$arch
    54: https://gsl-syd.mm.fcix.net/manjaro/unstable/$repo/$arch
    55: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 358
  1: cpu: 16.3% command: firefox pid: 1355 mem: 593.2 MiB (3.7%)
  2: cpu: 5.5% command: firefox pid: 1604 mem: 286.1 MiB (1.8%)
  3: cpu: 5.3% command: firefox pid: 2252 mem: 261.1 MiB (1.6%)
  4: cpu: 3.6% command: Xorg pid: 798 mem: 172.1 MiB (1.0%)
  5: cpu: 3.5% command: kwin_x11 pid: 925 mem: 198.2 MiB (1.2%)
  Memory top: 5 of 358
  1: mem: 593.2 MiB (3.7%) command: firefox pid: 1355 cpu: 16.3%
  2: mem: 369.3 MiB (2.3%) command: plasmashell pid: 960 cpu: 0.8%
  3: mem: 359.2 MiB (2.2%) command: firefox pid: 2068 cpu: 1.7%
  4: mem: 286.1 MiB (1.8%) command: firefox pid: 1604 cpu: 5.5%
  5: mem: 281.3 MiB (1.7%) command: firefox pid: 2171 cpu: 1.1%
  Processes: 358 Power: uptime: 23m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
I got this on journald when i play the game bef.
17.03.2025 11:22 kwin_wayland kwin_scene_opengl: 0x1: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
Please check the CPU power profile - it may be undervolted - thus it may crash when processing demands increase but there is not enough juice to fuel the demand.
this crash does not happen during any performance. When I open openGL (EGL) from the info center, I get an error that the eglinfo tool crashed while creating the page. Also, where can I check my CPU power profile? I don’t know, I couldn’t find it.
@supertramp7
https://wiki.archlinux.org/title/Power_management
eg. in my env.
cpupower frequency-info
❱ cpupower frequency-info
analyzing CPU 7:
  driver: amd-pstate-epp
  CPUs which run at the same hardware frequency: 7
  CPUs which need to have their frequency coordinated by software: 7
  maximum transition latency:  Cannot determine or is not supported.
  hardware limits: 550 MHz - 4.95 GHz
  available cpufreq governors: performance powersave
  current policy: frequency should be within 550 MHz and 4.95 GHz.
                  The governor "powersave" may decide which speed to use
                  within this range.
  current CPU frequency: Unable to call hardware
  current CPU frequency: 4.04 GHz (asserted by call to kernel)
  boost state support:
    Supported: yes
    Active: yes
    AMD PSTATE Highest Performance: 166. Maximum Frequency: 4.95 GHz.
    AMD PSTATE Nominal Performance: 124. Nominal Frequency: 3.70 GHz.
    AMD PSTATE Lowest Non-linear Performance: 59. Lowest Non-linear Frequency: 1.76 GHz.
    AMD PSTATE Lowest Performance: 19. Lowest Frequency: 550 MHz.
Looking at the inxi output - it seems you are on unstable branch.
This would indicate - either a problem with the opensource Nvidia driver or a confuguration issue.
Nvidia is outside my knowledge - I admit I have been tempted to buy a laptop with Nvidia - but it would only be for testing Manjaro - and I am not sure the community would approve funding a laptop solely for such purpose.
analyzing CPU 14:
  CPUs which run at the same hardware frequency: 14
  CPUs which need to have their frequency coordinated by software: 14
  hardware limits: 400 MHz - 3.70 GHz
  current policy: frequency should be within 400 MHz and 3.70 GHz.
                  within this range.
  current CPU frequency: 401 MHz (asserted by call to kernel)
    Supported: yes
    Active: yes
Here is my cpu power profile. does it show a problem? the previous driver was freezing so I switched to unstable but more up to date drivers. can I go back to stable? how do I go back?
Nvidia comes in two flavors proprietary and open-source.
For kernel 6.12
  • linux612-nvidia
  • linux612-nvidia-open
You just have to choose which one you use - I cannot help you chosing - I don’t use Nvidia - so there is that.
I also see this behaviour. I don’t know if it is a widespread issue or if it affects eglinfo and kinfo only.
same error here
kinfo ??
kinfo         ✔
KDE Plasma Version: 6.3.3
KDE Frameworks Version: 6.12.0
Qt Version: 6.8.3
Kernel Version: 6.14.0-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 32 × Intel® Core™ i9-14900KS
Memory: 62.5 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 4070 Ti SUPER
